Third time was the charm, this white matches the stock white almost perfectly. Semi gloss has just a little more shine to it, but you can adjust that with polycrylic on top if necessary.
I never would have thought that my AL37 would have been modified so much but it became a KC-135. I then got more and more ideas which took me to this wild idea that was proven successful today. The newest mod is that I added an F-16 to my Boom and made it look like it was refueling in the air. I hope you all like the pics and video. Video link here https://youtu.be/wD-hzv6mAM0
12 PhotosComment
4923crew Jeremy, that is way too cool. Can you hook up my 90 mm F-16 as well, that may be the only way I can get a clean flight in!
I couldn't tell, but is your boom on a servo that raises up on landing so the poor little F-16 doesn't touch first, or is it on some sort of spring loaded retract?
Hangar: EDF's: Mig 29 TV "Cobra", A-10 Arctic, SU-27 90mm 8S:F22 Red Lion/EuroFighterBronzeTiger/F18 Canadian & Tiger Meet/F16/F4 Jolly Rodgers & Blue Angel, 80&90 TV Avanti, Viper, Stinger 90. Props: 1600 Corsair & Spitfire, B-24, 1700 P-51, 60" Beast & P2 Bipe, Extreme Flight-FW-190 Red Tulip, Slick 60, 62" Extra 300, 62" MXS Heavy Metal, 62" EdgeComment
Just about have mine finished up! Does anyone have a good method for getting this assembled at the field? It seems really awkward trying to plug in the wings, extend the gear, reattach the wings, etc.
I haven’t read this thread much so go easy on me. Thanks my dudes
1 PhotoComment
I made a stand out of the box it came in. Using a HOT hacksaw blade, I cut two sections of the box that the fuse lays in. It's the exact shape of the fuse.Comment
I am fixing to maiden my al37 and I see all of the videos showing battery strapped down about middle of a admiral 5100 carbon pack and battery strap at the rear of the battery plate, when I put at that location, she seem really nose heavy .to make her balance slightly nose heavy. I have hang 3/4 of the battery off the rear of the battery plate, is the plane suppose to fly nose heavy?Comment
How are you holding the plane to balance it? Are you doing it right side up or upside down? It is not accurate or easy to do it right side up. This plane should be held upside down.I am fixing to maiden my al37 and I see all of the videos showing battery strapped down about middle of a admiral 5100 carbon pack and battery strap at the rear of the battery plate, when I put at that location, she seem really nose heavy .to make her balance slightly nose heavy. I have hang 3/4 of the battery off the rear of the battery plate, is the plane suppose to fly nose heavy?Comment
3/4” PVC with foam pipe insulation. They work great at the field, just flip the plane over for attaching the wings. Build the cradle tall enough so you can lower the gear in the cradle.
These are approx 30” long the one for my AL37 is a bit longer.2 PhotosComment
.png)
