  • You two have me thinking of ways to install functional cowl flaps now. I was perfectly happy with fixed open flaps. D*&T*m yu.
    Tom
    • Originally posted by I-fly-rc-aircraft View Post
      Tom
      Tom, I'll take full responsibility for your unhappiness in this case...now get back to work on the 'functional' cowl flaps. Best, Steve
      • Looking at the cowl with the front portion removed (where the weights and faux radial is) it seems the motor mount and shroud are incorporated into the foam as if the foam was molded around them. The area where the cowl flaps are is well aft of the motor mount. I'm not sure how to (or if ) I will proceed.
        Tom
          Tom
          Ditto brother! OMG, can you guys stop coming up with all these fantastic modifications that I love and have to have but simply am not capable of accomplishing? Even if I tried, it would most likely turn out like and I'd spend all my time trying to keep up and never get out to fly. And God knows I need all the practice I can get just to keep from modifying anything into a lawn dart.
          My motto used to be "More flying, less Buying". Well that didn't work out so well, so now I think I'll try "More flying, less Modifying".
          I'll just have to live vicariously through your photos and posts, so don't let me down.
          • regards nose weights i hava 4000 6 weights up front and a 6200 zippy with 2 weights up front i simply take off prop then cowl a little tap out they come!!!!!!!! between flights easy peasy cheers
            • I fired the pilot that came with the plane.... and Hired a new guy....
              I remember I enjoy painting!
              • Good call!!
                • Originally posted by e4dragongunner View Post
                  E4DG, The 'new guy' looks like a Naval Aviator Recruitment Poster in comparison. You done good. Bravo Zulu. Best, LB
                    Thanks Brother! I do Like to paint.... Coming soon .... Complete repaint of Eflite F-18.... with new pilots and cockpit.... and.... Eflite P-51 1.5 new 3D printed pilot !!
                    • Impression moteur 18 cylindres terminée. Quelques retouches de peinture pour finaliser. Click image for larger version
                      • Just awesome!!! Love the Engine Work!
                        • Originally posted by Christian62580 View Post
                          Christian, Est-ce le 3DLabs Pratt et Whitney 3DP? Meilleur, LB
                            C'est le 3D labprint Pratt & Whitney R-2800 Engine remis à l'échelle pour qu'il rentre dans le capot moteur. https://3dlabprint.com/shop/pratt-wh...r-2800-engine/
                              Christian, moi aussi, j'ai acheté les mêmes fichiers 3DP STL pour l'imprimer pour ma Flightline Corsair. Quel pourcentage avez-vous utilisé? Ki a estimé environ 85%. Meilleur, LB
                                Je n'ai pas travaillé en pourcentage pour l'impression des 9 cylindres du fond (P&W_R-2800_F4U_01). Sous cura 4.4, pour la valeur de X:132 Y:132 Z:32 le tout en mm. Pour le reste des impressions, X:77,4% Y:77,4% Z:46,5%. J'ai du faire des essais avant, et je pense que tu devras ajuster aussi toi même.
                                  Christian, j'apprécie tes informations. Mon estimation était simplement ma supposition. Je «redimensionnerai» l'impression 3DP sur le diamètre intérieur du capot et le support moteur. Je suis certain que cela fonctionnera aussi bien que votre travail, mais j'ai pensé demander comment vous avez obtenu votre résultat. Encore une fois, merci pour votre réponse. Veuillez continuer à ajouter vos photos au forum au fur et à mesure de votre progression. Excellent travail, monsieur. Meilleur, LB
                                    Steve,
                                    Isn't it enough that you guys are doing incredible modifications that most of us, including me, can't come close to matching and just feel plain jealous about, now your adding the fact that you're multilingual as well. Now you're just showing off. Took 4 years of French and all I can do in it is swear. Although that's true for Spanish and English in my case.
                                    • Click image for larger version  Name:	IMG_1077.JPG Views:	0 Size:	87.0 KB ID:	234851Click image for larger version  Name:	IMG_1078.JPG Views:	0 Size:	86.3 KB ID:	234850 Here's my 3D printed cowl flaps (non-functional). A little paint and glue needed.
                                      Tom
                                      Click image for larger version  Name:	IMG_1079.JPG Views:	0 Size:	86.5 KB ID:	234849
                                      • I-fly-rc-aircraft Cool!!! Just love the Corsair! Any version, any time.... Nice job!!! Jerry
                                        • Hugh Wiedman Well bro, all I can say is "Hugh, tu es un homme aux multiples talents, même si tu ne peux que maudire dans Français!!" Or, "Hugh, eres un hombre de muchos talentos, incluso si sólo puedes maldecir en francés!!" Señor. Or cussing in Spanish!!!! LOL LOL
