I upgraded the main wheels to the Robart 3.5", which helps, but the Corsair needs to be flown down for landing, it will not float in and flare. I still use full flaps on landing, actually even more than recommended, at 50 degrees (anything over 45 degrees and the flaps no longer create lift, just drag) only because I like the way it looks with max flaps at landing. My approach is at 40% throttle until I'm 1 foot off the runway, then only reduce it to 32% throttle and inch it down, staying perfectly level, as the mains touch, then slowly reduce throttle till the tail drops. If you try to land slower, the nose will be slightly up and it WILL bounce. You can not do a decent 3 point landing with the Corsair and you must keep it level and the tail up when landing. Once you do that a couple of times, it will seem like the Corsair is one of the smoothest landing warbirds there is. Took me some 20 flights to figure it out, but once I did, no problem. The Spitfire only needs to land, for me anyway, with 25% throttle when the mains hit, as it floats much more than the Corsair.
I also have a bit of down trim with full flaps on landing to keep the nose down, as it is easier for me to give it slight back pressure on landing to keep it level, than have to actually give it down elevator, which would work fine but that just is counter to the way my brain thinks on landing, especially since I fly a lot of EDF's that need the nose way up on landing.
.png)
Like Hugh, I use full flaps (full deflection) which only makes drag and helps slow the plane down - and so you definitely need to keep power on to drive it in. We are both using the same battery (RT6250) which is about the same weight as the Admiral 5000, all the way forward.
I thought I would do a little dressing-up of the OEM cockpit and why I also figured it wouldn't take much time, I do not know. In any event I have a new rear bulkhead, modified OEM pilot seat, new side panels (I will add the detail parts in pieces rather than print an all-in-one), and v2 of an IP Shroud on the printer. Foam surgery is the slowest part for me, ..'to cut or not to cut. that is the question', but in the end (as always) it always seems like why did I even sweat it in the first place?
