  • brrzee
    • Aug 2017
    • 48
    Janmb, stacking them in the aft position? Sorry not sure exactly what u meant by that. I am really trying to avoid moving the guts around. Thinking of taking some weight wrapping it in foam and lodging it behind the electronics and just keeping batteries in battery bays. Will have to keep playing. Guess thats one flaw of buying batteries other than recommended
      Because of my mods I had to stack my batteries like this. My other 90mm A-10 has the batts in the stock location.
      • janmb
        Slow and low
        • 729
        I am refering to what RCJetdude posted in his image: Having both batteries on top of each other in the aft battery bay. Doesn't require any mods other than a longer/extra strap.
        • brrzee
          • Aug 2017
          • 48
          Awesome awesome gentleman...i will try & go that route. Just tidy up the wiring around the batteries..where is your receiver. I see the speed controller taped to side of the fuse
          • Shogun
            Always Learning
            • Jun 2018
            • 16
            • Redlands, California
            One of my flying buddies found the little white V shaped nose gear spacer on the runway from my second flight Saturday. Didn't even notice it was gone. Guess I'll be gluing it back on....lol
            Also, probably a dumb question but why is the starboard gear nacelle nose painted black but the port side one is unpainted? The full-size A-10 pics Ive seen are varied--some have both painted, some have one, some have neither.--Any "purpose" to it?
            Jim
            • brrzee
              • Aug 2017
              • 48
              What type of batteries are those in the above posted pics
              • themudduck
                -TMD- Foaming at the Mouth!
                • 1041
                • Burton OH (near Cleveland)
                Jim
                The front of the unpainted port-side LG nacelle on the full-size A10 has a little door that opens, revealing the single-point fueling point under the door..
                The painted black part of the starboard LG nacelle also opens up, but I can't remember what's inside that door! And I used to know, so its bugging me.... :Thinking:
                  Those are Roaring Top 5800ma, 6S, 35C batteries. A gear door sequencer is just to the left of the upper battery and the receiver is servo taped to the opposite wall. Again, this is not a normal installation because behind the batteries is my powder canon and Shockwave2 sound board. The additional nose weight warranted stacking my batteries. My CG is between 80-85mm inverted with gear down. Balanced with my index fingers on the plastic wing roots. At one time this bird weighed in at a whopping 16lbs but I have since shed some weight. Around 14lbs. now. Flies great on the stock 80mm fans and 3D printed whistles in the nacelles give it a very realistic sound without the sound system. I hope Motion will have some video of it up soon from NEFI.
                    That is the home of the localizer glideslope antenna. They started painting that sponson tip satin black in 1992...
                    • bbaumer
                      • Jun 2017
                      • 152
                      • Indiana
                      Without searching a 430 page thread, what's a powder cannon?
                      • dahawk
                        Augermeister
                        • Jun 2013
                        • 1006
                        • Keller,Texas
                        Oohs and aah’s from Steve! Brrrrt!
                          Ignore the stuck nose gear. The sequencer has since been replaced.
                          • themudduck
                            • 1041
                            Woooooooooooooooooooooooooooooooooaaaah!!! Awesome!!! :Win::bluelove
                            • dahawk
                              Augermeister
                              • Jun 2013
                              • 1006
                              • Keller,Texas
                              I can watch that vid over and over.
                              • brrzee
                                • Aug 2017
                                • 48
                                RCjetdude did u have to remove the control board then to fit your batteries & all your other extras. If so where did mount it. Absolutely amazing job on your A10 by the way
                                Cheers
                                  Cheers
                                  Oh yes...it was a PITA but it worked.
                                  • brrzee
                                    • Aug 2017
                                    • 48
                                    Awesome pics RCJetdude thx..how did u balance it..wheels down right side up..or wheels up..upside down
                                      Wheels down inverted index fingers on the plastic wing roots is how I do mine.
                                      • Dirty Dee
                                        • 768
                                        • Northern Illinois
                                        https://www.thingiverse.com/thing:2988973
                                        Come and get em!
                                        • fhhuber
                                          • Aug 2015
                                          • 1476
                                          All of these upgrade parts to make with a 3D printer... You're going to make me buy a 3D printer.
