    • Nov 2013
    • 2702
    • Cody, WY
    Me, too, on the Cougar. I do like the other mode and will probably do the same with the P-51.
    How do you like your P-51 so far, Evan?
    cheers
    dave
      • 5395
      I like it. Looks and flies very well. That said I fly my jets more and actually like the Spitfire more.
      • jetfool
        • Nov 2022
        • 1289
        • Crawfordsville, Indiana
        Davegee,
        While working away trying to learn my new NX8+ Spektrum from my old Futaba 7c a deceased's friends son gave me his dads like new Spectrum 8, Taranis 9d assist + and a Turnigy 16 with 3-4 rec for each. Not sure if my old mind can figure out this new technology. Felt Humbled to receive these.
        Rex
        • Davegeee
          • May 2026
          • 90
          • Cody, WY
          I'm looking forward to flying my P-51 when I get it all done in a few weeks, hopefully.
          The upcoming F-35C should really be a cool airplane, and I have confidence that it will be, with the RC Geek Chris Wolf a driving force behind it. I may get one myself if it turns out in reality as good as it looks on paper!
          Cheers
          Davegee
          • BL_41
            • Mar 2025
            • 15
            • Amarillo, TX, USA
            "Question on setup of Freewing Gyro for 1600mm P-51".
            Sounds like the gyro that came with my Flightline P-51. I also bought the Freewing bluetooth device to communicate with the gyro. I found their Freewing Flight Assistant for Android, but not for iOS devices. I have fifteen flights using the gyro Basic Gain mode. The pitch and roll settings seem good. I had a couple of landings the other day in light gusty winds. The plane was rock solid all the through the landing. I think the yaw may be set a little high. On takeoff the plane has a tendency to zig-zag, regardless of the wind direction. I have reduced the gain on the yaw, but have not had a chance to test it.
            Brian
            • GliderGuy
              • 1408
              Hi Brian…
              The default gyro settings are mostly fine. The Zig Zag on takeoff is pilot induced. Once you get the hang of it…the Zig Zag goes away. I’m on high rates and no Zig Zag.
              The secret is don’t touch the rudder and smoothly but smartly go to full throttle. Don’t ease in the power…get after it. She’ll jump into the air very straight with a touch of up elevator at the start.
              Ease up the throttle to full power…and you’ll Zig Zag a lot.
              Others have posted this trick in prior posts.
              I agree with Evan…I like it!
              • nuts-n-volts
                Duke City Electric Flyers
                • 260
                • Albuquerque, New Mexico
                I think I'm quoting Evan here... I bought the plane without a gyro and firmly believe it doesn't need one at all. And, like GG said, go easy on the rudder when taking off/landing. It's very effective.
                Just a FWIW. I would check your Frame Losses after flying. I was getting over a 100 or so each time flying stock. Bought a 10A ZTW BEC from Motion. Had a feeling the load was high especially near the end of the flight with gear, flaps, etc all working. After installing, the FLs went down to below 20/flight. Just maybe something to keep an eye on.
                I also had a screech coming from the prop/motor whenever I made a power off dive, then coming back into the throttle. Un-nerving it was. I re-programmed the ESC and the now it has not only gone away, but the power is much smoother and quieter. I believe it was either the brake not being set to off or the Freewheeling feature not set to on.
                The aircraft is very well made and flys wonderfully.
                Fly low, fly fast, turn left
                • GliderGuy
                  • 1408
                  When I had a main not deploy until I recycled, someone commented about a possible frame loss issue on the P-51.
                  I immediately ordered some capacitors off Amazon and ended up adding 6600 uF (2 of the 3300 uF in parallel) because I could! In the past, gyros I have purchased came with 3,300 uF.
                  Since adding these caps to an open port on the RX, no more issues. I was surprised to find the bird’s gyro didn’t have a capacitor in the system. Checking my other MRC birds…some do and some don’t have external caps at the gyro. I’ve added caps to all the birds that didn’t have them. Couldn’t hurt!
                  And…because I could…I also added RF chokes to the non-motor side of the ESC. Generally, chokes are reserved for use on my high-current EDF jets.
                  I’ve made a lot of flights since the addition of the add-ons. Rock solid, now. I have equipment that doesn’t monitor frame losses or drops.
                    • 8215
                    I have been experiencing that same screech. Very unnerving! What entailed re-programming the ESC exactly?
                    • paulrkytek
                      • Jun 2019
                      • 528
                      • North of England
                      Gone for the full desert rat https://www.youtube.com/watch?v=-EDAfE7dQVI
                      • nuts-n-volts
                        • 260
                        GG, I actually tried a cap 1st. It helped, but not near as much as more power did with the higher current BEC. Now, don't get me wrong. I'm not knocking the Caps. i use them on many planes... coming from a suggestion you made a long time ago in a galaxy... er, plane, far, far away!
                        Just check load restrictions on any ESC. They usually will state - at least they did in the old days - how many servos can be used along with a certain battery. This P-51 has 12 servos (counting retracts)! In my opinion, way too much for what they're using to drive them.
                        Aros, I just went with the instruction manual that comes with the speed control / and airplane. Read, do beeps, be done, he happy. if you want, I can tell you what items I picked. Need to go down to the shop anyway. The thing I think was the culprit was a setting call Freewheeling. On old FW V1 ESCs it said to disable it, on the new V2 ESCs, it needs to be enabled, or ON.
                          • 5395
                          12 not including retracts. When I fly I’m always careful the do the gear when I’m not doing much else including flaps.
                            • 2696
                            Finally finished re-powering my "dog" 1700mm P-51. Haven't flown it yet, but will be posting more details in What Did You Fly (or will fly).
                            Installed an EFlight Power 60 470 Kv motor, replacing the FMS 360Kv gerbil wheel and got some 17X7 2 blade Xoar Props and 16X7 3 blade Xoar Props for it. On the bench, I could hardly hold it down at full throttle. :hugging:
ID:	449579 Click image for larger version
                            • nuts-n-volts
                              • 260
                              Yes, I stand corrected. Actually, Evan, I originally thought it was 12 not including retracts. Tried to count in my head and found the problem... in my head! Getting older I guess!
                              • GliderGuy
                                • 1408
                                Question-With the stock ESC (built in BEC) providing power to the RX via the throttle lead, what precautions / wiring changes, if any, plugging in a separate BEC into the RX? Or…do you just allow them to both run in parallel,per se?
                                  • 5395
                                  I would pull the red lead from the ESC plug.
                                  • GliderGuy
                                    • 1408
                                    Ordered one: ZTW 10A BEC / UBEC
                                    ​Thanks Evan…was reading the specs and found this:
                                      • 5395
                                      Note that is really a 6A BEC with a 10A burst.
                                      • GliderGuy
                                        • 1408
                                        Are the specs known for the stock P-51 ESC/BEC combos BEC section?
                                          • 5395
                                          7A, does not say if there is a burst or if that is the burst. I assume that is a constant rating and they don’t list a burst but would assume at least 10A.
                                          If you are not trusting the stock ESC and adding a separate BEC I would go bigger, 20A and maybe one with dual output leads.
