Official Freewing 90mm Eurofighter Typhoon EDF Jet Thread
  • Alphonso
    • Aug 2020
    • 101
    • Hastings, UK
    Simply paint over the decals. I like to use a foam roller and then a quick rub with a 320 grit pad to get the original paint smoothness back .
    • kallend
      • 1877
      I just painted over the decals. Click image for larger version
        • 2709
        As did I. Painted over with a primer first, sanded, then the new base coat, graphics, and finished off with 4 coats clear exterior spar urethane.
        Just did another F4 and had to do the same. :triumph:
ID:	393528 Click image for larger version
ID:	393529 Click image for larger version
ID:	393530 Click image for larger version
        • ElCid
          • Oct 2017
          • 114
          So just finished rewiring my Typhoon (removed the control box) and it works like a champ. No canard movement on the roll axis like the full size, and my gear go down/up in 4.3 seconds, including the sequenced rear doors (closed > open > closed) (Down from 15 secs stock). Tomorrow will be all about setting up the control throws and CG and then its hope for a nice day between now and the New Year.
          And Hugh, I have Callie working on a custom scheme for me. it will be another few weeks and It should be NUTS.
          • SanExup
            • 912
            • Western Wy.
            kallend This is one of my favorite schemes for the eurofighter. Glad to see someone go for it with the black. It's classy and with the benefit of higher viz. Nice work!
            Well, Hugh's is high viz too. Hugh Wiedman Impressive execution as well. I know I've probably commented on it in the past but it looks fantastic!
            • ElCid
              • Oct 2017
              • 114
              Would any one care to share their High and Low rate throws? The book is calling for 43mm/35mm on the Elevator and that is visually terrifying especially when you consider the Canards as well. I know settings are very personal but looking for some validation of the book.
              Sequencer Nirvana
              • Fast N Light
                • Apr 2021
                • 117
                Developing some printed rims which go with Dave Brown low bounce tires... ODs are same as OEM. Nose wheel is a bit wider. Should improve scale appearance and durability with no weight penality. Click image for larger version  Name:	IMG_4305.jpg Views:	0 Size:	122.7 KB ID:	394493
                • kallend
                  • 1877
                  Wheel cover for the stock main wheels:
                  https://www.thingiverse.com/thing:5933759
                  • RCGeekMark
                    • Feb 2021
                    • 6
                    • Phoenix AZ
                    I just painted over the decals. Click image for larger version  Name:	348641801_258154730069907_2947346411920153415_n.jpg Views:	168 Size:	323.6 KB ID:	393507
                    Hi Kallend, your RAF Typhoon is fantastic! I've finished the top of the wings, but working on the Callie vertical stabilizer and the bottom of the wings feels a bit challenging. Aligning the vertical stabilizer is tricky, and dealing with all those angles, servos, bumps, and holes can be intimidating. I've accidentally cut into the foam, leading to some touch-up work on one side of the vertical stabilizer. Any tips, tricks, or advice for covering these parts? Thanks a bunch!
                    • kallend
                      • 1877
                      Just take it slowly and if necessary on the bottom of the wing, do it in pieces.
                      • Airguardian
                        Post Stall Svengali
                        • Aug 2020
                        • 1676
                        • Catalonia
                        Almost forgot to post... 41 pages later, 'habemus maiden'!
                        • Jon @ Two Bros RC
                          • Feb 2024
                          • 16
                          Got mine back up after the battery tray mod I did late last year. This is a still shot from next Saturday's "1 Year of Perfection" - easily the best jet of 2023 by far. I love the stock 6 cell setup - it's stupidly overpowered. I'm balancing about 55 to 60mm behind the wing marks. I decreased AS3X priority so the gyro overrides my stick inputs so that I can't overcontrol the jet - just like the full scale flight computer works. It's so nice like this.
                          • Airguardian
                            Post Stall Svengali
                            • Aug 2020
                            • 1676
                            • Catalonia
                            Bringing some aggressive scale flying... flying at this place often gives me Mach Loop vibes!
                              • 2709
                              Jon, do you mean 55-60mm behind the factory recommended balance point? My 8S is about 25mm behind that point and from the looks of your battery placement, I assume you're 55-60 mm behind the factory balance point. I have to remove some stuff and maybe even add some tail lead to get there, but judging on your flight videos, it seems to fly great there.
                              • Jon @ Two Bros RC
                                • Feb 2024
                                • 16
                                It's 55-60mm behind the marks with a small amount of weight as far back in the tail (under the rudder) as I can get it.
                                • Jon @ Two Bros RC
                                  • Feb 2024
                                  • 16
                                  Here's my year in review on Eurofighter:
                                    • 4857
                                    Jon @ Two Bros RC Great video review and debrief. Which Afterburner did you install. Love the Flicker. Best, Steve
                                    • Jon @ Two Bros RC
                                      • Feb 2024
                                      • 16
                                      https://kmrcmodel.com is what we use these days. They're priced really well and have an instant-on burner system that's fully customizable.
                                      • Airguardian
                                        Post Stall Svengali
                                        • Aug 2020
                                        • 1676
                                        • Catalonia
                                          • 4857
                                          Airguardian, Tremendous flight video. That's what I would call "Passing your Quals", Sir. Best, LB
