  • downwindleg
    • 1279
    • Friday Harbor, Washington
    Could we possibly get back to the Corsair instead of seeing how many times I and other "scale nuts" can go into the dunk tank?LOLLOL
    • MikeT
      Here......Hold my beer.
      • 1060
      Originally posted by brk6188
      Obviously I am so old that I still think $500 is more than just pocket money.
      I remember putting in over a grand ( in 80's money) in every 60 size Top Flight warbird I built. Makes that $500 hobby expense on anything a bit easier to deal with
      Mike
      • theoldALFER
        Taildragger Pilot
        • Jun 2017
        • 163
        • Cape Coral, Florida
        :pop
        Scale Police Alert:
        Vought Salmon Primer: Apple Barrel 21470E Ripe Tomaro (WalMart $.50)
        Vought Cockpit Green: 2parts Tamiya XF-67 NATO Green + 1 part Tamaya XF-61 Dark Green (acrylics)
        Compaired to available photos, looks good to these Mark 1 eyeballs.
        • theoldALFER
          Taildragger Pilot
          • Jun 2017
          • 163
          See my post above (2283)...:Cool:
            Originally posted by theoldALFER
            :pop
            Scale Police Alert:
            Good job, for a backward prop running old dude!!!!! ;):Cool::Cool::Cool::Cool::Cool: Oh hell!! I just described myself!!!!!!!!!!! LOL Jerry
              :P:P:P:P:):):)
              • Grover54
                Going Weightless
                • Jan 2019
                • 319
                • Seattle Area (Redmond)
                Speaking of the FL Corsair 5055 340Kv motor.... Though currently out of stock I'm disappointed it doesn't come with the appropriate parts - "X" motor mount, attaching screws (pic 1) and prop adapter (pic 2). Though the attaching screws are no big deal (you can find them at any HW store) the motor mount is unique. In addition, the motor is also unique in that the face has the four (4) screw holes the prop adapter (pic 2) with the "HEX" head attaches and it's an extra part to buy. The "Prop Holder/Spinner" (Pic 4) has a 12mm recessed HEX (pic 3) to slide over the HEX on the prop adapter. So my point is you need more than just the motor; you need the prop adapter, prop holder (3 or 4 blade) and the "X" motor mount + screws. I wish MRC would bundle all the required parts and price accordingly instead of piece milling it OR be more clear of the various parts you need and disclose you need to purchase those extra parts. Customer Service explained they assume you'll use the existing X motor mount and prop adapter for the replacement motor??!! If you're replacing the motor it's for a reason and most likely all those extra parts are also needed. Just saying :)
                Click image for larger version  Name:	FL 5055 340Kv Motor.jpg Views:	0 Size:	61.9 KB ID:	187005Click image for larger version  Name:	FMS Prop Adapter 2a.jpg Views:	0 Size:	95.1 KB ID:	187006Click image for larger version  Name:	Prop Setup 3.JPG Views:	0 Size:	91.8 KB ID:	187007 Click image for larger version
Name:	FMS 4 Blade Prop Hub.jpg
                  • 8795
                  Sorry, I must have missed your post about this. What happened to your original motor?
                  On my FMS 1700mm Corsair, when I upgraded the motor from the 300kv to their 360kv motor for more grunt, it was easy since I could re-use the existing other parts. However, had I gone with a much more powerful, faster motor like this one, it all came as a complete collection of everything needed to do a transplant.
                  https://www.ebay.com/itm/5065-380kv-...p2047675.l2557
                  So, yes, it would be nice if these things could be packaged together but I can see where they don't want to do this for those who can use the old parts. Personally, I don't like paying for parts that I won't use. On the other hand, when I did the upgrade for my P-51 Mustang from the stock 4s motor to a 6s motor, I had to do the same thing and get all the little pieces separately.
