  • Clugh
    The pyro 800 hybrid already had the delta coils secured with the boron nitride infused since I have the room with the securely out the way I'm going to mixed gauges. For the wye coils I plan to use 15 AWG. Both machines are ready for the open wye coils to be wrapped.
    My rotor bell is super clean and the PM is nice with uniform spacing around the can.. :stuck_out_tongue:
    Thanks for you time and patience.
    TTYL
    Hubert
  • Clugh
    Since the HK 5020 is already laced with 9 turns of 13 AWG 1.828mm. I'll wind a 5TY+ 9TΔ. I'm pretty sure I can fit it or get close. A parallel version can get good fill because it is a single coil winding on all 12 teeth before you terminate it. See all 12 slot wedges sticking to the pm. I wont install them at first so I can look at just the hybrid winding effects.
    Thank you for your time and patience.
    Huber
  • Clugh
    From left to right if you look at the 2nd and 4th attachments in the previous post you can see all the slot noise that unwantedly effects flux density. The slot wedges reduce the noise as the permeability of the wedges increase.. They also increase the peak flux density when selected correctly. You can observe that data in the 3rd attachment above..
  • Clugh
    The theory.
    4 Semi-magnetic slot wedges
    ​The use of fractional conductor windings can modify (fine tune) the winding factors of the synchronous machine. These winding factors feed-forward to the air-gap flux density wave via the armature reaction MMF wave. Altering the winding factors has no effect on the stator slot permeances that have a large influence on the resulting air-gap flux density wave. The stators of large generators are usually designed with open slots and closed with a high temperature plastic or glass-fibre slot wedge to assist with keeping the coils in place. Open slots reduce the output voltage quality of generators and also degree the performance of motors – pole face losses increase significantly due to the increased air-gap harmonic content [6]. Fig. 5 shows the wedge placement in a parallel tooth synchronous machine.
    There are commercially available semi-magnetic slot wedges [5]. These wedges have >1 relative permeability in the range 2 ≤ μr ≤ 10 and have been shown in single-tooth wound synchronous reluctance motors to reduce the harmonic content in the air gap by modulating the flux density wave via the permeances. It is possible that combination of reduction in pole shoe surface iron losses, reduced voltage THD, reduced field current, and improved efficiency energy conversion efficiency can be achieved by adopting correctly designed semi-magnetic slot wedges​
    Click image for larger version  Name:	experiment3.jpg Views:	0 Size:	112.1 KB ID:	429837
    ​Finite element studies can be used to determine the radial component of the air-gap flux density. The slot wedges shown in Fig. 5 have their relative permeability modified accordingly; 1 (normal wedge) ≤ μr  ≤ 100 (high permeability wedge). Transient motion analysis is also performed to determine the eddy-current losses in the pole face of the salient rotor poles. Fig. 6 shows the resultant radial air-gap magnetic flux density plots across a single rotor pole pitch in machine with different wedges, Fig. 7 shows the radial flux density harmonic decomposition, Fig. 8 the residual magnetic flux density over a rotor pole pitch and Fig. 9 the eddy-current distribution over half a rotor pole pitch.
    As is clearly evident from Fig. 6, the stator slotting permeance causes significant variation of the air-gap flux density over the rotor pole face.
    This leads to harmonic losses in the rotor pole surface and increased armature voltage harmonics, both of which are undesirable. By introducing the semi-magnetic wedges (here we must note that the wedge permeability is much less than the stator lamination steel), there are two observations;
    • (i) Increased fundamental flux
    • (ii) Reduction in the high frequency slotting harmonics
    The increase in the fundamental flux is attributed to the shortening of the effective air gap, the Carter factor for the stator is reduced, and hence the effective air gap is smaller. The Carter factor is usually computed via conformal mapping assuming that the steel has infinite permeability and the stator slot opening has a relative permeability of one, this effectively enlarges the air gap – this effect is reduced with semi-magnetic slot wedges.
