  • Originally posted by Mad Baron
    That's why I went ahead and got the 4000s every one was saying that it will fly the best with the 4000. I have some 3300 and a 3000 will these work as well?
    Absolutely! I've even used 2750's but you'd want to add a little nose weight with batteries that light. 3000 and 3300's will work great just check your CG and make sure it's not too far aft.
    • I have some 3600's as well and she flies fine with them, but I can see the difference, not anything huge. Maybe its just me, but the 4000's seem ideal and, of course, that's all I've tried in her. Some of the bigger batteries may be even better. Nothing like a bigger gas tank.
      • Well I received mine and opened her up, boy is she pretty!
        Then I put her together and tested controls, prop blew apart leaving a nice hole in the wall where a blade decided to nest. Then I get aysymetric Flap deployment centered servos and noticed that the servo that I noticed had red, white, and black wires doesn't center the same as the brown, yellow, and orange one. So I pull the servo and no dice that servo doesn't center like the other and the servo arm either lines up forward of center or aft of center and no matter what I can't get rid of the aysymetric deployment of the flaps.
        The final issue is the control horns. Both ailerons were hanging by the literal thread as well as one Flap horn. Good thing the prop blew I suppose or I'd be looking at a pile of foam. I'll glue them back in, but dang I know I didn't get a lump of coal for xmas.
        Motion has been very good about the prop and I've no issue with them. My Cat musta been built on Friday or Monday because I'm starting to feel it's a lemon in a group of margaritas.
        • Hey Rfenner, first off, welcome to the forum!!
          That's a tough break, but the guys at Motion are the best, so I have confidence they'll get you straightened around.
          Funny how that works because up until this point, there hasn't been anything major, but you seem to get everything, good thing the prop ended up in the wall and not some other place softer like flesh!
          Hang in there and keep us updated on how you make out.
          • I built my second Bearcat this weekend. What a beautifully done model. Everything worked as advertised. I did not use the little blue box. I still prefer my "y" connectors. The decals included were some of the best I have ever received. They went on very easily.
            Bob
              I finally got started on my Cat today have to test the electronics first and figure out the little control box for the radio. I have been searching for the Varathane and it looks like I would have to order some in.
              The only place I could find the Varathane was from Amazon.com My local Home Depot didn't have it and neither did a couple of smaller mom and pop hardware stores in my area.
              • My local Home Depots have carried Varathane for a while now, but not in Matte. However, they are now starting to get Matte in stock instead of just selling it online. I was in there the other day and they said they were getting it any day now. Hopefully they will have it by this weekend.
                  The box is only for the gear and flaps if I remember right, anyway, anything not coming out of it you have to put directly into the receiver.
                  • Got my replacement Bearcat today. I might be able to work on it this weekend, but I have a week long work trip on Monday, so it might have to wait. I have the FMS retractable tail wheel and will do the mod to this. I will post a full write up on how to do it when finished.
                    • Originally posted by Rfenner View Post
                      We are working with him to get him going, just waiting on some parts to arrive. Once we have them we will get him in the air in no time. As for the different colored wires it relates to one of the Servos being a Reverse Servo and that is where the difference lies.
                      • Great news Wayne, of course, anyone who has dealt with Motion R/C has every confidence that he would be taken care of.
                        • i received my Bearcat yesterday and tonight assembled it. I am totally confused on the wiring and polarity of the plugs going into the control board from the servos. First, do the yellow or white wires when plugged into the control board face inboard or outboard and are they opposite on right and left sides or all one direction? Second--It shows 5 wires coming out of control board to my receiver and I have only 3 plugs coming out---from the right side first is flap, second wire is going to the last output on left to a 3 wire plug marked GEAR, there is no rudder wire, Fourth wire from right also says gear. This all makes no sense at all. How can my receiver send a signal on a single wire to this control board. I plugged in the battery and nothing turns on. Please help so I dont have to return this thing
                          • Welcome Albrat! This video shows how to set up the blue servo box: https://youtu.be/ltp0VPRJ10g
                            • Been looking at these and wonder if theyll fit this Cat
                              Alloy Oleo Struts Offset with Trailing Link 168mm F8F Bearcat Style (2pcs)
                              • Originally posted by albrat View Post
                                Hi Albrat
                                Check out post 118, I had the same questions, the box they show in the manual is not what you receive. You use the box for L/G, ailerons and flaps an bypass everything else into the receiver.
                                The single wire for the flaps works, just have to determine whether it plugs in so its at the top or bottom. Seems to me it was at the top.
                                • I am like Mad,,,i just used y connectors and stashed the blue box...
                                    Now that's interesting, let us know what you find
                                      Hey Gman.......just measure your struts and let us all know if that 168mm length is gonna work.
                                      I'm making mental notes for when I grab one to do the "Beetle Bomb" ;)
                                      • Will do.....WOW!!!
                                        What just happened to the Squawk!!
                                        I go away for 1/2 an hour and everything changed!!
                                        That's crazy!!
                                        • The stock struts measure 15.5 cm and they are 16.8 cm. Now, I didn't pull one of mine out of the servo, so you have to allow for that as well as the fact that they are measuring the length when the strut isn't compressed at all. What we're going to run into is whether its going to retract or does it extend too long. Be cool if it worked, maybe we might even get a small amount of extra prop clearance, that't be nice.
