I'm half tempted to get her and her mate and attach IR receivers to them for target practice. But thought it would take too long to teach them to roll over and play dead after 6 hits!
Well I got another excellent Heng Long T72 added to the inventory. This one was specifically built for use as a “loaner” tank at the regional club events/battles I attend.
It has almost completely stock running hardware, but was given a new non standard look. The theme for the new look is “up armor & advanced optics”. I also added one of the new LegoDEI 6.0 HL battle receiver. It can be seen peaking out of the “loaders hatch” opening.
Note: 99% of the parts used to create this “up armor” look are “off the shelf” HL parts (T90, ZTZ99 and Abrams).
More photos and videos of this and other tanks can be found on my Instagram @ fsttanks so feel free to check them out.
Heng Long T72 “Up armored”
Heng Long T72. “Desert” (left) is fully modified and “Up armor” (right) is mostly stock running hardware.
Since, as yet, I have not connected with anyone local for scale tank battles, I had to go against the only other tank that I know of nearby. This one resides in front of a local automotive repair shop. Alas, the shots I took at it didn't seem to have any effect on it at all.
6 PhotosComment
...as long as you don't give her any BB's! :astonished:Comment
Thanks Prowler! My process is "dirt" simple. (Remove the track, of course) These are plastic tracks. Spray them with flat aluminum or steel, Tamiya or Modelmasters, I can't remember which. Gotta be flat. Then I use Modelmasters "Light Earth" spray and give it a light overspray coat, so the steel shows through. The variances in how much spray is fine, just do light sprays from a little ways away until you get the effect you need. The sprays won't affect the track function unless you pour it on. It stays on even though rough offroad use!The more screws it takes to reassemble a tank, the more likely it is you left something out!Comment
Heng Long T72 rear end photo of how the recovery log is attached.
^^^^^ Log usually does not hit obstacles But when it does it saves the fuel drums from being ripped off.
vvvvv Below is a close up of how the log attaches to the rear hull. I used wire for a more realistic look and stronger attachment vs the zip ties HL recommended.
