  • Fast Eddie
    • Oct 2016
    • 119
    • So.Cal
    Custom livery...more to come.
    This picture you'll just have to figure it out...
    Rotating Beacon ?
    • Lon
      • Jul 2014
      • 1201
      • Miles, Iowa
      Maiden this morning!!
      Total of 10 flights on the A-10.
      Lon
      • Shirty
        Hobby Squawk Water Boy
        • 1067
        • Perth, Australia
        Grats Lon. Awesome.
          • 2137
          • On planet earth....right
          Looks like a great first flight to me :). Excellent job!
          • Pete Lane
            Turbine lover
            • 290
            • Los Gatos Cally
            Especially with no breeze. 23.4 V
            Nice !
              Originally posted by T-CAT
              Bingo :). Holding the elevator stick pressure is key. Most of the bucking bronco landings occur when the plane is slow (and sometimes not slow enough, but depends), the planes wheels touch the ground (sometimes not gently enough causing it to spring in the air) and the pilot completely relieves all elevator pressure as soon as wheels touch. Holding just enough of that back pressure on the elevator keeps a small amount of lift that gradually reduces as the airspeed continues to decrease while the plane is on the mains and nose gear, and lessens the chance of the jet oscillating up and down from rear to nose.
              I cut 3/8" off my nose strut spring which has helped with the bouncing.
              • downwindleg
                • 1279
                • Friday Harbor, Washington
                Great flight Lon, I do the same kind of breathing when I'm taking a plane up for the first time. Pegs the pucker meter for sure!! Hope mine goes as well. Amazing runway!!!!!! Brad
                  Woohooo! Another successful maiden. Keep em' coming. Congrats Lon. Nice job. I was initially nervous as well but once airborne it flew so well that it helped relax me so that by the end of the flight I was elated.
                    I modified the cockpit so you don't need to pull the latch pin back to close it...that bugged me :wacky
                    Click image for larger version  Name:	20170605_005115677_iOS.jpg Views:	1 Size:	93.8 KB ID:	79346
                    Click image for larger version  Name:	20170605_005738833_iOS.jpg Views:	1 Size:	72.5 KB ID:	79347
                    Click image for larger version  Name:	20170605_005705039_iOS.jpg Views:	1 Size:	64.6 KB ID:	79345
                    • Pete Lane
                      Turbine lover
                      • 290
                      • Los Gatos Cally
                      Self pushing. One handed.
                      Thanks !
                      Plane
                      • 1horse59
                        Don't shake much anymore
                        • 71
                        • Huntsville, AL
                        Congrats on your maiden Lon
                        • RCAV8R
                          Certified Plane Nut
                          • 355
                          • Medford, Oregon
                          Nicely done Lon! I I agree with Brad...that is an awesome field you guys have! Thanks everyone for your reports on your maidens...those of us in the second shipment group appreciate the input! Rob
                          • downwindleg
                            • 1279
                            Good mod TI, just like a door latch. What material did you use on the strike side? Brad
                              • 7325
                              Amazing flight, amazing plane amazing field and well, amazing pilot as well.
                              Diane and I both watched the maiden flight and rooted for you, great job!!
                              The one good thing about returning from Nefi is stopping by your field and seeing this place on person. Every time I see this field I drool !!
                                Good mod TI, lust like a door latch. What material did you use on the strike side? Brad
                                It's just a piece of plastic I cut from an old P-51 gear door, I cut it 5/8" longer than the stock one then heated it and bend it.
                                • dkalwishky
                                  Warbird Lover
                                  • Sep 2015
                                  • 1382
                                  • Des Moines, IA
                                  Originally posted by bill34207
                                  I'm planning to go with the FT scheme (backup plan, termites if I screw up the tigers) on mine so you are welcome to the Blacksnakes nose art from mine once it gets here.
                                  Thanks, let me know when your plane arrives and if I haven't secured them sooner I'll take you up on the offer.
                                    These are yours if you want them...
                                    • DCORSAIR
                                      • 1918
                                      • Selma, Ca.
                                      I will more than likely give up my Black Snakes decals as well when mine gets here, I don't like snakes and don't want one on the front of my A-10....:Scared::Scared:LOL....... Not sure which of the other two sets of decals I'm going to use yet so if someone needs the Black Snakes I will let them go for free of course, but let me get my A-10 first, looks like Tuesday is my delivery date.;)
                                      • dkalwishky
                                        Warbird Lover
                                        • Sep 2015
                                        • 1382
                                        • Des Moines, IA
                                        Awesome, I'll pm you my address.
                                        • WAY BAD
                                          • 69
                                          • Bossier City, LA USA
                                          If anyone has a set of the Termite liveries they would like to sell, I wouldn't mind picking up some.
                                          This will be the first time I've done water slides since I was a kid, so I can only imagine what it's going to be like trying to do them on this bad boy.
