ok, good to know..I must not have the elevator set right in neutral then. I'll adjust that and try it out next time.
I noticed the APU exhaust ports didn't come with a decal to cover up the gray, but the outline in the foam mold is there on the aircraft. I have a small label maker, so I printed some circles to stick on to the area. I could have painted it, but figured this would take less time and it did, ha-ha. I also printed out the star for the left wing main gear pod on the front tip. The star I used is already cut out, but I made a lot in different sizes to test out, which one I liked more, and was more appropriate for scale proportions.
My trick for pulling the tape off, is to use a heat gun set on low and warm the tape as I pull it off at 180 degrees direction , making sure not to be too close or too long on one spot.Originally posted by ColtPilot View PostWork in progress. Just finished painting the fuse. Darn tape pulled some paint off. Will have to get some touch up gray.
When I'm done painting my A-10 I will show you the results.BVM Bandit, EFlite Carbon Z T-28, EFlite Carbon Z Cub, EFlite Promethus, FW Avanti S, FW A-10 ThunderBolt, FW P-51 Mustang, EFlite Convergance, EFlite Carbon Z Cessna 150, EFlite Habu, EFlite Styker Q-F27, HSD Navy Super Viper
I likes it!Originally posted by Fast Eddie View PostA little more work on the cockpit. I know the scratch built ejection seat is a little too wide. Almost Lazy Boy recliner size, but good enough for me. Mainly, I just wanted a moving pilot head..
Good puppy, too.
That is really good! Can you make him salute too? :)Originally posted by Fast Eddie View PostA little more work on the cockpit. I know the scratch built ejection seat is a little too wide. Almost Lazy Boy recliner size, but good enough for me. Mainly, I just wanted a moving pilot head..
