  • Russ
    EDF Enthusiast
    • 63
    • Houston, Texas
    Yes she flies like on rails. I land with high alpha attitude and full flaps for a less long rollout but it is very long without full flaps. The only problem is heavy cross winds where I often get a wingtip drag cos that big rudder gets pushed around. I just put wingtip skids on and no problem.
    • Russ
      EDF Enthusiast
      • 63
      • Houston, Texas
      Originally posted by roys001
      I've had My F-86 for about a month. I'm running the 6s 5000mah battery. Carving out the canopy was not a problem. For me however My flight times seem to be limited to 3 minutes. The plane flys great. Like already mentioned wind is just not an issue. I've started practicing a steeper approach angle with flaps in light winds and I'm getting some nice squeaker landings. I have noticed though that the tires are getting flat spots on them. I'm wondering if anyone else is having that problem?
      Most probably your lipo battery. I know several people with this plane and all get AT LEAST 4 full minutes of mixed flying on 6S-5000's. One guy gets 3.5 minutes on a 4000 so all other things being equal, it leaves the battery. Taking off ordinance will also help a bit. Also, I have two 6S-5000 lipos from two different makers and I never had to carve any foam. I just dropped the ESC down in the air stream and put the battery all the way back in the compartment and all fits well. I even have a 130 amp ESC in mine when I upgraded to FMS 3270-2000 motor/fan combo.
      • Kokopellimusic
        Hobby Squawk Newbie
        • 55
        • Nashville, Tennessee
ID:	182224 I moved my ESC below the balsa deck. It made a lot of difference in battery placement. I’m only getting around 3:00 to 3:15 as well. That’s with the drop tanks. I will take them off and see if that helps some.
        • Kokopellimusic
          Hobby Squawk Newbie
          • 55
          Did you have to do any carving to change out the motor to the FMS? I've read that's a great combo on this jet.
          • Russ
            EDF Enthusiast
            • 63
            • Houston, Texas
            It took me only one evening, I don’t remember the details now but it was very minor and really just a drop in. Really noticeable upgrade, 15% more power I would guess. Sound is as good or better too. I did have to rearrange for the bigger esc but it all worked with no big mods.
            • Ron1950
              Retired ATC
              • Oct 2015
              • 887
              • brandon ms
              the fms 2000kv fan and a freewing 100a esc in mine really made a difference...batteries and esc come in barley warm after 3 to 4 min highly recommend it...you do need to cut a slight bit of foam at the rear of the fan housing...very little easy install...make sure u get the 100a or bigger esc..
              • gooniac33
                The Original Gooniac
                • Jun 2016
                • 1047
                very minor foam removal but huge upgrade in performance!!
                • Helmsman52
                  • 247
                  • Saint Paul, MN
                  I have a set of used retracts laying around in great condition, I painted the hubs. If anyone needs them... just pay for shipping.
                  Thanks,
                  Paul
                  • Ks.jetflyer
                    • 131
                    Thanks,
                    Paul
                    Sent you a pm
                    • Kokopellimusic
                      Hobby Squawk Newbie
                      • 55
                      Hey guys, have any of you found a good silver paint match for touch ups? Thanks.
                      • theoldALFER
                        Taildragger Pilot
                        • Jun 2017
                        • 163
                        • Cape Coral, Florida
                        I’ve used these Krylon premium metallic paint that I got at Michael’s. I’ve had good results on Natural Metal finish aircraft. Should work well on the F 86 - which I have yet to unbox. :Silly:
                        Hope that helps you.
                        • Lon
                          • Jul 2014
                          • 1201
                          • Miles, Iowa
                          The Tamiya chrome silver X-11 is a good match for me. Click image for larger version
                          Lon
                          • flyinhigh042
                            • Dec 2018
                            • 100
                            Hey everyone. Admittedly, I’m being a little lazy here. Rather than researching and reading 21 pages in this forum, I’m wondering if anyone has flown the F 86 with the Admiral 5000 6S pack? Is it too heavy? Or will it work? Thanks for the input!
                            • Kokopellimusic
                              Hobby Squawk Newbie
                              • 55
                              I have not but I have flown mine with the RC Jetwerks 5300 60c and it flew fine but it was a little heavy. I think the Admiral 4500’s work well.
                              • Russ
                                EDF Enthusiast
                                • 63
                                • Houston, Texas
                                Yes, I fly with Admiral 6S-5000 and it's made for this jet...nice power, 4 full minutes of mixed flying.
                                • Phantom
                                  • Mar 2019
                                  • 504
                                  • M.D.
                                  I have flown it with a CHNL 6s 6000mah 70c battery. Trust me that's a big battery, 4.5 to 5 minutes of flight time. Lands a wee bit faster but still easy to grease her on, it's the only time I land with power on for this bird, unless winds dictate otherwise I usually land power off.
                                  • DCORSAIR
                                    • 1918
                                    • Selma, Ca.
                                    Shouldn't be a problem I would think, I fly mine all the time with Gensace 5000 60c pks, it handles it just fine, I fly a little nose neavy anyway on all my jets so it flies just fine and lands like a trainer, I can grease it right in on the mains with the drop tanks on.:Cool:
                                    • flyinhigh042
                                      • Dec 2018
                                      • 100
                                      Thanks to all for the battery info. I do appreciate it. Looks like I need an F-86 in the hanger... ;-)
                                      • Phantom
                                        • Mar 2019
                                        • 504
                                        • M.D.
                                        I'd like a little more speed for fluid aerobatics I've got a few FW power systems to include a 6 blade and 9 bladed fan. Has anyone had success using another FW power system set up in their F-86. Keep in mind I've been flying this one since about 2015 stock so not sure if they upgraded the power system for the ones they sell now...:Confused:
                                        • Ron1950
                                          Retired ATC
                                          • Oct 2015
                                          • 887
                                          • brandon ms
                                          first flight on the 2100kv fan tomorrow...hope I got that darn fan back on right lol ill let ya know if I think its faster then the 2000kv fan
