  • Hiddenhanger63
    • Oct 2020
    • 8
    oops
    • Hiddenhanger63
      • Oct 2020
      • 8
      Same here? Click image for larger version
Name:	freewing-a-10-thunderbolt-ii-super-scale-twin-80mm-edf-jet-pnp-motion-rc-2594314420273_1024x1024.jpg
ID:	278398Click image for larger version
Name:	freewing-a-10-thunderbolt-ii-super-scale-twin-80mm-edf-jet-pnp-motion-rc-2594302623793_1024x1024.jpg
ID:	278399Click image for larger version
Name:	freewing-a-10-thunderbolt-ii-super-scale-twin-80mm-edf-jet-pnp-motion-rc-2594300624945_1024x1024.jpg
        Yeah, those are old pictures and initially the gear door did go up after gear deployment. But then we pointed out to MRC that this was not scale so they changed the programming in the board to have the door remain open.
        • Hiddenhanger63
          • Oct 2020
          • 8
          Ohh ok I see now thanks, Although scale I would have preferred it to go up as it looks like it could easily catch longish grass if the standard or upgrade strut is fully compressed. Should be ok though. I have a trailing link strut from HK that is identical I believe to the upgrade one but the wheel hits the rear door when compressed is there a work around to the way the door is fastened or do people cut the door to clear the tyre?
          • bbolz
            • Mar 2019
            • 154
            Yeah i inquired to jetguy how he got his to close with the gear down. You unplug the nose gear and door from the controler and hook them up directly to your receiver. You then use the sequencing function in a 9dx or better tx. I couldnt get it sequenced right and gave up, but that will work. Just go to youtube on the spektrum sequncer and they explain how to set this up.
            • Hiddenhanger63
              • Oct 2020
              • 8
              Cheers that may be a easy option, I fly with a Horus and open TX so I know it can be done it just means a bit or research as to how to do it.
                • 8835
                Or ................... you can adapt a set of these to your A-10. It's from the new Mig29 and has a "second stage" gear door circuit (opens and closes the door before and after gear movement). You could plug only your nose gear and nose gear door into this board and "Y" your retract lead so both the stock board and this board get the signal. Which is more important - time spent to research how to do it with your TX or 22 bucks (+shipping)?
                • Hiddenhanger63
                  • Oct 2020
                  • 8
                  Thankfully with the open TX system your nearly guaranteed that someone has “been there and done it” 30 seconds google search comes up with all the settings and mixing needed with variable timers etc.
                  • ColtPilot
                    Hobby Squawk Advanced Pilot
                    • Jun 2015
                    • 538
                    • Saint Clair Shores, Mi
                    I guess this picture from motion there must be something non standard about it then?
                    Those were the first ones to come out. Many folks had the input saying what gives and was fixed. Also the penny pod is no longer used by the A-10's. As you can tell by my photo with the real deal it is no longer there. That's how it became the A-10C.
                    • Balsa Bob
                      • Sep 2020
                      • 59
                      • New Hampshire
                      About to start assembly of mine. I had read about strengthening/stiffening up the front of the fuselage with carbon fiber rods/tubes, one on each side. Is this a good idea ?
                      Bob
                      • ColtPilot
                        • Jun 2015
                        • 538
                        Bob
                        Yes, the addition will be beneficial. After 4 years I still need to do mine.
