  • TSHobbies
    Hobby Squawk Warbird Pilot
    • Nov 2015
    • 671
    • Cartersville GA
    ok, good to know..I must not have the elevator set right in neutral then. I'll adjust that and try it out next time.
    www.TSHobbies.com
    • ColtPilot
      Hobby Squawk Advanced Pilot
      • Jun 2015
      • 538
      • Saint Clair Shores, Mi
      Looking good! That purple table really makes it popLOL:Cool:
      My wife loves purple, everything is purple.:)
        • 2137
        • On planet earth....right
        Work in progress. Just finished painting the fuse. Darn tape pulled some paint off. Will have to get some touch up gray.
        Very nice! Looks like a clean paint job and should be better for orientation too.
          • 2137
          I noticed the APU exhaust ports didn't come with a decal to cover up the gray, but the outline in the foam mold is there on the aircraft. I have a small label maker, so I printed some circles to stick on to the area. I could have painted it, but figured this would take less time and it did, ha-ha. I also printed out the star for the left wing main gear pod on the front tip. The star I used is already cut out, but I made a lot in different sizes to test out, which one I liked more, and was more appropriate for scale proportions.
ID:	84502Click image for larger version
            • 2137
            It's great seeing all the pictures and video of everyone's flights. There's a lot of amazing paints job people are accomplishing on this jet.
            • Sky Wolf
              Flying Ant
              • Sep 2013
              • 731
              • Irving, Texas
              Originally posted by GTiR1080
              I even tried mine out of the plane sitting flat on the table with just a single servo in it and it still didn't work.
              There must be some sort of trick to this receiver? Will reach out to HH again.
              • Sky Wolf
                Flying Ant
                • Sep 2013
                • 731
                • Irving, Texas
                Originally posted by Patrnflyr
                A friend of mine flies his with this receiver and no problems at all
                Then your "friend" must inow the secret. Can you ask your "friend"if f he knows what the problem might be.
                • Nitromag57
                  • Jun 2017
                  • 9
                  • Quad cities Iowa
                  a10 pnp sold out!!!!
                  • t33jetman
                    • 515
                    My trick for pulling the tape off, is to use a heat gun set on low and warm the tape as I pull it off at 180 degrees direction , making sure not to be too close or too long on one spot.
                    When I'm done painting my A-10 I will show you the results.
                    • Nucastle
                      • 17
                      What color Grey and Green did you use?
                      • 401 FOOT CEILING
                        I need 5 gallons of prop wash, please.
                        • Jun 2017
                        • 42
                        • West Linn, Oregon
                        FYI...if anyone needs flight batteries, some just showed up in stock at MRC!
                        • 401 FOOT CEILING
                          • Jun 2017
                          • 42
                          • West Linn, Oregon
                          If anyone needs to touch-up the top (bluish) paint on the FW A-10, may I suggest Tamiya XF-19 Sky Gray, XF-8 Flat Blue and XF-2 Flat White. Will take a little experimentation. Only use a very, very tiny amount of blue and lighten with white to match what YOUR eye sees.
                          • TomPatton
                            XNitroJunkie
                            • 279
                            • Elida Ohio
                            I just bought 6... Damn, there goes the grocery money for this week...lol...
                            • 401 FOOT CEILING
                              • Jun 2017
                              • 42
                              • West Linn, Oregon
                              Well I bought two, 6s and two 3s, so need to lose over 1800 grams of fat just to get back down to my "flying" weight!
                              • TSHobbies
                                • Nov 2015
                                • 671
                                • Cartersville GA
                                lol, I bought 3 more, that'll give me an even number now. $600 bucks in groceries? lol thats alot of Ramen noodles!
                                www.TSHobbies.com
                                • 401 FOOT CEILING
                                  • Jun 2017
                                  • 42
                                  • West Linn, Oregon
                                  $600, huh...he who hesitates is lost! If I had your money, though...I'd burn mine!
                                  • Fast Eddie
                                    • Oct 2016
                                    • 119
                                    • So.Cal
                                    A little more work on the cockpit. I know the scratch built ejection seat is a little too wide. Almost Lazy Boy recliner size, but good enough for me. Mainly, I just wanted a moving pilot head..
                                    • 401 FOOT CEILING
                                      • Jun 2017
                                      • 42
                                      • West Linn, Oregon
                                      I likes it!
                                      Good puppy, too.
                                      • Thomas W
                                        • 54
                                        • Indianapolis, In.
                                        For the guys that are using the nerf whistles, are you using 4 (2 in each pod) or 2 whistles (1 set in 1 pod)?
                                          That is really good! Can you make him salute too? :)
