  • Corsair nut
    Jets...warbirds...mmm hmmm
    • 218
    • Tehachapi ca
    We had a grumman day at the field yesterday. Had my f8f and f14 out for some great flights. F7f belongs to my dad.
    • vduniec
      Hobby Squawk Pilot
      • 314
      Originally posted by GarrisonR
      Well I picked up a F-14 ARF, I have wanted one for a while now and I was inspired by Cosair Nut’s build/paint videos, I figured while my flying fields are shut down and with all this extra time I’d make it happen. I’m filling in panel lines, repainting and using A-10 ESCs with T-33 9 blade inrunners. Might test out the 12 blade rotor eventually.
      I designed this 3D printed main gear brace. I don’t fly off grass but my clubs runway has it’s issues and I figured for the occasional hard landing it’d be worth it. Plus I have the time..
      I’m open to any and all feedback on the design, especially before I glue or epoxy it in. Thats my other question, do you guys think I should glue it in with Foam Cure or use epoxy? The glue I'd use is similar to the included freewing glue and has a bit of give to it.
      The brace weighs 35g with 15% infill but was honestly plenty strong with 10% infill as I increased the wall thickness and top/bottom layers.
      I also plan to strengthen the nose gear, likely with some variation of the RCINFORMER’s method.
      If others are interested I can post the STL also.
      Those look great! I'd be interested in the .stl's. I'm rebuilding mine and might consider installing those.
      • Brinka
        Because I was inverted!
        • 121
        Awesome job! Pics look fantastic. 👍
        • GarrisonR
          • Jul 2019
          • 56
          • La Mesa, CA
          Attached! Just mirror about the long axis in your slicer for the opposite side.
            Thanks for the file! I printed up a set yesterday for the one I'm going to be working on soon. Nice solid structure and low weight.
            • GarrisonR
              • Jul 2019
              • 56
              • La Mesa, CA
              Nice, no problem!
              Quick notes I forgot to mention
              -When clearing out the foam for the flat bit on the end (did that for more glue surface area in an additional direction) be careful to not go too deep on the inner side (closest to jet centerline) as the duct for the edf is just below. You cold even trim off the inner portion of the flat to be safe.
              -You can use the brace for the opposite side, placed upside down to trace on the foam for where to cut, or you could also print 1 more and stop the print short (before the long bits stick up when printing upside down) just flip it over for the other side.
              -Removing the foam on either side of the end of the carbon spar and you will be at the top of the gear mount, thats the depth of foam to be removed for the top of the part that sits flush with the foam.
              If you have any questions just let me know! Mine when in without a hitch, and literally snapped on to the gear mount perfectly.
                Thanks for the installation tips! I've had my second F-14 for several months now, but other projects have gotten in the way (been playing with turbines lately). Now that Summer is here (building season for us in the Arizona desert) I'll get back to it.
                • vduniec
                  Hobby Squawk Pilot
                  • 314
                  Cool! Thanks for sharing.
                  • John Bergsmith
                    • Mar 2019
                    • 189
                    • Concord, NC
                    Your Tomcat looks outstanding. I had the opportunity to see them often throughout the 80's and 90's and your weathering looks great. Excellent job!
                    • gooniac33
                      The Original Gooniac
                      • Jun 2016
                      • 1047
                      I got a crazy flight with the wild teenagers at my field a couple weeks back... take a look... Sunset flight so cool to see all of the LEDs shining bright!
                      • Door Guns
                        • Oct 2019
                        • 19
                        Can someone confirm that the stock decals applied at the factory are water slide?
                        I'm planning to give this thing a make over. Just want know what I'm getting myself into before it arrives.
                        Thanks,
                          Thanks,
                          Yes, they are water slide. Just paint right over them.
                          • Door Guns
                            • Oct 2019
                            • 19
                            Thanks for the info. I'm hopping I can wet them wet and remove them.
                              Don't bother, it won't work. They have a glue on the back that sets when dry. Wetting them will not loosen the glue. Just paint over them, you won't be able to tell they were there. Lightly sand them with 400 grit if you feel it's necessary.
                              • N4Speed
                                • Jun 2020
                                • 50
                                • Dallas TX
                                Hi Folks,
                                I spent over 10 years flying and enjoying various RC planes and cars, but have been away from it for many years and now getting back into RC. I bought an E-flight Apprentice STS 1.5m to get started and get comfortable. I also got an E-flight P-51D Mustang 1.5m to transition to from the trainer. I just received my Freewing F-14 Tomcat, unpacked it and wow, what a beauty!
