One thing to try/test to reduce the chance of the flap deployment issue occurring is to move the L-bend of the control rod to an inner hole on the servo arm (closer to the arm center screw) of the servo to achieve better torque from the servo. This will be at the expense of servo throw, but if you can achieve enough servo throw for the flap positions you want by using an inner hole on the servo arm, then an outer isn’t necessary or beneficial if you’re wanting to prioritize torque. It’s been a while since I’ve owned the Freewing F/A-18C, so I can’t remember which servo arm hole I used on the flaps for the linkage. However, then again, the flap issue could simply be from the stock servo not being strong enough for the job. It’s still worth a try
It’s likely been discussed, but I haven’t kept up on this thread at all. If so, my apologies. I remember a discussion long ago about keeping the flap deployment speed in the radio to a reasonable amount because if too slow it could cause issues. I always had mine on 2 seconds or less and didn’t have an issue, thankfully.
.It’s likely been discussed, but I haven’t kept up on this thread at all. If so, my apologies. I remember a discussion long ago about keeping the flap deployment speed in the radio to a reasonable amount because if too slow it could cause issues. I always had mine on 2 seconds or less and didn’t have an issue, thankfully.
But at least I saved about $120 by ordering them just before the 15th! Probably shouldn't have undertaken the repaint of the Mig at the same time but couldn't leave it in the box so I figured it was better to paint 2 at once and save some "paint barn" costs and time. Finished the Mig cockpit and just finished the Hornet cockpit. Now it's on to final masking and primer time for both.
