View Post
Hey all, so I've had my Corsair since mid March, and I'm finally getting to put some time into it. I got it all together and testing all the Servo's etc. I've skimmed thru the forum and I think I am having a similar 'blue box' issue with the tail wheel. With gear down I have zero tail wheel or rudder control. With gear up I have full rudder control. So I've went so far as to hold full rudder while bringing the gear down and the rudder becomes stuck in that full throw position. Then I can move all the controls and at some point the rudder and tail wheel jumps erratically and the rudder becomes un stuck, but then no control on either (tailwheel/rudder) from that point. I have noticed that if I do a lot of alerion movement with the gear down it causes the tail wheel to jump here and there as well. I haven't notice any loss in elevator or alerion control at any point. I'm going to try the direct y-harness and see how that goes, but obviously this is pretty concerning.
Originally posted by sfcfury View PostHey all, so I've had my Corsair since mid March, and I'm finally getting to put some time into it. I got it all together and testing all the Servo's etc. I've skimmed thru the forum and I think I am having a similar 'blue box' issue with the tail wheel. With gear down I have zero tail wheel or rudder control. With gear up I have full rudder control. So I've went so far as to hold full rudder while bringing the gear down and the rudder becomes stuck in that full throw position. Then I can move all the controls and at some point the rudder and tail wheel jumps erratically and the rudder becomes un stuck, but then no control on either (tailwheel/rudder) from that point. I have noticed that if I do a lot of alerion movement with the gear down it causes the tail wheel to jump here and there as well. I haven't notice any loss in elevator or alerion control at any point. I'm going to try the direct y-harness and see how that goes, but obviously this is pretty concerning.
I have had my corsair up 5 times now. She handles good but lord is she slow. Not so slow that it is nearing stall speed, it seems to have decent power but there is not much difference between 50% throttle and 100%. My telemetry showed 61mph upwind and 69 down wind. My 1700mm seems to fly with much more authority upwind 82 and 90 down wind. I have recalibrated my esc, and no difference. I am using the admiral 6s 5000 50 c. Anyone else having this scenario?
Originally posted by Crazystick View Post
OK , I had about the same experience with mine , using Spektrum radio, 7 ,8 and 9 channel Spektrum rx , changed to 6 channel rx and all was good , go figure . About 2 months ago I lost the RF board on the tx , ( 6 yr old radio ) and crashed the Corsair , still repairable but have not done anything to it yet , soon I hope
Ken
Originally posted by Ken Smith View Post
Just to let you know you can send in your radio for a check for shipping and parts if needed.I send my DX9 in yearly for cleaning and checkup. Last cost was about $12 for shipping to HH , they shipped back at N/C. Good peace of mind. Could be a great savings in the pocket.
Ken
Originally posted by apmech1 View PostI have had my corsair up 5 times now. She handles good but lord is she slow. Not so slow that it is nearing stall speed, it seems to have decent power but there is not much difference between 50% throttle and 100%. My telemetry showed 61mph upwind and 69 down wind. My 1700mm seems to fly with much more authority upwind 82 and 90 down wind. I have recalibrated my esc, and no difference. I am using the admiral 6s 5000 50 c. Anyone else having this scenario?
Once it's been calibrated, you can (if you want to experiment with it) increase you servo travel for throttle to more than 100% to see if it will get you a little bit more. In general, it won't but won't hurt to give it a try.
Insofar as this Corsair's speed compared to the FMS Corsair, I'm using the same 4-blade prop as on my FMS Corsair and the speeds of both are fairly similar, perhaps the FMS is a bit faster but that may be an illusion due to the bigger size of it. As for acceleration, the FW/FL Corsair has a lot more "get up and go" since it's much lighter. With the 3-blade stock prop, the smaller Corsair should be about the same speed. Again, since I haven't installed my airspeed indicator on the planes, it may only be an illusion.
- Likes 2
Originally posted by karltrek View PostSending the Multi Function Control (Blue) Box to MotionRC. They want to check it out.
once I get to it I think if I can get the tail wheel to deploy fully I will unplug it. I had so much going wrong at the field I never got back to does the rudder work when the retract does not fully deploy.
JoePlatt: fw190d9 Dynaflite:PT-19 IMP:Macchi202 ESM:fw190 ESM:Tank, Hien Jackson:DH-2 BH:macchi200 Extr:fw190 Holman:me109F H9spit2 FL:F4u,spit 9 FW:me262 GP:us60, Stuka, cub, F4u PZ:me109, albi EF Hurri, T-28 FMS: 2x fw190, me109 Lone Star:Skat Kat RSCombat:2xfw190d9
Originally posted by paladin View Post
after winter, and the april and may showers I got the corsair out to the field sunday for maiden. I did notice that the tail wheel was not deploying completely. soon after I noticed when I powered up the flaps would go to half setting. checking my radio it was not. moved the slider then the switch and no flap movement at all. finally I plugged the flap plug from the blue box to the aileron socket in the rx and still no flaps. removed and powered up again and the flaps went to the half way position and did not move after. I had already removed the ailerons, elevator and rudder from the blue box. tonight I plan to remove the flaps as well.
Joe
I'm sure your aware as I am having both worked in the electronics manufacturing zone that these limited/non high volume circuit builds could be skedgy due to traces, etc from hand solder layout.;)Warbird Charlie
Originally posted by CorsairJock View PostFull scale Corsair flies at 400 mph top speed. At 1/8 scale, 50 mph would be scale. So question is, how much faster than scale do you want to go? I'm flying mine on 5S 5000 mAh, and am very satisfied with speeds, and LOVE climbing ability even on just 5S. That big prop really pulls.
wouldn't it be great if we could then the 30mph wind on our corsair turns into a 3.75mph wind. we could fly everyday!
Originally posted by Hardway View PostLOL You can't scale air... Bummer though. The J3 Cub flies just fast enough to kill you if you crash! :Scared:;)
As for this question ........................how much faster than scale do you want to go?
PS. My FMS Corsair whistles when it comes diving down over the runway. (You know - "whistling death"?) My FW/FL Corsair does not whistle. That's not scale, is it? But I'm OK with that.
BTW, I've seen RC models of flying Dumbo. So, what's the "scale" speed for Dumbo? I mean, just how fast can a real elephant fly? Can anyone remember? And what about pigs? What's the "scale" airspeed for pigs? I recall someone saying it's about 25 snots and any faster than that, is oinkless. :Silly:
- Likes 3
