    • 8223
    Originally posted by theoldALFER
    Anyone know what page the detailed engine cowl resides? :pop
    F4U-1D Cowl
    F4U-1A Cowl
    • themudduck
      -TMD- Foaming at the Mouth!
      • 1041
      • Burton OH (near Cleveland)
      I'm pretty sure that's the same part, just painted in the two versions.
      I ordered an extra one for $5 for my D.. I figure I can play with it and try repainting the inside, adding some detail to the cylinders, etc. Making this thing removable was a really nice touch by MRC.
        Ben has suffered an incredible loss of all his birds and supplies in his garage. He has helped us out many times, so lets help him!!! I am in for a 200.00 gift card! Who is with me??
        :Cool:
        Shutting doors and leaving.
        Today, 08:36 PM
        So last week my garage caved in during the -50 cold snap we had for a week in WI. I lost all my foam birds except the 1600 spit that I had in the house. A plane which I hate by the way. Insurance adjuster came today and of course none of the dozen birds I had are covered. So I have nothing to fly except this plane which I hate for more than one reason. Coupled with the fact that I was hoping to get into the new corsair and I see the price just went up 60 bucks. I am shutting it down. I have been priced out of the hobby and cant afford to rebuild my stable at all. This happened to me in Pinball to when all the yuppies came. The last batch of pilots are at my house for Todd and Dave and then thats that. I cant afford this anymore and its just to depressing to stick around. I am just defeated and crushed not only by the loss of my stuff but by the fact that I can no longer pay 460 bucks for a plane anymore. I have been with Motion almost since the beginning but I gotta call it.
        Later folks!
        AMA 1102566
        Tags: None
        • theoldALFER
          Taildragger Pilot
          • Jun 2017
          • 163
          • Cape Coral, Florida
          Sorry. What I meant is that one of our fellow “contributor “ posted pictures of how he upgraded the cowl usin some electric wire etc.
          cant seem to find :Confused:
          • sethscorsair
            • Jan 2019
            • 63
            • Georgia
            How much does one lead ballast weigh?
              20 grams. Just FYI, they are steel, so lead will be denser and heavier if necessary. They are about 12mm in diameter and 20.5mm in length....
                Ole-Timer posted that data. Trying to find the post for you now....
                  Originally posted by fastphil
                  Added a little more weight up front in the F4-U using some flat weights I had on the workbench,... ended-up with three pieces to get the CG I was looking for, and they fit right behind the cylinders with a little hot glue ( I wouldn't doubt a big 45 slug would fit into the weight holes)
                  The weight is 12.5mm, so it is 50 cal!!! LOL I bet the .45 would work just fine!! 230 grain!! :-)
                  • theoldALFER
                    Taildragger Pilot
                    • Jun 2017
                    • 163
                    U Texans r all rite!
                    • sethscorsair
                      • Jan 2019
                      • 63
                      • Georgia
                      Ok thanks hardway im just guessing that my 5200mah pack weighs 759 grams according to the place i bought it https://www.amazon.com/Zeee-Batterie...s+lipo+battery and my other lipo is 4500 mah https://hobbyking.com/en_us/zippy-co...xoCgjcQAvD_BwE probably weighs about 700 grams so i will try taping 2 of them to the zippy and see where that gets me for that one. I was going to get matching pair but the zippy was on sale.
                      • downwindleg
                        • 1279
                        • Friday Harbor, Washington
                        Originally posted by redbarn
                        Anyone got a good idea for guns on this thing?
                        The Mr. Sound system does the sound of the engine controlled by the throttle and guns plus an option for sequenced led lights if memory serves. I think you can get it from MRC.
                        • Ole-Timer
                          Warbird Enthusiast
                          • Dec 2017
                          • 344
                          • New Brighton, PA
                          Originally posted by Ole-Timer
ID:	174523Click image for larger version
ID:	174521Click image for larger version
                          Alfer, post 833
                          • Ole-Timer
                            Warbird Enthusiast
                            • Dec 2017
                            • 344
                            • New Brighton, PA
                            I used 3/16 aluminum tube filled with sand n bent, 14 gauge copper wire for the ignition wire harness. 44 1/16 holes had to be drilled to accommodate all the wires.
                            Everything fit so snug it probably didn’t need the epoxy on the backside...
                            Not perfect but at 70mph it’ll do.
                            Sorry, no 3D files here. :)
                            Click image for larger version Name:	661AE36C-4722-4582-880D-35A3464172E9.jpeg Views:	1 Size:	150.3 KB ID:	174544Click image for larger version Name:	E738BE7A-0ACC-4F32-AC1C-FE55AFA8098A.jpeg Views:	1 Size:	128.7 KB ID:	174543Click image for larger version Name:	45245E88-DF6C-4EFA-8DDE-5E1E21723282.jpeg Views:	2 Size:	114.3 KB ID:	174545 Click image for larger version Name:	CA349BCD-A52F-4730-A5DE-C9DBA390BB90.jpeg Views:	2 Size:	136.6 KB ID:	174547
                            And this one
                            • Ole-Timer
                              Warbird Enthusiast
                              • Dec 2017
                              • 344
                              • New Brighton, PA
                              I simply used what I had on hand. Didn’t spend any extra...
                              Posts 833 on page 42 and 842 on pg 43
                              • theoldALFER
                                Taildragger Pilot
                                • Jun 2017
                                • 163
                                Thanks OT
                                :Cool:
                                • themudduck
                                  • 1041
                                  Detail, details.
                                  Has anyone else noticed that the model is missing a Pitot tube on the left wing? We need to add that. Maybe a 3D part?
                                  Also, from the Corsairs I have seen, the "step" in the right-side inboard flap is a hole that goes all the way through.
                                  Easy to see in this pic of a F-4U I took a few years back at an airshow.
                                  This bird has blue legs!
                                  I haven't decided whether I should cut the flap step out on the model. What do you guys think? Maybe this was only on later models?
                                  Click image for larger version  Name:	F4U-4_Bu97388_front_view[1].jpg Views:	1 Size:	87.8 KB ID:	177484
                                  • Grover54
                                    Going Weightless
                                    • Jan 2019
                                    • 319
                                    • Seattle Area (Redmond)
                                    :Cool:
                                    Today, 08:36 PM
                                    Later folks!
                                    AMA 1102566
                                    Tags: None
                                    Why won't his insurance company cover the damage????? Sure would like to know who the Insurance Company was to avoid them. So sorry this happened.
                                    • paladin
                                      model customizer since 1968
                                      • 243
                                      Very cool site but the minimum pricing bracket is $400 bucks...Hard to imagine shelling out nearly the same price for a cockpit kit as the plane itself! LOL :Scared::Thinking::Crying:
                                      ah, but you looked! and were thinking we could take orders and when we reach the min have them made. weren't you?:)
                                      Joe
                                        I don't know. Tom from Motion is going to get Ben receipts for the planes purchased from MRC to try and get the insurance to cover them. Check out the thread in the Lounge and let Ben know you are thinking of him. We have almost 360.00 in pledges so far for a new Corsair!!! :Cool:
                                        https://www.hobbysquawk.com/forum/th...rs-and-leaving
                                        By the way Grover, Ben is AkumaZeto from the Pilot Paint Service on this forum....
                                        • Grover54
                                          Going Weightless
                                          • Jan 2019
                                          • 319
                                          Detail, details.
                                          Good Catch. No I didn't notice it. My eyes were still swirling from the "New Box Smell". LOLLOLLOL 3D part sounds good but I bet one could fashion something pretty scale from their spare parts and "stuff" bin.