                  • Grover54
                    Going Weightless
                    • Jan 2019
                    • 319
                    Actually, me too. I purchased the 5060 300Kv FMS used in their 1600mm Corsair for my H9 P51D 20cc because I wanted a 4-blade prop and I really like the "encased" prop holder with the recessed 12mm "HEX" head. For $86 I thought I would get all the parts but now I see I could have purchased the 380Kv for about 1/2. What 5065 380Kv did you buy? Did it have the "HEX" head on the prop adapter? Lesson learned - Need to ask before I solo all the research.:Silly:
                    • Grover54
                      Going Weightless
                      • Jan 2019
                      • 319
                      XViper - Have any suggestions as to where I can find a 4-blade, 95mm (3.7") spinner? I've looked everywhere and No Joy. I heard about True Turn as an option but they won't even kiss me first for the price. How hard would it be to carefully modify my existing 2-blade spinner to a 4-blade? There's plenty of room to do it and I've heard others say they've done it if you balance it properly or is that an absolute No-No?
                        • 8795
                        I ended up buying the newer FMS 360kv motor that they eventually put into many of their big planes. At the time, the 360 motor came stock in their big Pits biplane. I found the 380 motor later but the Corsair performed so well with the 360 that I didn't see the point in another 20kv.
                          • 8795
                          I've done a lot of searching for various kinds of spinners. Sometimes, I got lucky, while most of the time, it was a dead end. Have your tried looking over the assortment of spinners at HobbyKing? If you are handy with a Dremel, it is possible to modify a spinner from a 2-blade to a 4 blade. It'll never turn out perfect so be prepared to balance the spinner by itself. Insofar as "spinners" go, this Corsair (and the FMS one) doesn't really have what one would call a spinner. It's basically a fancy nut or covering cone for the nut. The blades don't actually have to protrude through a spinner as such.
                          I was originally going to just use the 4-blade prop from my 1700mm Corsair like TiredIron did but I found that the hex base on the prop adaptor was a bit on the small side and it didn't bite the hex hole in the prop assembly. I suppose it "could" work. I'd just have to make sure the nut is very secure and maybe even apply some FoamTac on the surface touches the base of the prop adapter and the nut itself to prevent slippage. I've yet to maiden mine. I'll make the call after that to try the 4-blade or not.
                          • Grover54
                            Going Weightless
                            • Jan 2019
                            • 319
                            Yes, the H9 P51D 20cc spinner is primarily for looks but here is what it will look like on the cowl and once I put the additional 2 slots in the spinner it will be a clean fit.
Name:	New FMS Motor 4a.JPG
ID:	187093Click image for larger version
Name:	New FMS Motor 4b.JPG
ID:	187094Click image for larger version
Name:	New FMS Motor 4c.JPG
                              • 8795
                              Are you planning this spinner for the Corsair? I'm not so sure it'll look OK on a Corsair.
                              • downwindleg
                                • 1279
                                [QUOTE=Grover54;n187092]
                                Yes, I'm also confused. Is this for the Corsair or like an FMS P-51. If it's for the Corsair you might want to think about the prop and hub for the FMS 1700 mm P-47. It's a four blade 17" diameter prop and hub assembly that would probably work on the Flightline 1600mm Corsair. But if it's for a P-51 that's a horse of a different color. Please advise.:Confused:
                                  Stay focused boys, you almost confused meLOL............Grover wants to put a 4 blade on his H9 P-51 as mentioned on post #2289 and again on 2293 ;)
                                    • 8795
                                    You mean post #2286. I had to do a double take. The P-51 reference was like "the forest for the trees" - didn't even register. I'm so old, that if you fart, it had better be loud. If I can't hear it, I won't smell it either. :Silly:
                                      At least my oldness has a medical reason now a days for juxtaposing the 6/9 and the CRS..........chemobrain;)
                                      So your like a skunk, can't smell your own :Poo:LOL
                                      • Grover54
                                        Going Weightless
                                        • Jan 2019
                                        • 319
                                        LOLOLOL!!!!! Ok, a bit off topic but No absolutely not. I was talking using the same motor as the Corsair.
                                          • 8795
                                          I always tell my wife one of two things .............................. "My shxt don't stink." OR "The dog did it."
