  • Rcfiddy1
    Professional Crash Test Dummy
    • Aug 2015
    • 186
    • Manalapan, NJ
    Anyone have a good ejection seat? Now that my bird is flying it’s time to do some upgrades to the mitten wearing munchkin pilot. I just finished resin printing a pilot and now need some seating.
    • leithalweapon
      • Aug 2020
      • 113
      • DeKalb, IL
      Originally posted by PaulZ
      Successful maiden! Here is a video of flight #4: https://youtu.be/CqV0Z66s-5k
      ​​​​​​One observation - there is certainly a non-linear response to the elevator, it feels awkward. I have the upgraded servos from MRC. I think it is due to the flex on the control rods. Even with the carbon fiber tubes the rods flex. Funny enough MRC sells rods for the F-14 Wing sweep mechanism that are perfect length and are much thicker. I'll be installing these soon: https://www.motionrc.com/products/fr...ng-pushrod-set
      Wow would have made things much easier if MRC had realized they had a simple solution on hand. Let us know how it works!
      • Airguardian
        Post Stall Svengali
        • Aug 2020
        • 1676
        • Catalonia
        Send pic of that pilot!
        • Rcfiddy1
          • Aug 2015
          • 186
          • Manalapan, NJ
ID:	280415Click image for larger version  Name:	Screenshot 2020-10-13 190530.jpg Views:	0 Size:	83.6 KB ID:	280413
          • Rcfiddy1
            • Aug 2015
            • 186
            • Manalapan, NJ
            I used same pilot in f18 and it turned out pretty good. Just scaled it to sized. Click image for larger version
            • Scale Master
              X USAF Pilot, Commercial IFR Jet Rated
              • Apr 2019
              • 86
              Special thanks to Chris for hooking me up with a pair of Mig-29 Rocket pods! They look great and the design of them is spot on. I still need to ad the finishing weathering touches to them but they look good. See pics below. Chris I might order another pair from you....... I'm thinkin it looks better with two pods on each wing. I saw a few pics online with that config and the jet looks great.
ID:	280444Click image for larger version  Name:	IMG_9494.jpg Views:	0 Size:	130.2 KB ID:	280441Click image for larger version  Name:	IMG_9496 (2).jpg Views:	0 Size:	113.2 KB ID:	280442Click image for larger version  Name:	IMG_9497.jpg Views:	0 Size:	101.1 KB ID:	280443 Click image for larger version  Name:	IMG_9492.jpg Views:	0 Size:	139.5 KB ID:	280440
              • mshagg
                • 541
                • South Australia
                Nice! Just putting the finishing touches on my first pod and starting to print up a second. They're bigger than they look in the slicing software lol.
                • mshagg
                  • 541
                  • South Australia
                  Making progress on the air to ground loadout. These take a surprising amount of time to print and paint.
                  • janmb
                    Slow and low
                    • 729
                    Stunning projects, those pods look badass.
                    Will definitely need to print some for myself i due time. Thanks to Chris G for the design.
                    Unfortunately, my MiG had a dead main retract out of the box, but motion showed impeccable customer service as usual, so a new was in the mail hours after the ticket was written. Sucks to wait another week, but gives more time to build well anyway.
                      • 5401
                      Did you check connection behind the wing interconnection board Jan? I had some connections that were loose to the point they could have easily come off.
                      • Jet jocky
                        • Aug 2020
                        • 44
                        Does anyone know how to remove the small tiger head one the intakes without ruining the paint. Or do you have a perfect color match so I don't have to repaint the whole bottom. I want to put block numbers in that area.
                          • 5401
                          Good question as I'm intending to just paint over it at some point.
                          • Jet jocky
                            • Aug 2020
                            • 44
                            Did a repaint wich was a pain had to be careful so it wouldn't pull the gray paint off.
                            • Gringotuerto
                              • 409
                              • San Diego
                              I did the same thing, painted over and put number decals on it. I used Model Masters Dark Ghost Grey acrylic. It seemed close enough match that I couldn't notice the difference.
                              Probably my wife would say it needs closer color matching, but on the other hand, I would say her knitting machine needs a turbine motor upgrade.
                              • GliderGuy
                                • 1412
                                Click image for larger version  Name:	DE4C6692-A0BE-4F8E-9E3C-9D45E33D7778.jpeg Views:	0 Size:	98.4 KB ID:	280473
                                From a prior post..,..HD paint dept:
                                I still need to get a can.
                                • Radar-Guy
                                  AirBorn Jetworkx
                                  • 364
                                  All retracts are fuselage mounted, leads go directly into the MCB (aka blue box).
                                    • 5401
                                    Oops, you are right. None the less there were loose servo connections behind one of the wing interconnection plates on mine. I assume he did check connections on the MCBe...
                                    • janmb
                                      Slow and low
                                      • 729
                                      The retracts on the MiG are part of the body, and does not go through that board or ribbon at all.
                                      I removed the entirely retract device and tested it completely isolated. So all other sources are ruled out.
                                        I went and got a can of this several weeks ago. Perfect match!
                                        • evensen007
                                          • Jul 2020
                                          • 101
                                          • Asheville, NC
                                          Just a PSA that the Socokin 6000mAh 6s 60c batteries are on amazon prime deals for 59 bucks a piece! I've been liking them; comparable to my HRB 6000's.
