  • ok, good to know..I must not have the elevator set right in neutral then. I'll adjust that and try it out next time.
    www.TSHobbies.com
    • Originally posted by Twowingtj View Post
      Looking good! That purple table really makes it popLOL:Cool:
      My wife loves purple, everything is purple.:)
      • Originally posted by ColtPilot View Post
        Work in progress. Just finished painting the fuse. Darn tape pulled some paint off. Will have to get some touch up gray.
        Very nice! Looks like a clean paint job and should be better for orientation too.
        • I noticed the APU exhaust ports didn't come with a decal to cover up the gray, but the outline in the foam mold is there on the aircraft. I have a small label maker, so I printed some circles to stick on to the area. I could have painted it, but figured this would take less time and it did, ha-ha. I also printed out the star for the left wing main gear pod on the front tip. The star I used is already cut out, but I made a lot in different sizes to test out, which one I liked more, and was more appropriate for scale proportions.
ID:	84502Click image for larger version
          • It's great seeing all the pictures and video of everyone's flights. There's a lot of amazing paints job people are accomplishing on this jet.
            • Originally posted by GTiR1080 View Post
              I even tried mine out of the plane sitting flat on the table with just a single servo in it and it still didn't work.
              There must be some sort of trick to this receiver? Will reach out to HH again.
              • Originally posted by Patrnflyr View Post
                A friend of mine flies his with this receiver and no problems at all
                Then your "friend" must inow the secret. Can you ask your "friend"if f he knows what the problem might be.
                • a10 pnp sold out!!!!
                    My trick for pulling the tape off, is to use a heat gun set on low and warm the tape as I pull it off at 180 degrees direction , making sure not to be too close or too long on one spot.
                    When I'm done painting my A-10 I will show you the results.
                      What color Grey and Green did you use?
                      • FYI...if anyone needs flight batteries, some just showed up in stock at MRC!
                        • If anyone needs to touch-up the top (bluish) paint on the FW A-10, may I suggest Tamiya XF-19 Sky Gray, XF-8 Flat Blue and XF-2 Flat White. Will take a little experimentation. Only use a very, very tiny amount of blue and lighten with white to match what YOUR eye sees.
                          • Originally posted by 401 FOOT CEILING View Post
                            I just bought 6... Damn, there goes the grocery money for this week...lol...
                            • Originally posted by TomPatton View Post
                              Well I bought two, 6s and two 3s, so need to lose over 1800 grams of fat just to get back down to my "flying" weight!
                              • lol, I bought 3 more, that'll give me an even number now. $600 bucks in groceries? lol thats alot of Ramen noodles!
                                www.TSHobbies.com
                                • Originally posted by TSHobbies View Post
                                  $600, huh...he who hesitates is lost! If I had your money, though...I'd burn mine!
                                  • A little more work on the cockpit. I know the scratch built ejection seat is a little too wide. Almost Lazy Boy recliner size, but good enough for me. Mainly, I just wanted a moving pilot head..
                                    • Originally posted by Fast Eddie View Post
                                      I likes it!
                                      Good puppy, too.
                                      • For the guys that are using the nerf whistles, are you using 4 (2 in each pod) or 2 whistles (1 set in 1 pod)?
                                          That is really good! Can you make him salute too? :)