                          • 2716
                          This thread has been a little "quiet" lately with everyone exploding the MIG thread :bomb:​, but after almost a month after I finished the Arctic build, I finally finished (although still need to apply the clear gloss spar urethane to it) the Dirty Dee cockpit. Good thing I bought a second cockpit to work on so I was able to maiden the A-10 and get about 30 flights on it while I "occasionally" worked on the cockpit. Chris's design is absolutely fabulous and everything fits "like a glove" once you get the foam cut out correctly. This wasn't an easy rebuild (especially cutting out the correct amount of foam), but then again nothing is easy for me, and I want to thank Chris for his incredible design and others who helped me out immensely with the parts. I used a JH Hobby 1/10 scale full body pilot, same as what I put in the F-18 Canadian and he fit very nicely. The finished cockpit weighed in at 274 g, which is 170 g more than the plain stock cockpit. In order to keep my CG at 92 mm (which I felt made it perform the best for me), I had to move the 2 RT 6250 batteries back another 2 1/2 inches and move the battery straps and extend the floor under the forward battery. I had already removed the circuit board and velcro-ed it to the back port fuselage wall, but at this point, I can't get the CG any further back without going to lighter batteries, which ain't going to happen since I love the 5+ minutes of flight time coming in with 35% or more left in the tank. I know I'm repeating myself, but I love everything about this jet, which I would have never guessed even at the point that I finally purchased one! I initially thought that this might end up as a "hangar queen" but it just refuses to be left at home when I'm heading to the field. It easily replaced the Avanti as my first EDF flight of the day and the poor little Avanti hasn't been out in months.
ID:	279601Click image for larger version
ID:	279602Click image for larger version
ID:	279603Click image for larger version
ID:	279604Click image for larger version
ID:	279605Click image for larger version
ID:	279606Click image for larger version
                          • James
                            Administrator
                            • Aug 2017
                            • 1543
                            Looks great Hugh! Any pics of the entire plane finished?
                              • 2716
ID:	279621Click image for larger version
                                Fabulous work Hugh Wiedman ! Wish we lived close, we could have some pretty cool tandems!
                                • themudduck
                                  -TMD- Foaming at the Mouth!
                                  • 1041
                                  • Burton OH (near Cleveland)
                                  That is really spectacular work. I love those spirals on the fan cones.
                                  • Dirty Dee
                                    • 768
                                    • Northern Illinois
                                    Hugh Wiedman great work!
                                      • 2716
                                      Hey, what's 3000 miles or so among RC buddies? I'll be there shortly, leave on light on!
                                        Consider it done!
                                          • 2716
                                          ​​​​​​Got another 7 flights in today on the A-10 along with 4 on one of my F-4's. Every time I fly the A-10, it just seems to fly better each time, which at this point is almost impossible to get better unless I let a decent pilot take her up for me! Would have got more but these 2 burned through my 18 RT 6250's and I refuse to waste time at the field charging, and I'm not going to buy any more batteries, 140 are enough (man, just think how many more actual planes I could of had instead).
                                          Anyway, interesting observation here: I fly off grass so upgraded the nose to the trailing link. We had 14-18 mph winds directly down the runway, but neither of them seemed to give a hoot about gusty winds (thankfully not a crosswind though). With jets, I always start out the take-off run with full elevator to relieve pressure on the nose gear which helps it get up to speed quicker on grass, then slowly release elevator just before lift off leaving just enough up to lift off smoothly. Since we had a strong headwind, just to see what happened, I started a take-off run with NO up elevator. The result was that it drove the nose pressure down so much that about 1/2 way down the run, the trailing link was fully depressed. Started over with my normal take-off procedure and that ended that experiment!. The twin "exhaust " thrust is directly over the elevator surface (and if you test it out on the bench you can see and hear just how much thrust the elevators directly influence), that if you use full or even 1/2-3/4 up elevator on take off, it REALLY forces downward pressure on the tail, thus keeping the nose "light as a feather". Probably not needed as much on asphalt, but on grass, wow, what a difference.
                                          The other thing I noticed was that for landing, downwind around 28-32% throttle, final glide after lining up runway reduced to 15% and then 8%, and about 4 feet off the runway throttle to 0 and then raise the nose before touchdown gets just a perfect somewhat high alpha landing with 0 bounce (actually have never experienced the bucking bronco effect yet :fingers_crossed:) resulting in a 10-15 foot roll out, at least on grass. Never thought I'd ever chop the throttle on a jet, but this is not your "grandmothers" EDF. Noticed GliderGuy on a post in the Mig 29 thread with almost the exact throttle positions for landing, so these both seem to be a little different than some of the others being a bit larger and able to glide easier without dropping like the proverbial rock.
