View Post
View Post
It's my F-4 that's on the 8S inrunner setup and it's night and day to the 9-blade power system, I completely love it but think the F-18 wouldn't handle the extra weight as well as the Phantom.
View Post
I'd love to know how you get on with that CG, I had some real issues with my maiden (all ended well) but the Gyro kept forcing the nose down. I think this was my fault as the placement was a compromise and I suspect it's canted at an angle I couldn't immediately see. I will re-calibrate which will solve the issue I'm sure.
One of my flaps also got jammed around 80% deployed against the fuselage (which it wasn't doing on the ground although I knew there wasn't much room between the flap and the fuselage despite my trimming nearly 10mm off both sides). This caused the whole jet to roll crazily after I deployed them, it was all I could do to jam in opposite aileron and rudder to land her.
I actually fly with the Chairman of IMAC here in the UK (Malcolm Green)... small world!
View Post
Andy
My luck they'll get the Mig back in stock on May 16th!
). Now those concerns/issues plague my every thought!
Something to be said for "Ignorance is Bliss"!