    As a consequence, the fundamental voltage capability for the machine will increase slightly, or the required field current for rated air-gap flux will reduce along with the associated loss and temperature rise. Second, due to the reduction of the discontinuity of permeability in the slot opening, the stator slotting permeance function becomes less pronounced, reducing the high-frequency slotting visible in the air-gap flux density waveform for a machine with conventional wedges
    Use of fractional-conductor windings and semi-magnetic slot wedges in synchronous machines
    Christopher Donaghy-Spargo, Anthony Spargo
    First published: 14 May 2019
    https://doi.org/10.1049/joe.2018.8205
    Citations: 3
    You can always cut the overbearing CL off Docta...and try to make new friends that will not constantly try to force you to build a 41** LMT
    ​YT,
    Hubert​
  • Clugh
    Hi,
    You have to be a member and signed in to see the photos from here on out. :stuck_out_tongue:
    I'll leave data when its complete with a new winding.
    But check out the 3DP semi magnetic slot wedges I made for a higher efficiency Scorpion HK5020
    Thanks
    Hubert
  • Clugh
    Muncie.is right around the corner....:pray:
  • Clugh
    And why are you not testing "syncloss" now for Audisosmith? I bet you dont even have a AC amp clamp or DC wattmeter on the bench. feeding the inverter. You have a scope dont you? Why haven't you captured the BEMF waveforms the comparative motors make using the scope in FFT mode and calculated the Thd using a prime mover to drive the motors as generators ?
    The Comtrol YY motor works perfect as a prime mover the new motor is the perfect brake
    Drive three halogen candles with the motor terminals and the load is on when all three open end are shorted to one another. You can do that with 3 transistors and vary the load with duty cycle at the on gates. You can even use another inverter connected to the braking motor in active freewheel on the battery end you can drive a dc load, recharge a battery, or strap some type of braking resistor across it. Heater elements will work.
    What data and capture equipment do you have Dr Okon besides unilog.?
    Where is the control Y or YY motor at the same or similar Kv and its constants Dr Okon? You forget scientific method when you test things?
  • Clugh
    #2 was a 12 turn YY wound with 1.25mm. So only 1 turn more than the hybrid and it had larger wire. Do you see what the idle current Kv and operational temperature rise from ambient was Dr Okon.
    P700 YY
    12 turns parallel wye in 1.25mm
    Copper cross section 14mm^2
    Kv 527
    Io 2.7 amps @ 20 volts
    ΔTemp @ 5min from ambient = +5 °C
    P700 Hybrid
    11 turns (4T)Y + (6T)Δ in 1.20 mm
    Copper cross section 12.4mm^2
    Kv 410
    Io 1.51 amps @ 23 volts
    ΔTemp @ 5min from ambient = +3°C
    Only you cant see the writing on the wall. and yours never agrees with academics and is always a secret. BTW you notice Docta at WOT, which is six step for yge's, the larger wire dual layer YY with more fill ran hottest of all the motors on the YGE at 8khz pwm and zero degrees timing???? In a dual layer It will have the most sinus like waveform away from BLDC drive mode of the inverter so torque ripple is maximum with it at full throttle with the YGE.
    No one even records idle current amperage to the 3rd decimal. Tell another story or show them the incorrect routing and motor constants that came with it. You never showed the backside termination of your hybrid wound motor for the forums.
