  • downwindleg
    • 1279
    • Friday Harbor, Washington
    Originally posted by WAY BAD
    Here's Steve's (RCJetDude), he just fnished TV on his.
    https://youtu.be/Pn7YuqLgYZ4?t=2
    Really amazing flight Steve, wouldn't have expected to see that in an EDF. More like what you would expect from some 3d park flyer. Very cool all the way around. Would like to see the linkage between top and bottom vector petals. Maybe George can do a follow up set of pics for his vectoring assembly.
      • 5384
      I posted pics of mine a ways back, ball links.
        Thanks to Evan D for his help as I was able to program tailerons. I also added some floods to the main gear. So, opening canopy, wingtip lights and strobes, RC Geek center-burner, Jeremy Solt's slime lights, mains floods, 3D printed cockpit parts and thrust vectoring. I am done....
          • 5384
          You’re going to like those as well as the TV’s! :)
          • downwindleg
            • 1279
            Very cool Steve and yes I saw your ball link setup Evan D but Steve used a different linkage than yours that was less obtrusive. That's why I was asking. Many thanks to you by the way for being the pioneer of this mod. Hoping to try it myself when I get the plane.
              I just used the standard ball links used on Freewing planes. Drilled holes in the tab on each plate to thread the ball link screw into then clipped off the excess on the back side. Filed it down a bit and hit it with a spot of glue to help secure it. The links themselves have to be cut shorter but just secure to the threaded end of a pushrod that I snipped off.
                More pictures of the continuing TV saga:Silly:
                    • 5384
                    Well done!
                    • john2kx
                      • 112
                      • North Augusta, SC
                      Steve,
                      What did you use as floods for main gear? Wired to MCB or separate power/activation system?
                      Freewing A10, F4, F22, Sebart Avanti S mini
                        Originally posted by john2kx
                        Steve,
                        I got some white 1W LED's off of eBay, made some 3D printed mounts for them which I then just glued to the gear doors. I made a three to one harness and just plugged the nose strut light and two main strut lights into the take off light spot on the MCB-E. I then recessed the foam in the wing where the light fit when the gear was retracted. I think Pat did something similar on his.
                        Click image for larger version  Name:	IMG_20190102_220251.jpg Views:	1 Size:	221.1 KB ID:	170061
                        Click image for larger version  Name:	IMG_20190102_215306.jpg Views:	1 Size:	171.6 KB ID:	170055
                        Click image for larger version  Name:	IMG_20190102_215314.jpg Views:	1 Size:	169.0 KB ID:	170056
                        Click image for larger version  Name:	IMG_20190102_215320.jpg Views:	1 Size:	139.4 KB ID:	170057
                          • 8202
                          Steve your F-22 is pimpin' brother! Love it!! :Cool:
                          • john2kx
                            • 112
                            • North Augusta, SC
                            Thanks for the detailed description and pics Steve!!
                            • JazzmanB
                              Flying and drumming in the pocket
                              • Sep 2018
                              • 85
                              • Sf
                              From today https://youtu.be/tSDq7KmIaaM
                              • downwindleg
                                • 1279
                                So George, love all the pictures of the TV. Just one question, what is the second rod going across the whole thing. Is that just for longitudinal stability with the torque rods crimped together inside the tubes?
                                  Yes sir ;)
                                    I think I'm finished...maybe;)
                                      • 5384
                                      I like it. On mine my flaps move less that yours in proportion to the ailerons. The full span ailerons and tailerons produce a really high roll rate. I have a elevator to flap mix with Up elevator causing down flaps. This is not working as well as it does on other planes I have and I think the next flights out I'll reverse that and if still not effective turn it off.
                                      I like the triple flash on the top of the fuse and have been back and forth on if I want one.
                                      Great job!
                                      • adb2@suddenlink.net
                                        Advanced Pilot
                                        • Nov 2018
                                        • 104
                                        • Abilene Texas
                                        Did you do this to all three gear? About to soften mine up as well.
                                        John
                                        I tried the softer springs and they were just too soft, Wouldn't hold the plane up. I then followed your measurements and you hit the nail on the head. Just much better. Thanks
                                          Advanced Pilot
                                          • Nov 2018
                                          • 104
                                          • Abilene Texas
                                          I wanted to give TiredironGRB credit for cutting down the springs. Worked very well. Much better.
