Lon
Freewing A-10 80mm, F-86 80mm, F-15 90mm, F-16 90mm. Avanti. FMS DHC-2 Beaver, Fliteline P-38L ,HSD HME-262, HSD F86.Comment
WOW that's smooth, glad they got this resolved, almost wish I had waited (almost :) ). Good luck with her, wonder if the 2nd run of silver is looking this good.rc flyin addictComment
Hey, that's awesome Lon!! Maybe things are working out as they should, since you already know how she's going to fly, odds are she'll be staying in that condition!
Cool!!!
Grossman56Team Gross!Comment
Hey Gman,
I'm planning on her staying that way. I have 50+ flights on the silver one now, and haven't had to break out the CA or replace any parts. Have had to tighten a grub screw or two, but that's it! So looking forward to getting the Green one together and getting her in the air!Lon
Lon that OD looks great! I just may have to get a new one with such a nice finish...Mine was one of the first batch...Not bad but definitely not as smooth as that second batch. Keep her clean! ;)My YouTube RC videos:
I'll keep her clean! She's smooth, i mean every where, looking to find places where it isn't...no luck:)
Lon
Ya Steve has been upgrading/retrofitting many popular manufactured airframes with carbon fiber rods.....creating a very stiff rigid airframe. One of the benefits of reinforcing with carbon fiber rods is indeed less damage if crashed. FlightLine incorporated reinforcement rods to this P-38 - However Steve of Killer Planes stabs more CF rods in where-ever an airframe can accept them.Anybody seen this? http://www.killerplanes.com/crashproofplanes
I have purchased many warbirds from him over the years.....not for crash proofing but merely for the added stiffness rigidity which for me added to the longevity of the model(less flex - less stress - no worries of wing "taco" in heavy winds or WOT stunt flying). I have one airframe that was involved in a mid-air hit with a much larger gasser.......the plane that stuck mine went down in pieces because its prop hit the carbon fiber rod in the rear fuselage then hit again on my tail feathers - his prop exploded and ejected the motor and severed his wings in flight.....while it created a huge gash in my fuselage and severed the hinge of the rudder....I was still able to continue my flight on power and make a soft controlled crash. I still fly my plane to this day after filling in the gaps of my airframe with light weight spackle......This would have been a certain write off of my plane had it NOT been a Killer Planes retro-fitted carbon fiber stabbed airframe. I have this flight on my U-Tube Channel....Need to call attention of it to Steve now that I think about it!!
Kelly Johnson's P-38 rides again! For all the rest of you who also can't figure out why FMS stopped making their gorgeous P-38, I have some good news: Now there's an EVEN NICER one! The LIFE SIZE (well...Denise size, anyway) 1600mm Flightline P-38 is here!
TwistedGrinComment
Hey Lon, not to rain on your parade but I can see the cells clearly in your pictures especially picture number two where the light reflects off the finish. Either you guys don't have your reading glasses on or are due for a visit to the optometrist. That's not to say that it isn't a better finish than earlier batches but I hope none of you read x-rays for a living!!! LOL, Brad P.S. Those cells will become more and more visible in the hot sun pretty shortly, especially inside the cockpit- just sayin'.Comment
Downwind leg. .no problem with my parade..hope you feel better. .as I had posted to Lauren, you have to get your nose up next to the plane and be looking for cells. Or as I do myself, magnify the photos and look for cells. With the exception of when I have refinished and painted a foamy like others. I haven't seen a better factory finish on a foamy.Hey Lon, not to rain on your parade but I can see the cells clearly in your pictures especially picture number two where the light reflects off the finish. Either you guys don't have your reading glasses on or are due for a visit to the optometrist. That's not to say that it isn't a better finish than earlier batches but I hope none of you read x-rays for a living!!! LOL, Brad P.S. Those cells will become more and more visible in the hot sun pretty shortly, especially inside the cockpit- just sayin'.Lon
Looks great to me Lon!!
Maybe its a matter of perspective, to know a good one is to have seen a bad one, sort of thing.
Hey all,
my my wing landing gear gave way. The wooden piece that the landing gear is screwed to came loose.
what is the best way to re-attach it?
epoxy?
foam-tac
silicone caulking
ca
any suggestions? I have never had to adhere wood to foam.
ToddComment
Here's a short of my Allied Green P-38 that arrived this week.P-38L by Flightline. 1600mm wingspan. Available at MotionRC.Lon
Is the P-38 the plane you used here or the Sea Fury? Just curious if it's the P-38 that gave you the 10 minute flight time with 2 ESC's.
Interesting you bring this up.
I have the HK Avios Sea Fury. Motor and ESC are stock, but I'm flying it with a much more efficient prop & spinner from the 1400mm FMS P-51. I built it about the same time the P-38 came out, so I was very interested in using the same battery in both planes. The recommended battery is 3300-4000 4S, but I stuffed a 5000 in it and crossed my fingers on maiden. It was definitely on the heavy side, but CG'd perfectly and flies well.
I have my timer set for 7:00 and when I land, I was only putting back in ~2000mAh. I decided one day I was going to change my timer from count down to count up, and fly it until I hit LVC. Yes, I know this is hard on batteries, and not particularly smart. I went to an area I seldom fly at that is far from the world, and no one but me was around. I knew the risks, so no lectures please.
I started losing power at 17:30 and landed without issues...
The funny thing was, at about 10 minutes I started to get bored, and began to lose concentration. We all know it takes your full attention to fly a warbird, and that long flight was almost exhausting. It was interesting to see how long I could milk the battery, but it just wasn't fun to fly that long. I have the timer set at 8:00 on that plane now, and that's plenty long enough for me. I like to take a break between flights, and setting up a perfect landing approach is half the fun of R/C for me anyway...Bob Duncan
The only real helicopter is the CH-47 Chinook. The rest are just sling loads!Comment
