    Congrats Aros! Thumbs up on the repaint.
    Thanks bud! Although, I must confess, the highly reflective nature of the paint does seem to lend itself to more gatoring susceptibility. I've only had her out in the direct Sun a few times, and never for all that long, and only maybe mid 50 degrees for the most part. Admittedly, it's nothing major, but those cells are becoming a tiny bit more pronounced than I would like. Nothing much I can do about it, just kind of live with it, knowing it's the nature of the EPO beast. You don't even notice unless you are inches away.
    Something for some to consider if wanting to go with a highly reflective aluminum/silver finish.
      • 7430
      Originally posted by jetfool
      Dan,
      What radio did you end up with? I have always used Futaba but looking at the Spectrum 8e. Most of our members are using this now and I like a lot of the features. Still using my 7c Futaba after 14 yr and never a problem.
      Best Regards, Rex
      I bought a Spectrum NX 8+ which has 20 channels, great little radio and more channels than I'll ever use!
      In the manual, page 54, top left is the atennae reference.
      (Dangerous Dan)
      • Glazier808
        • Feb 2020
        • 25
        Anyone else having an issue posting pictures?
        it doesn’t give me the option to resize the picture anymore and it’s telling me it’s over max
          • 4873
          G8,
          Over sized is a common thing.
          You could resize in MS Paint or whatever post processing photo app you might have.
          If you pic is over-sized you'll not get a size option, I don't believe.
          Best, LB
          • Glazier808
            • Feb 2020
            • 25
            Hmm, nothing different on my end from earlier posts, when I went to post before it always gave me the option for size but it no longer does
              Took her out for her second sortie. This time I tried the grass field adjacent to the airport runway. Flew fantastic. Now that she's trimmed, just no bad habits to speak of. Flies great, lands great, looks great...What's not to love?
              After the flight, Callie's decals were waiting for me in my mailbox so I made no short order of slappin' them on. I think she turned out great! I'm very pleased overall. Now that the trimming and jitters are out of the way, now I can really let loose with her moving forward. Apologize for the low quality video. My fiancé was filming on her phone which doesn't have the best video quality.
              Click image for larger version  Name:	IMG_6106small.jpg Views:	0 Size:	518.9 KB ID:	447513
              • Glazier808
                • Feb 2020
                • 25
                Click image for larger version  Name:	IMG_9580.jpg Views:	33 Size:	242.2 KB ID:	447523
                finally got one to load I don’t know what the issue was
                I added invasion stripes to the top of the wing and yellow to the tail. I was having some issues with it silhouetting at a distance in a high wing over. This helped tremendously and although I know it’s not correct to scale for Frenesi, I like it!
                  • Nov 2013
                  • 2787
                  • Cody, WY
                  Beautiful job with the repaint, Aros! When I finish my present Hairless Joe project, I'm clearing the tables to pick up one of these new P-51 models!!
                  Glad your flights are going well. Seems to be a pretty standard remark from others that this is a great new flying airplane!
                  Cheers
                  Davegee
                  • marty 72
                    • May 2021
                    • 36
                    AROS,
                    You did an amazing job with the paint. I zoomed in, the edges all looks nice and clean. Question: Do you use blue painters' tape for the edges or something else? No issues with pull up the original paint? How many coats of the silver did you need to cover the green and black original paint?
                      Lookin' good! Nice job!
                        Cheers
                        Davegee
                        Thanks Dave! Means a lot coming from you. Yes, she's definitely as advertised. Really a tremendous flyer and like some have said, even the landings make you look good!
                          Originally posted by marty 72
                          AROS,
                          Thank you very much!
                          I did use the blue painter's tape for this model. I've used frog tape and other types, but I keep coming back to the good ol' blue. Now, that's not to say it won't peel up paint or bleed. All tapes I've used over the years do that to one degree or another. There's hobby trim tape out there (like 12mm wide or something) that is probably the best non-bleed or peel, but I tend to run out and use the blue painter's tape. One technique I use is I always put the sticky side on my pants or shirt a couple times before applying. This helps with less paint pull. The good news, I don't recall any original stock paint pulling up. It was the white and black invasion stripes I painted that was problematic. A bit on the yellow I used for the nose but nothing major. The silver I used for the base did pretty good not peeling too, but even when it would peel a little, there was still enough silver on the coat that I didn't need to touch it up.
                          Speaking of, I almost always expect to do detail touch ups, especially after using multiple different paints like this one (silver, yellow, olive drab, white and black). To me, it's just part of the process. Luckily, painting new liveries on RC model aircraft is probably the one rare time I have patience, lol.
                          I use paper towels to mask off the large areas you don't want overspray. Always works great. Some use newspaper, but I've always used paper towels with great success.
                          Thanks again for the compliment!
                            • 4873
                            Aros,
                            Outstanding.
                            Best, LB
                              Originally posted by Elbee
                              Aros,
                              Outstanding.
                              Best, LB
                              Thank you my friend! Like Dave, coming from you that means a lot.
                                • 4873
                                "[and] Like Dave"
                                I might have to succumb to the siren song of this beauty sooner rather than later.
                                Best, LB​
                                • marty 72
                                  • May 2021
                                  • 36
                                  Aros,
                                  Thanks for the detailed reply! I may do something similar to what you did, start with a clean silver canvas as you did, but a with different scheme. Initially, I was hesitant to buy a brand new $600 plane then repaint it. I've done quite a bit of model painting, so I should be fine. I've used the blue tape and done very well with it. I have to say, doing your very own scheme is a lot of fun and when done right, quite rewarding.
                                    • Nov 2013
                                    • 2787
                                    • Cody, WY
                                    Best, LB​
                                    Come to Jamaica, Mahn! You'll like it here! And they have lots of nice P-51D model aeroplanes, too! 😁🤣😊
                                    • Rdavila
                                      • Nov 2015
                                      • 3
                                      Do i always need an RX battery for the receiver?
                                        • 5424
                                        No, this and most electric planes have a built in BEC, battery elimination circuit that powers the receiver. A few don't trust their electronics and do a separate BEC or battery but it adds complexity.
                                        • GliderGuy
                                          • 1416
                                          The thing that threw me was not seeing a BEC lead to plug into the RX. The guys here helped me understand that the built-in BEC (built in to the ESC that is) powers the RX through the throttle lead that connects to the RX.
                                          The separate pigtail off the battery lead/connector is a separate source for auxiliary stuff you might add. Note: Do not connect this pigtail to the RX.
