  • nuts-n-volts
    Duke City Electric Flyers
    • 262
    • Albuquerque, New Mexico
    I just went with the 10A as my feeling was there was something amiss with the BEC in my ESC. Waaay too many Frame Losses. And most Frame Losses are caused by voltage drops. And those are caused by a few servos overloading the circuit. I don't think the internal BEC is a "switched" one either. By going with the external switched BEC, (separate unit), things are much more safer with the FLs only 20 or less.
    Fly low, fly fast, turn left
    • nuts-n-volts
      • 262
      And I do agree with Evan about going bigger. Why not? They are not that much more expensive. Weight is minimal. More power is piece of mind.
      • GliderGuy
        • 1416
        Thanks guys…all good data/information.
        Good precaution about exercising the gear without having a lot of other controls moving about during the gear extend/retract action.
        We’ve had a week of strong wind. I’ve been grounded this whole week. UGH!
        The wind finally let up this afternoon (06/12)! Got in 10 flights. Began working on getting into the habit of letting the gear complete its cycle alone with minimal other servo action. I can see this is a good habit to develop for any large (large gear servo) and multi-servo bird.
        • nickwildman81
          • Nov 2025
          • 17
          • North West, UK
          Loving this bird! 27 flights and over 3 and a half hours airborne. Using Hoovo 6S 5200's I'm getting on average around 7:30 with some left in the 'tank' for a go-around. Custom graphics by Callie, going to do some weathering eventually.
          Just incorporated gear door droop after motor shut down, flap droop and elevator droop. Nice little scale details.
          Click image for larger version  Name:	IMG_3534.jpg Views:	0 Size:	96.5 KB ID:	449652 Click image for larger version  Name:	IMG_3533.jpg Views:	0 Size:	127.3 KB ID:	449653 Click image for larger version  Name:	IMG_3261 2.jpg Views:	0 Size:	162.6 KB ID:	449654
            • 2716
            Sweeeeet! Callie to the rescue! Yippee Ki-Yay :cowboy:
            • paulrkytek
              • Jun 2019
              • 542
              • North of England
              Tried the gun sound system up in the air today, just not loud enough with the 2" speaker I installed at the front. Would probably be better with larger air exit holes but not prepared to create those so I have taken it out and will use it in my upscalled Magnatilla/Eindecker when I get around to building it over the next winter
                • 7432
                DaveGee just got his and we're working on a pilot. The bust I think we'll end up using will be an upsized version of the one I have in the P-51B. He just fits so well.
                BTW, the gunsight is my N9 design.
                Click image for larger version  Name:	20260530_093940.jpg Views:	0 Size:	91.0 KB ID:	449683 Click image for larger version  Name:	20260530_093946.jpg Views:	0 Size:	59.2 KB ID:	449684 Click image for larger version  Name:	20260518_131706.jpg Views:	0 Size:	105.7 KB ID:	449685
                (Dangerous Dan)
                • jetfool
                  • Nov 2022
                  • 1368
                  • Crawfordsville, Indiana
                  Grossman,
                  Your Pilots are fantastic. Outstanding Craftsmanship. Bob is still on flight status.
                  Best Regards, Rex
                    • 4873
                    Grossman56,
                    Is that the Max Grueter P-51 pilot bust?
                    Looks great regardless, Danger.
                    Best, LB
                      • 7432
                      Yes, the Max Grueter bust, the shoulders have been shaved slightly so he is a nice tight fit.
                      Dave went with a different pilot that I found on CG Trader, he has separate arms and a full body, so he cut him at the waist.
                      The pilot was originally made for a 1/32 scale Revell P-51 model kit that he enlarged. It's not bad either, I have him in the basement drying after the black coat application.
                      You can check him out here.
                      (Dangerous Dan)
                        • 4873
                        Grossman56,
                        Thanks, Danger.
                        I have the P-51 pilot in full figure, just hadn't seen the bust only version.
                        Diggin' all the extra details.:star_struck:
                        Best, LB
                          • 7432
                          Dave just sliced off his lower end.
                          The print is a little rough but doable. Is there any way to increase the resolution?
                          (Dangerous Dan)
                            • 5425
                            Revisiting the screech. I have a sound system so I never noticed it. But listening for it now I hear it. Just enable freewheeling?
                            The thing I think was the culprit was a setting call Freewheeling. On old FW V1 ESCs it said to disable it, on the new V2 ESCs, it needs to be enabled, or ON.
                              • 4873
                              (Dangerous Dan)
                              Dan,
                              1. Post processing FDM prints with acetone works wonders, though some detail can be lost if you go too far.
                              2. Reduce the layer height in Prusa Slicer
                              3. Slow the print speed which can also help reduce artifacts in the prints.
                              I have all of these things and each has it's own effectiveness.
                              Best, LB
                              • nuts-n-volts
                                • 262
                                Yes.
                                  • 5425
                                  OK, I turned active freewheel on and on the bench the motor clunks when giving initial throttle off no throttle. So I then turned off active freewheeling and it's nice and smooth when giving throttle. Does yours do the same?
                                  • Davegeee
                                    • May 2026
                                    • 90
                                    • Cody, WY
                                    (Dangerous Dan)
                                    Hi Dan: I just saw your post on 19 June. I don't know of a way to make the print resolution better. There might be some way to do that, but I don't know how to do that, if it is even possible. Can you make it work as you have it now?? I think it is still probably better than the OEM bust that comes with the kit.
                                    Thanks,
                                    Dave
                                      • 4873
                                      davegee.
                                      You can decrease the layer height in Prusa Slicer.
                                      More layers better resolution.
                                      See below.
                                      (Dangerous Dan)
                                      Reply Post by Elbee.
                                      Dan,
                                      I have done all of these things depending on the print and each has it's own effectiveness.
                                      Best, LB​
                                      • nuts-n-volts
                                        • 262
                                        Evan, I set mine to ON as from what I remember. And, I logged it it my book. Logged as a V2. Here's the confusing part that I discovered recently. There was a V1 Freewing ESC that also has the feature, yet, looking at its manual, the Freewheeling default on that earlier unit was set to OFF. This newer V2 says to set it ON. I can't help but wonder if the factory got the settings confused, then printed them wrong in the manual? Either way, I turned mine ON and it went away. Here's the rest of the parameters and my settings:
                                        1. Brake Type - Disabled
                                        2. Brake Force - Low
                                        3. Voltage Cutoff Type - Soft
                                        4. # LiPo Cells - Auto
                                        5. Cutoff Voltage - Disabled
                                        6. Start Up Mode - Normal
                                        7. Timing - Medium
                                        8. Active Freewheel - On
                                        9. Search Mode - Off​
                                        Now, you have me wondering as one cannot see the current programming in the unit without a display. Or you just do it again... and fly it again to troubleshoot. Crazy.
                                        Not to keep guessing at this, but there is also the brake. I'm sure it should be disabled. But, its possible that units were shipped to customers with it in Low. The V2 manual says the default is low because it is also set to reverse. I say this because when asking Martin at Motion, he mentioned to also check the brake. I did not think mine was the problem, however I still set it to OFF in "Type". So, maybe that is confusing things.
                                        ...Just called Motion... could not help with the issue. Sorry, but I gonna have to order a programmer display to be sure.
                                        • nuts-n-volts
                                          • 262
                                          Great! So after that long post, I go to Motion again (after I called about the issue) and looked for a FreeWing Programmer... with a display. They have one. The 2 reviews both say it doesn't work. The response back agrees that there is still something not quite right!
