  • Prekin
    • Feb 2021
    • 135
    just replaced the hinge on radio hatch.
ID:	371447Click image for larger version
ID:	371446Click image for larger version
    • RRHandy
      Instructor Pilot
      • 896
      • Lilburn GA
      Need rivets around that too.
      AMA 424553
      • Prekin
        • Feb 2021
        • 135
        one simple rule for this project: "Less is more." Just only experinece from first lines of rivets.
        • kallend
          • 1877
          Originally posted by Prekin
          one simple rule for this project: "Less is more." :
          That's why I'm not putting any 'rivets' on mine.
          • Prekin
            • Feb 2021
            • 135
            I changed my mind about the rivets on radio hatch. RR Handy, you were right!!
            I assembled the wings and fuselage to do some last rivets. Now she looks like in winter camo
ID:	371759Click image for larger version
ID:	371760Click image for larger version
            • jetfool
              • Nov 2022
              • 1362
              • Crawfordsville, Indiana
              Going o look great when you finish. Good job. Rex
                • Nov 2013
                • 2783
                • Cody, WY
                Hi Prekin: your decals you are painting over look painted on, themselves. Did you paint them or did it come that way? My plane is over 5 years old and all the markings were vinyl transfers, although I much prefer painted on markings. Just haven't found a way to do that on foam without pulling the paint off...
                Looking great!
                Davegee
                • Prekin
                  • Feb 2021
                  • 135
                  Dave, unfortunately when I opened the box all decals were already placed on Spitfire. :rage: Roundels on fuselage are waterslide decals same as nomenclature and serial number and tailcode. Unfortunately they do not use softer in FL factory, so will have to repaint them. I prefer if all those details are painted. Just like in real. I painted them also on FL B-24.
ID:	371841Click image for larger version
ID:	371840Click image for larger version
ID:	371837Click image for larger version
ID:	371843Click image for larger version
ID:	371839Click image for larger version
ID:	371844Click image for larger version
ID:	371842Click image for larger version
ID:	371838Click image for larger version
ID:	371845​Click image for larger version
                  • kallend
                    • 1877
                    Is that the anti-submarine livery? B-24s sank more U-boats (72) than any other aircraft type.
                    • Prekin
                      • Feb 2021
                      • 135
                      Correct. That is RAF Coastal command paint scheme. SQN no.311. "PP Z" GR.Mk.V with dumbo radar in nose and GR.Mk.VI "PP K" (Kosťa).
                        • Nov 2013
                        • 2783
                        • Cody, WY
                        Hi Prekin: Splendid job on your B-24 models! What kind of tape did you use for masks so that they wouldn't pull off the previous paint over the foam? Painting on decals or markings in my book is the Only way to go, if at all possible. I've had some attempts at it on foam, but usually with poor results.
                        My FL Spitfire is almost 6 years old, and I think it came with no markings at all already applied at the factory. I painted mine up in the colors of one flown by Witold "Lanny" of 302 Sqdn before he and other Poles joined into the 56th Fighter Group of the USAAF. I had Callie make the specific markings for that plane, but used the stock roundels that came with the kit that are showing signs of age and slight peeling and chipping in spots.
                        Thanks for any info on how you did your maskings on your beautiful B-24s!
                        Cheers
                        Davegee
                        • Prekin
                          • Feb 2021
                          • 135
                          Thank you Dave for kind words, I’m glad you like the Liberators!
                          The yellow tape is paper masking tape. Similar like painting masks for plastic kits. The blue vinyl is 2 year vinyl decal foil.
                          Whole B-24 was painted by the white full synthetic paint. That was good base paint and no etching layer was needed.
                            • Nov 2013
                            • 2783
                            • Cody, WY
                            Thanks for the info, Prekin! Great job!! Do you have a source for where I could purchase the vinyl decal foil and the paper masking tape. I'm not too familiar with those.
                            Davegee
                            • Prekin
                              • Feb 2021
                              • 135
                              Davegee
                              The masking tape is in hobby shop and vinyl decal foil you can buy in advertising office or car shop.
                                • Nov 2013
                                • 2783
                                • Cody, WY
                                Cool! Thanks!
                                Davegee
                                  • 7418
                                  Yep, mine came with several sheets and no decal installed. Flightline has decided not to send out sheets and install one set of decals. PITA if you ask me.
                                    • Nov 2013
                                    • 2783
                                    • Cody, WY
                                    PITA, indeed! I don't know why they went to that decision. Nothing against the original livery schemes and those famous pilots, but I seldom go along with the original paint scheme, opting for my own, instead.
                                    Thanks for that information, anyway.
                                    Davegee
                                      • 7418
                                      Same here Dave, a lot of my planes are not the original livery and some have substitute decals like the Flying Tiger insignia:
ID:	371985 And my Spitty is definitely not a stock option as she portrays 'Skipper's' Spitfire in the movie The Battle of Britain
                                      So when we have to deal with removing decals to apply our own, especially when that was not the case with the original releases, well PITA!
                                      I knew the Bearcat went that way but this is the first I've heard of the Spitfire so I guess we can assume that all FL airplanes are going that way. I wonder about the Freewing jets?
                                      • f4u ausie
                                        • 1242
                                        • Melbourne
                                        My spitfire came decals and all pre applied.. was expecting ,couple decal sets... oh well... would have thought the labour to install them, would cost more than giving u couple options and do it yourself... they however are nicely done .. i assembled it 1week ago.. just waiting 4 maiden asap....:partying_face:
                                        • Prekin
                                          • Feb 2021
                                          • 135
                                          Not sure how about FW jets, but FL Corsairs still come clear with all decals on extra sheets. I read, that work with large decals on Spitfire was big pain for some customers, so they decided to make it easier for those. In my opinion, there should be 2 options for Spitfires. With decals and decals on extra sheet.