    :face_with_monocle:
    TTYL
    Hubert
  • Clugh
    Click image for larger version  Name:	image.png Views:	0 Size:	73.3 KB ID:	429799​The Hybrid P700 does a lower Kv with 4 less turns than a YY and it ran cooler despite less fill. and at a significantly lower idle current. Less turns in this case made it much lighter than all the other motors in the Cambridge test but with 4 less turns you can run alot larger wire with it. Larger wire with less turns drops the DCR. The mis already wound with a larger wire than the YY 1.15mm to 1.20mm
    The YY's idle current is 2.1 amps at 18.9 volts the hybrid is 1.51 amps at 23.49 volts After 5 min The YY who's idle would be even larger at the same voltage ran at 33 degrees Celsius the hybrid 24 degrees Celsius
  • Clugh
    Click image for larger version  Name:	image.png Views:	0 Size:	154.4 KB ID:	429794​Yeah that's wtf I thought! You still HAVE NOT left a single unit of data. o youre still a full joke to US but figure you better wind ya HK and test it before I leave them the real data. And what measuring equipment you use when you are not testing the right way nor are your reporting the idle currents. You still think your friends in Germany and American are stupid huh? Funny how my post drummed the bs back up again. Silly man hiding his comparative constants on a motor he says he has no use for but he is testing it again and still asking for data. You're so damn bright and weird you cant realize nobody in the world has any data to offer a clown but the English speaking Anglophiles. ..There's a million ways to test its effectiveness that doesn't require a 10,000 Yokogawa PA WHICH the IEEE top test equipment HAS ALREADY SHOWN THE IMPROVEMENTS BTW ! Despite that its very easy test.for a hobbyist it s obvious to everyone but a moron that loss translate theat. If the pm and bell have reduce loss even close to the projected numbers common sense would tell you you can look at the bell temps oif a motoro in operation and you can always turn a freaking prop and look at consumption. You know all that so please continue with the Minstrel show. You rather me expose you step for step. Ok cool go ahead with that. Let US and them understand .You're interested in anyone's data on a motor winding your application has no use for? We're glad you finished your unreported data yet still have interest. You really think the hobbyist are stupid....and cant see the dents in your reptilian armor No one In the world has any data on the external rotor hybrids but POCBOY....That's why you are here in class. Remember? Dr Okon You haven't posted a single thing of any scientific comparative relevance YET! I also see you aint ask ya buddy in Bayern or explain why it wouldn't be suitable for a hobby speed plane LOL!. See how you skew fact and I expose it easily? That always happen with fact versus fiction. Do you expect different results if you keep lying? It is mania, the sudden shift in opinion and emotions, u 2 go through daily. Its like menopause.
    "If someone tests this as well and comes to different results, I would be a bit interested."
    "As written:
    if someone should find out otherwise, I would be interested.​"
    ~Dr Ralph Okon~
    "The no-load currents show differences max. in the (unreliable) 3rd decimal place."
    And I know that's a lie there's no way the idle current is the same... what would you need any more comparative data if the phase resistance was the same with no change in idle current between the two machine that run at the same Kv The hybrid is a slower machine for sure therefore it can also hold larger wire becuase it uses less turns. Thats clear in the P700 data from the "Anglophile" in Cambridge UK!
    This is why real engineers leave data and not social media mania. Its even more simple why he wont leave any constants because that would mean someone could check his falsified recollection of data.
    Where are the recorded comparative motor constants on these 10 and 14 pole motors you supposedly and fairly tested with the control wye wound machine dude? Comparing a 10 pole motor and a 14 pole motor on the hybrid winding isnt a comparative test . The effect will be exactly the same on both engines.
    Click image for larger versionName:	Hybrids1.pngViews:	0Size:	204.5 KBID:	429795
    Where is the control wye wound motor and its constants Dr Okon??????? or you trying to confuse the forum again by comparing things not in question like two different pole rotors on the same wind .
    :woozy_face:
    Hubert
  • Clugh
    Click image for larger version  Name:	ralph.png Views:	0 Size:	114.7 KB ID:	429787 Click image for larger version  Name:	100_2588 (1).png Views:	0 Size:	98.4 KB ID:	429789
    Ralph Okon!
    I bet you wont ask or tell Christian Lucas directly in that German thread exactly why a hybrid wind work for your application and any other e traction application in hobby or recreational that use a 12 slot 10 pole machine.. And he wont ask or tell you a good reason either!
    Or you both could come out the closet Click image for larger version  Name:	shocked.gif Views:	0 Size:	542 Bytes ID:	429790and answer me here directly since you are both here. You know you both are posting a bunch of nonsense over there in Germany!
    You laid up together now AFAIC which is incredibly funny but you see the data here on the subject matter....you two got some???
