Originally posted by RMatteson
View Post
could be the 12 bladed fan alsoOriginally posted by C17loadmasterThe stock setup isn’t terrible if you use smaller batteries. Anything above a 4000mah I would use the Freewing 2210 Inrunner. It’s the version of FW EDFs. If you want your flight time to stay around stock just use less throttle. The newest FW version is roughly the same weight as the old version but creates a lot more thrust.
If you spend most of your time at half throttle the FMS set up will suit you really well. You will get a significant increase in performance over the stock. Stock you need to use 3/4 power and a lot of momentum to keep this thing in the air. With the FMS it will get off the ground sooner and land slower. It will just be much lighter flying than stock. Your flight times will be a little bit over what you get with stock as well. With my F-104 I gained about a min flight time on a 5000mah pack.Originally posted by RMatteson View PostI just bought a TB ARF F-16 and would like some input as to a EDF unit for it. My objective is to find a unit to give the good take off speed on a geotex runway about 325 foot long with grass on the ends of it. I want to use 6s power. I have a almost new FW 12 blade 1550kv and 130amp esc set up which would be stock power. I also have looked at the FW 90mm 4068 in runner and the FMS 12 blade 1900kv out runner. The FMS unit is the lightest and the FW IR is the heaviest, with the stock in the middle. I'm assuming that the FMS edf is all composite? With the heavier weight in runner because of motor. Look I want a good flying plane, but don't care how much vertical it has, but rather good cruising scale speed at 1/2 or so power to have fun my way. I have read the threads, with some saying stock power is fine, and others saying it needs all the power it can get. I have 2 FW 70mm F-16s, one gray and one camo but wanted the 90mm TB scheme as well. So should I go stock or get one of the higher power fans? Thanks for your help.
RickCheck me out on youtube at https://www.youtube.com/user/gooniac33
It was only my second jet... my first was the 80mm F-86. It wasn’t bad on the maiden until landing. The CG in the manual is way too aft in my opinion. It made it down safely but I went around more than once on approach. I watched the MotionRC Video of Pilot Ryan flying it and copied his battery location. After that it was awesome. I have never crashed mine, and it has been flown a lotOriginally posted by slingshot View Postmaybe she will just be a hanger queen. beautiful looking jet.
I've heard anywhere from 115mm-125mm. Where did you end up at?Originally posted by C17loadmaster View Post
Honestly, I can’t remember. I drew a line where the battery should be placed for my preferred CG. I have over 20 planes that are flight ready, so I had to start marking them to save myself from having to break out the CG stand all the time. I put my 5000mah lipo in the same spot as this image and it worked perfectly. The manual had the lipo about an in inch aft and it was a handful. When I moved the CG forward landing became a breeze. I use a gyro on landings and takeoffs and I use flaperons and tailerons. The tailerons are set to activate when the flap switch is set for half or full flaps.Originally posted by Ks.jetflyer View Post
Also, I’m using a Spektrum IX 12, so if anyone wants the file I can send it to them.
Any idea what your batt weighs? I have different brands and weights of 5000mah. thanksOriginally posted by C17loadmaster View Post
I have flown it with 4, 5, and 6000mah packs. The picture is with a 5000mah pack weighing 725g/ 25.57oz/1.6lb. The CG envelope is pretty forgiving on this plane. The lighter the lipo, the better it will fly... the 6000mah made it fly like a rock with no additional flight time.
Here is a video with the FMS fan and YeP 150. I’m using a Admiral Pro 60c 4000mah. It’s my only “crash” on this plane. It’s definitely one of the stronger Freewing jets. There are no structural weak spots prone to damage that I can find. The aluminum NLG has bent a few times. Especially after this great landing.
I've got hundreds of flights on mine and I like the CG around 118mm, seems to be the best for landings anyway, little nose heavy but flies great, in fact I just bought another F-16 ThunderBird, also going to try out the new FW 4068-1835kv inrunner in it, love the F-16, never get tired of flying one, will always have one in my hanger, or two.1 Photo
- Likes 2
If you don't have one already, get one, they fly great. I enjoy flying the F-16 better than any of my other EDF jets, those slow high alpha passes with the gear down are so scale looking and then adding power and pull the gear up are a thing of beauty, those high alpha landings are great to, they do take practice but once you get them down it becomes so easy to do.Originally posted by purduephigam View PostAll this talk is giving me the itch. F16 is one of my favorites.
So you want one yet?:):)
Mulling it over and looking for excuses/justification to purchase. Do people enjoy the stock setup, or recommend the upgraded inrunner? I love the scale military version but seem to be more tempted by the Thunderbird scheme. Either way, just wanted to get everyone's thought on the power setup.
I highly recommend getting Arf+ and putting in the FMS 90mm fan and the YEP 150A ESC. It lightens the airplane significantly, while also providing increased thrust, and longer flight time.Originally posted by purduephigam View PostMulling it over and looking for excuses/justification to purchase. Do people enjoy the stock setup, or recommend the upgraded inrunner? I love the scale military version but seem to be more tempted by the Thunderbird scheme. Either way, just wanted to get everyone's thought on the power setup.
Did you watch the link I posted of the FMS/YeP combo? It’s awesome! My YouTube channel has the video of the maiden as well. The difference in takeoff roll is incredibleOriginally posted by purduephigam View PostMulling it over and looking for excuses/justification to purchase. Do people enjoy the stock setup, or recommend the upgraded inrunner? I love the scale military version but seem to be more tempted by the Thunderbird scheme. Either way, just wanted to get everyone's thought on the power setup.
