    • 4857
    Hugh Wiedman, that is just crazy smart. Bravo Zulu, Sir. Best, LB
    • spcboarder
      • Jan 2023
      • 7
      Hello,
      I have just applied all the decals on the vertical stabilizers. They do look great. I can recommend to use decal softener for a great looking finish.
      Does anyone know, where the camouflage decal is going? In my attached screenshot it is marked orange.
      I cannot see it from Alpha's pictures. Possibly somebody can upload a picture of his MIG-29 with the decal applied?
      Thanks for the hints.
      Br, spcboarder
      Originally posted by Alpha
      Apply the included waterslide Tiger decal, port and starboard, to depict this livery:
      Click image for larger version Name:	Tiger CAG - Port.jpg Views:	0 Size:	277.0 KB ID:	267876Click image for larger version Name:	2317404.jpg Views:	0 Size:	150.9 KB ID:	267881
      Here are the decals themselves, out of the box:
      Click image for larger version Name:	IMG_20200810_092045.jpg Views:	0 Size:	77.6 KB ID:	267878Click image for larger version Name:	IMG_20200810_092106.jpg Views:	0 Size:	64.1 KB ID:	267879
      And showing the Tiger decal's placement (self-explanatory... just apply it directly over the existing camo decal on the vertical stab)
      Click image for larger version Name:	IMG_20200810_092158.jpg Views:	0 Size:	78.3 KB ID:	267877
        • 2709
        Thanks LB, but "crazy smart"? Many folks use that first word to describe me, but almost no one, including my CO, ever use the second word. 🤯
        • Olivier_
          • Sep 2023
          • 36
          • France
          Hello dear airplane pilots !
          I would like to have your opinions (also look at the pictures), because I am preparing my MIG for its first flight in a few days !
          • To have my MIG balanced on the manufacturer's CG, I must use the second compartment at the very front of the plane. The one in the middle gives me a rear CG. For information I use spektrum 6S - 5000mah - 50C - 690g. I installed the blue box and the receiver under the rear battery plate. What do you think ?
          • Also what do you think of the rates proposed in the manual ?
          waiting your answers,
          Thanks 😁
          Olivier
          • Vondug
            • Sep 2024
            • 2
            • Pilot A&P Mech. Rc for 40yrs
            Definately use forward bay for battery! Learned the hard way, test flight day before yesterday! It did not turn out well! Replacement parts on the way!
            • Olivier_
              • Sep 2023
              • 36
              • France
              What happened ?
              Did you use the middle compartment ? ​
                • 4857
                Vondug,
                terrible what happened on your first test flight.
                Welcome to Hobby Squawk, glad to have you onboard.
                Best, LB
                • Vondug
                  • Sep 2024
                  • 2
                  Yes I used middle compartment on the vt version. test flew other day battery up front, balanced 10mm behind wing cg marks. Nose heavy! nose retract servo took a crap so waiting on new one to come in! will give more updates!
                  • lusek_pl
                    • Sep 2020
                    • 49
                    • Polska
                    Has anyone of you replaced just the nozzles in the rotors with these new 12-blade ones?
                    I have a problem because they are too wide
                      • 5401
                      Yes, they don’t fit. Not even close.
                      • lusek_pl
                        • Sep 2020
                        • 49
                        • Polska
                        The question is how to solve this, can anything be done about it. On motionrc they claimed it would fit... Grinding the rotor is a bad idea because it will be unbalanced. It is too wide by about 1 to 1.5 mm. Maybe grind the stator? Because the motor mount fits, only the diameter, I don't know why it has that size.
                          • 5401
                          Buy the shroud for the 2150 fan. Motion only sells it as a set I think.
                          Freewing 80mm 12-Blade EDF Set B for Inrunner Motor [P0808] Motion RC​​
                            • 5401
                            • yogi
                              • Dec 2024
                              • 4
                              Hi All, question looking to upgrade the elevator servos on the Mig29 was thinking about AGF B26CLM ….. after something with a little more torque and more throw. Any suggestions?
                              • yogi
                                • Dec 2024
                                • 4
                                Specification
                                Operating Voltage: 4.8-8.4 V ​Operating speed: 0.095sec/60°@6.0V ​Operating speed: 0.085sec/60°@7.4V ​Operating speed: 0.080sec/60°@8.4V ​Stall Torque: 8.5 kg-cm (118 oz-in) @6.0V ​Stall Torque: 9.5 kg-cm (132 oz-in) @7.4V ​Stall Torque: 10.5 kg-cm (146 oz-in) @8.4V ​Gear: Titanium ​Motor: CLS ​Size: 35.8*15.2*29.7mm (1.41 x 0.59 x 1.16 in) ​Weight: 26g ​Connector Wire: JR 180 mm
                                worried it could be a little too big ?
                                  • 2709
                                  Originally posted by yogi
                                  Specification
                                  I used the Promodelers. On the road but don't remember the model number. Fit perfectly and they're smooth as silk with plenty of torque. Somewhere back in this thread I listed them. I usually upgrade with hitecs, but tried these and absolutely love them.
                                  • yogi
                                    • Dec 2024
                                    • 4
                                    Are the promodeller servos 24 or 25t ?
                                      • 2709
                                      Not home so not sure, but I think they were 24, as I used the metal servo arms that came with the Freewing upgraded elevator servos. Also used the Hangar Nine titanium rods. With the Promodelers, you also need one of their small online servo reverser for one of the servos, right side if I remember correctly. I'll be back home around the 23rd and get all the specs and info to you then. They were a drop in fit.
                                      • Airguardian
                                        Post Stall Svengali
                                        • Aug 2020
                                        • 1676
                                        • Catalonia
                                        Love to fly at beautiful fields... there's nothing quite like that! :D
                                        • ahajr
                                          • Mar 2025
                                          This is a new Freewing Redstar MiG-29 Fulcrum Twin 80mm. I am having a issue where the thrust vector module is jamming and stalling the servo. I have checked the servo and the ball links. They are all fine out of the system. In the attached video you can see what I'm talking about. Does anyone know the internals of the outer and inner housing? Is there an internal pin that may be broken or loose? I'm not looking forward to busting this all loose on a new unflown plane to see how it works. I am wondering if there is a known fix. I am thinking there is a broken pin or a warped outer or inner part. Customer support says these are the fix https://www.motionrc.com/products/fr...nkage-set-n329​. However these don't look anything like what is on my plane unless they are internal to the mechanizm, which I can't see without taking it all apart.