    :pop
    Danke,
    Hubert
  • Clugh
    A serial wound 5 turn wye + 9 turn delta hybrid on the Pyro p650 is going to bring a Kv of approximately 536.@ 1o degrees timing on the castle Hydra Ice HV 200 v2 there would be numerous ways to route it and still end up with the equivalent circuit just like the conventional windings. You can also wind hybrids with only 6 wires and no solder points if you know how.. but a proper silver solder join creates a cooling sink right at the connection nodes of the delta and wye machine.
    Click image for larger version  Name:	image.png Views:	0 Size:	57.4 KB ID:	429785
    perfect attendance....​:heart:
    You know you need a weekly regimen of medication too because you could just talk to me and make these ridiculous proclamations you are in Germany right here direct Ralph... You plum crazy just like Luke cap.
    Tell me is this deep GER-mania u2 suffer from?
  • Clugh
    Click image for larger version  Name:	y-d.png Views:	0 Size:	804.3 KB ID:	429777
    KONTRONICS PYRO P700
    4 turn wye + 7 turn delta Hybrid
    :see_no_evil:
    Click image for larger version  Name:	Untitled (1).png Views:	0 Size:	167.4 KB ID:	429778
    Have a close look at number 3
    Americans motor heads can determine from the Kv and no-load currents and turns counts compared to the conventional windings if there is an improvement in efficiency. Its enough here to make that obvious determination if the Dr and his friend in Bayern know anything about electric motors and physics which they do, so they are a sad couple when they play laurel and hardy and concurrently falsify information about electric motors on the GSM.
    They both are already aware of this data. Click image for larger version  Name:	Doh.gif Views:	0 Size:	976 Bytes ID:	429781
    This crazy alter ego powercroco doesn't need any data from his German forum colleagues to compare when he knows full well they do not have any Click image for larger version  Name:	naughty.gif Views:	0 Size:	343 Bytes ID:	429780
    This was the first attempt by a hobbyist, so the doctor has to work on his skills, because as you can see, it fit, the engine was running and the data came along..
    What's the doctor's problem, guys?​
    Pure nonsense!.... Click image for larger version  Name:	killcomputer.gif Views:	0 Size:	339 Bytes ID:	429779
    Wenn er die Kabel nicht richtig verlegen kann, ist das sein Problem, nicht Ihres!!! Der Grund, warum er diesen dummen Thread überhaupt gestartet hat, ist, dass er seinen eigenen Thread wegen der Schuld des Witzbolds nicht wieder eröffnen kann.
    Click image for larger version  Name:	Jester.gif Views:	0 Size:	401 Bytes ID:	429782
    He tells you his application has no use for it which is VERY false but still what about all your own individual applications readers....:scream: Do not listen to it. It's nonsense!
    TTYL
    Hubert
  • Clugh
    Das Komische, Dr. Okon, ist, dass ich auf Ihrem Bild sehen kann, dass Sie den Hybrid mit einfacher Stern-Dreieck-Schaltung gewickelt haben. Es handelt sich nicht um eine Parallelschaltung wie bei mir, daher sind Ihre Kabel lang, genau wie bei einem Motor mit einfacher Stern- oder Dreieckschaltung. Die Verwicklungen durch Ihre Verlegung sind Ihr eigenes Problem. Schlagen Sie es nicht als Problem für andere vor, denn die gleiche Version wurde mit dicken Drähten auf einem 700er in Cambridge, Großbritannien, gewickelt.
  • Clugh
    So don't be too confident about his thumbs up in agreement to your statement about the hybrid.. He only put that thumb up ya booty because he is still here and tries to remotely to annoy me.
    He knows the winding works and works very well ,so please be careful with the company you keep Dr Okon....
    You see he said no one on the forum knows anything about electric motors especially the crocoman, so I wrapped it all up for you in a 4 post package so the.modus operandi in Bayern is understood by all the thumbs
    He can offer you a thumb to tickle your fancy but not any empirical data on the star - delta hybrid winding on 12 slot 10 and 14 pole external rotor BLDC machines like you inquire about.
    :gift:​
    Take care....
    Hubert
  • Clugh
  • Clugh
  • Clugh
  • Clugh
    Hi Dr Okon.
  • Clugh
Name:	Magnitizer and magnetizing circuit.png