                                The other 2 planes are ready and I will start flying the trainer this week in local RC club. I plan to take my time building the F-14 and won't fly it until I am very comfortable with P-51, I might even get a beginner EDF prior to flying F-14.
                                I am trying to get the right radio system for the F-14. For the other 2 planes, I am using Spektrum DX8 G2. My goal was to follow RC Geek’s radio setup which I think needs 9 CH. I got a Spektrum Ix12 but I have seen mixed reviews on various website for Ix12. I am now thinking to return Ix12 and was thinking to either go with another DX8 G2, use 7-Ch as per instructions and use a gyro to help with flight stabilization or get a DX9. If at all possible, I prefer to stay with Spektrum brand for buddy box reasons.
                                I appreciate any input you guys have on radio selection or anything else regarding F-14.
                                  • 8201
                                  Welcome to Hobby Squawk N4Speed ! Sounds like you have a good plan in place overall. I have to suggest that I definitely would recommend some decent EDF training before flying this F-14. Even being comfortable with the P-51, there's little resemblance to the F-14 as far as overall flight characteristics, wing load and especially the complexity of the wing-sweep functionality. As we have posted on our YouTube page recently, there's a vast difference in flying prop versus EDF jets so I hope you take that in consideration. Enjoy the progress and much success to you!
                                  • N4Speed
                                    • Jun 2020
                                    • 50
                                    • Dallas TX
                                    Thank you Sir! I agree, what is a good beginner EDF?
                                    Also, any suggestion on radio? back when I was flying, Futaba, HiTec & Airtronics were the way to go, but I am not having much luck finding 9 CH plus in these 3 brands. The only Airtronics I found was developed 10 years ago and looks like they are no longer in business in USA. I found Futaba 10JA but it comes with 8-CH R3008SB Receiver.
                                    I am tempted to give iX12 a try but in most review sites, it only gets 3.5/5
                                      • 8201
                                      For me personally, I would look at the smaller size EDFs and work your way up...There are a lot of EDFs we carry that are considered "trainer-like"...Look for something with a solid wing surface at first...Start in the 64mm/70mm range and work your way up from there. We don't have any EDFs that have the swept wing function other than the F-14. So that is just something you will have to learn on as you fly it. For radio, I have flown Spektrum for most of my two plus decades in the hobby. Futaba is fine too...I have the iX12 as my current radio. It has its warts but I do love the touch screen functionality. Otherwise look for a DX9 or something comparable if you would consider Spektrum.
                                      • SJN
                                        • Mar 2019
                                        • 7
                                        • Denmark
                                        Hi Guys.
                                        Im looking to upgrade my stock 6 blade setup to the stock 12 blade version and still use the 80 amp ESC`s
                                        When you look at the spare parts section on motion RC site there are 2 different 12 blade EDF units.
                                        What is the difference, and has freewing changed the EDF during the time it has been out ?
                                        One has a metal spinner, and the other has a plastic spinner
                                        https://www.motionrc.eu/products/fre...-w-3530-1680kv
                                        https://www.motionrc.eu/products/fre...r-motors-black
                                        Click image for larger version  Name:	freewing-80mm-12-blade-metal-edf-set-for-outrunner-motors-black-motion-rc-2403301949489_1024x1024.jpg Views:	0 Size:	60.5 KB ID:	258855Click image for larger version  Name:	freewing-80mm-12-blade-edf-6s-power-system-w-3530-1680kv-motion-rc-5492402159665_1024x1024.jpg Views:	0 Size:	68.1 KB ID:	258856 Click image for larger version
ID:	258857Click image for larger version
                                        • SJN
                                          • Mar 2019
                                          • 7
                                          • Denmark
                                          Well, 12 blade EDF`s arived, and are installed. Now I just have to get the CG in spec again, and looking forward to some better noise than the 6 blade fans :-)
                                          One fan was in perfect balance, and the other just needed a tiny bit of tape to balance out as perfect as the other. Looking forward to the next flight :-)
ID:	259404​​​ Click image for larger version
ID:	259405Click image for larger version
ID:	259406Click image for larger version
ID:	259407Click image for larger version
ID:	259408Click image for larger version
ID:	259409Click image for larger version
ID:	259410Click image for larger version
ID:	259411Click image for larger version
ID:	259412Click image for larger version
ID:	259413Click image for larger version
ID:	259414Click image for larger version
ID:	259415​​ Click image for larger version
