Official Black Horse 2350mm Gilmore Red Lion
  • 406PIlot
    • Nov 2020
    • 381
    • Billings, MT
    My Gilmore cowl did not have the blisters installed. I had to cut them out and glue them to the cowl.
    • djmoose
      • 150
      • Cleveland, OH
      Let's attach the rudder and elevator with Robart pin hinges in the same fashion as we did with the ailerons. We'll also install the respective servos and pushrods to connect everything up.
      "Approximately 100 miles southeast of Holbrook, Arizona, the Hornet engine began running rough. The experienced pilot (Roscoe) began studying the terrain in case of an emergency landing proved necessary. Few options presented themselves in the desolate mountains. A bailout would be a last resort. The racer was his pride and joy of five years. Spotting a green field, he began his approach, the propeller now fanning uselessly in the breeze. The racer cleared the field's fence, stalled, and caught its landing gear in the soft dirt. The racer began tumbling end over end for about 60 yards. It eventually stopped on its main gear and engine. Six inches behind Turner's head, the beautiful Wedell-Williams racer was nothing but a mangled mess. The only part of the place that seemed to have a chance to be repaired was from the cockpit forward." - Wedell-Williams Air Service page 84
ID:	310925Click image for larger version
ID:	310922Click image for larger version
ID:	310923Click image for larger version
ID:	310927Click image for larger version
ID:	310924Click image for larger version
ID:	310928Click image for larger version
      • CitabriaDriver
        Me
        • Feb 2021
        • 21
        • Wiltshire, UK
        The more I fly this the more I like it. Even with a Saito FG61 TS it has plenty of power.
          CitabriaDriver Brilliant flight and well done videography. The FG61 pulls it around nicely.
          djmoose The additional bits of history are always fun.
          • DaleD
            • 57
            https://m.youtube.com/watch?v=UdknwpJc4Q0
            Very nice flight. The FG61 does appear to have more then enough power.
            What I loved about your flight was the landing. If I am not mistaken, with your set up she appears to be a floater. At one point, I saw what looked like a little down elevator input to get her to settle down on the approach.
            Thanks for sharind
            DaleD
            • CitabriaDriver
              Me
              • Feb 2021
              • 21
              • Wiltshire, UK
              Thanks DaleD. She does float, in fact without a decent (10kts) headwind, it difficult to get her to land and not end up in the long stuff at the end of the strip.
              Thanks for sharind
              DaleD
              • 406PIlot
                • Nov 2020
                • 381
                • Billings, MT
                What size prop are you running with the FG61?
                • CitabriaDriver
                  Me
                  • Feb 2021
                  • 21
                  • Wiltshire, UK
                  It’s a 22x10
                  • WrightBrosRC
                    All Things Aviation
                    • Feb 2019
                    • 195
                    • Hillsboro, OR
                    I put the first three flights on mine this morning. 26.7lbs AUW, 12s x 24,000mah (6s x 4), Rimfire 65cc 160kv, 24x10 prop, Castle 160(no BEC), 123LiFe 6.6v receiver batt, Hitec D645MW servos, all hardware is from the kit. It flies with plenty of authority. It was a very enjoyable morning.
                      WrightBrosRC Congrats! Great pics and report.
                      It looks like you went with different wheels. The stock wheels are quite hard and wear rather quickly. What wheels did you use? They look like they've got some give.
                      • James
                        Administrator
                        • Aug 2017
                        • 1543
                        WrightBrosRC - Looks gorgeous, any in flight pics or videos coming? I feel I mostly see this one on the ground
                        • WrightBrosRC
                          All Things Aviation
                          • Feb 2019
                          • 195
                          • Hillsboro, OR
                          Thx TJ! You have a great eye for details... the wheels are treaded Dubro inflatables at zero, or ambient pressure. Yes, the stock wheels are practically a slap in the face to consumers. There is however, a balance to be achieved when it comes to grass ops. Soft wheels with wheels pants create some occasional friction on the grass and demand a higher level of attention and elevator control. I may consider added tire pressure in the future, however performance on the smooth runway is most excellent.
                            James If MRC gets a good number of these in stock, you should get one. Good candidate for your next gasser project .
                            WrightBrosRC Thanks for the wheel info.
                            • DaleD
                              • 57
                              Any idea when MRC is likely to get new stock? I wasn't able to secure one in the last shipment hoping to secure one next time around.
                              Thanks
                              DaleD
                              • RCBobP
                                • 89
                                WrightBrosRC Sorry, I'm a bit confused. For grass ops, are the stock wheels preferable? That's what I'll be flying from for the most part. Thanks.
                                • WrightBrosRC
                                  All Things Aviation
                                  • Feb 2019
                                  • 195
                                  • Hillsboro, OR
                                  Hi Bob, sorry for the confusion. I have never used the stock wheels as they are rock hard. I do recommend a softer tire, however part of my point was that for grass ops I would likely use more tire pressure and maybe even more wheel space under the wheel pants for less friction. I only have three flights so far but have flown from both grass and geotex just fine.
                                    DaleD I have absolutely no idea.
                                    Tom from Motion RC has mentioned on several pages here, that getting product from suppliers, sufficient to keep up with demand, has been a challenge. Maybe he has some info as to when the Gilmore might be back in stock.
                                    Best bet would be to add yourself to the Notify Me list on the Gilmore product page. The bird is worth having for sure.
                                    • James
                                      Administrator
                                      • Aug 2017
                                      • 1543
                                      DaleD - I don't have any firm dates, but I believe the next shipment is probably early summer. I can't find the post but Tom did speak about how Blackhorse is more a boutique factory compared to say Freewing in that they are a smaller operation and by nature of the beast, balsa models take a lot more time to produce 1 model vs a machined foam-electric model. We had only recently just received a BlackHorse order in February which had the Gilmore as well as many of the large warbirds (Zero, Corsair, etc) and they were gone within a week. So the best bet is to always click the notify me when back in stock button so you will get emailed when new stock is in, but when it is, especially with balsa models, you have to be ready to pounce.
                                      It's been the case the past year that more people have either found the hobby, or those within the hobby already have just dove in even more to the point demand is far outweighing supply across the board. Add shipping craziness and the fact that balsa models just aren't able to be produced as fast as foam-electric and you have a recipe for long wait times.
                                      I wish I had a better answer for you
                                      • RCBobP
                                        • 89
                                        Originally posted by James
                                        DaleD
                                        This here is some good news for the hobby!
                                        • DaleD
                                          • 57
                                          Thank you James. I look forward to receiving notification on the next shipment and availability.
                                          DaleD
