So true for a plane like a sailplane, which can have flaps and ailerons. However, this plane, being a flying wing, doesn't really have flaps and ailerons. They only used those terms to differentiate the inner and outer control surfaces. Regardless of them being "innies" or "outies", they are still elevons and they should have called them inner and outer elevons. That being the case, I've always considered "reflex" as being UP elevator and nothing really to do with flaps/ailerons. All my other flying wings have always referred to using some "reflex" to aid in launch. This was also suggested for the A-10 models.
Here’s a company that builds a position control box for the RV-10 type aircraft. They use the term REFLEX for negative (up) control surface position.
Good ‘nuff for me as are the other posts which define reflex as up control position. I won’t hesitate to use the term going forward to indicate “up”.
Therefore, for the B-2…
Setting the inner surfaces to 8 mm reflex and the outer (non-clamshell) surfaces to 4 mm reflex as a starting point for a maiden is a perfectly acceptable use of the term REFLEX…IMHO.
This is interesting. It’s the first time I’ve heard of this. I guess you just showed an old dog a new “trick”.Here’s a company that builds a position control box for the RV-10 type aircraft. They use the term REFLEX for negative (up) control surface position.
Hey all.
I'm learning an editing software so I recut the previous B-2 video with the on board camera. Let me know if this is a better format for future videos please.
old cut
new recut
Thanks
JoseComment
„REFLEX“
It‘s about the „camber line“ (a curve halfway between upper and lower surfaces) of an airfoil. For tailless aircraft, an airfoil with a „reflexed camber line“ will help to improve stability.
When looking at the FW B-2 wing, there seems to be such an airfoil at the inner portions, but it soon changes to a conventional „semi-symmetrical“ airfoil (look at the outer wing root). To keep „the reflex“ over most parts of the wing, the control surfaces need to be trimmed up.
Indeed.„REFLEX“
https://en.wikipedia.org/wiki/Camber_(aerodynamics)
An airfoil where the camber line curves back up near the trailing edge is called a reflexed camber airfoil. .Comment
Nice work Icarus the 2nd , not only did you get off grass in a short distance, it was WET grass, so kudos to Radar-Guy for the mods.
For those of you interested in B2 historical information, the Smithsonian channel has a series called Air Disasters (great program which sums up my flying skills). This year one of the episodes is called "Stealth Bomber Down", from Season 17 (current), episode #3. It's well worth the view. It details the take-off crash of the Spirit of Kansas from the Guam airbase in 2008 which shut down B2 operations for several months and potentially could have ended the B2 program. There is outstanding real videos, interviews, analysis of the crash to determine the cause and insight into the most sophisticated aircraft in the world, which was quite fascinating to me (especially when you find out what brought it down). Also learned that the $44 Billion B2 program had 21 bombers in total (not sure if that's still current) and initially had 300 hand picked pilots in the group, the best of the best. Each B2 was named after a state, except two which were designated as the "Spirit of America" and the "Spirit of Kitty Hawk". I won't spoil it for anyone interested in watching it, so you'll have to see it for yourself, which IMO is well worth it.Hugh "Wildman" Wiedman
Got the chance today (after a 4 in rain last night) to hit the pavement and try out the rotary knob channel (normally flaps) mixed as master and the elevator as the slave channel.
The mix is adjusted so that when I rotate the knob fully, it adds about 4 mm more of up elevator trim. Both outer ailerons also move up a bit as the inner elevators move up a bit.
Why? Because I am a little nose heavy and gear down at 25% pattern throttle, she requires holding some additional up elevator. Being lazy. I implemented the mix (lots of ways you can do this). It works great! I use it for both take-off and landing and get rid of the extra “up” once the speed increases and the gear is up after take-off.
I made the mistake of not going around on a bounced landing. Ended up bending the worm gear in the nose wheel retract servo. Had to replace the retract servo this evening. UGH - If she bounces, react fast….power up and go around and try again.
-GGComment
Well done G. !! :-) Kind Regards JörgComment
I can't answer for him, but I've used a lot of these and they are very inexpensive:
https://www.amazon.com/gp/product/B0...rch_asin_title
https://www.amazon.com/6000K-6500K-6...188720-7042619
and if you are willing to go with 1W LEDS (which are still plenty bright) you can get a lifetime supply at $0.13 each:
https://www.amazon.com/dp/B07DPRWVRF...pa_dk_detail_0
Here's what they look like on my Mirage
