Official Freewing 90mm Eurofighter Typhoon EDF Jet Thread
Glad your enjoying yours, it is an awesome flyer and one of the best looking in the Freewing lineup, I sold mine recently just because I got into the bigger jets but enjoyed all the flights I had with it, hope to see an even larger version one day.
In the absence of specific guidance in the manual, the consensus seems to be that it's an alternative spring for the nose strut, with a different stiffness.Comment
If it's like other Freewing struts, you just need to remove the trailing link (be careful not to lose the circlips) and pull the plunger out. The spring fits behind the plunger.Comment
Just putting mine together and a few things. First is a very nice-looking plane and i am very much looking forward to the maiden. I also noticed the extra spring so thank you guys for answer that question above.
Also, even though it comes with no tiger decals applied, it still has many out of the box including wing stickers and an aircraft number, which is disappointing. Anyone know of a good way to remove those?
Online many complain about the gear cycle speed but mine go up and down lightning quick, which makes me wonder if they changed something in the blue box? I was planning on ripping out their mixing box entirely save for keeping the lights going but now I might just fly it as stock before performing the surgery.Comment
Paint over decals you don’t like. You can’t remove them without harming the surface of the foam. You can program the retract sequencing through most radios or use Kallends sequencer (I tried and took it out), or swap out the FreeWing sequencer (what I’ve done) or live with it.Comment
I changed the code in response to your comments. I don't think you tried the revised version.Paint over decals you don’t like. You can’t remove them without harming the surface of the foam. You can program the retract sequencing through most radios or use Kallends sequencer (I tried and took it out), or swap out the FreeWing sequencer (what I’ve done) or live with it.Comment
