  • t33jetman
    • 515
    Click image for larger version  Name:	20180403_050740.jpg Views:	1 Size:	86.1 KB ID:	126805Click image for larger version  Name:	20180403_050716.jpg Views:	1 Size:	69.6 KB ID:	126806Click image for larger version  Name:	20180331_125355.jpg Views:	1 Size:	147.5 KB ID:	126807 nothing earth shaking, just wanted to remove my tanks and pylons ,so I will put screws in this to remove both. This will be good when I want to just go clean and fast.o
    Glue tail hook like this so the rear cover and hook can be removed for inspections later.
    Replaced all control rods with thicker one's for solid control and no flutter. Also the elevator removed and blocks glued in and servo can be screwed down. Click image for larger version  Name:	20180331_125238.jpg Views:	1 Size:	103.8 KB ID:	126808
    • t33jetman
      • 515
      • Radar-Guy
        AirBorn Jetworkx
        • 364
        While admiring the plane during the wait for my JePe Storm fan (I hope to collect it next week) I discovered that the paint scheme in the tail area is somewhat inaccurate. There is too much "bare metal" applied. I used the MiG Ammo colors (great match, thanks to Alpha for the recommendation) to get a more accurate look.
        Frank
        • ryramZ
          Pilot Ryan
          • Dec 2012
          • 814
          Go Navy! Progress on "Red Rippers" from the Forestall
          • Radar-Guy
            AirBorn Jetworkx
            • 364
            Nice, but add more grey color to the tail above the exhaust area, please ;)
            • ryramZ
              Pilot Ryan
              • Dec 2012
              • 814
              I will. I saw your post after I did it. Doh!
                Originally posted by janmb
                This will be awesome indeed!
                What plans have you made this far for releasing the line? Needed in terms of safety as well I'd imagine...
                Hey Jan and Boots, after further consideration it would be fairly easy to go ahead and add a controlled release feature so I will most likely go ahead and do that.
                • bbaumer
                  • Jun 2017
                  • 152
                  • Indiana
                  I was thinking you could add a mix that prohibited that servo from functioning while gear was up and throttle was above a certain level, that wouldn’t stop an accidental malfunction, but it might keep you from hitting the wrong switch at the wrong time
                  • gooniac33
                    The Original Gooniac
                    • Jun 2016
                    • 1047
                    I am clearing out some planes before I get this bird but have seen 2 fly to date and love it!! It flies great in stock form but I never leave planes stock...LOL I have several different set ups to try. My F-15 has a 13 blade set up that is working really well so far but there are still others out there to experiment with as well. I love the 12+ blade sound over anything less.... the challenge will be fun!!
                    • purduephigam
                      Jet degenerate
                      • 352
                      • Plainfield, Illinois
                      You know what else sounds sick? The new F4 sound clip from Shockwave. Prelim install was last week, and I'll be finalizing everything and hoping to finish the build this weekend. Pics/video to follow :Cool:
                      I can't leave anything stock myself LOL
                      • janmb
                        Slow and low
                        • 729
                        Well, if you don't, you have to be REALLY sure the chute never accidentally releases mid flight..
                          If a chute did deploy mid-flight I wonder if it wouldn't necessary be a catastrophe assuming you would have to increase power and land as quickly as possible at a higher throttle quadrant then normal. Yes? No? Who wants to be the test pilot?
                          LOL
                          • Helmsman52
                            • 247
                            • Saint Paul, MN
                            I must give credit where credit is due. Helmsman52 (Paul) has been hugely instrumental in helping to come up with what you see. I may have brought the parts together to make it work but Paul is the one who had the idea to use the existing CF tube in the tail section to make the spring loaded release mechanism. He is a very clever individual. ;)I just ran with his idea and I like how his chute turned out so I will be making one like his.
                            Hey thanks for the props! Glad you could make out my kindergarten drawingsLOL:Cool:
                            • Helmsman52
                              • 247
                              • Saint Paul, MN
                              LOL
                              I’m going to say, with the slot chute that I made, no problem if it is accidentally deployed because of slots and 1/8 shock line that has plenty of give but if it was not slotted? It’d be one wild ride :Silly:
                              • navy0968
                                Naval Aviation Vet
                                • 6
                                • Pinecliffe, Colorado
                                Nice progress on your Navy Phantom Ryan!! Sure wish Motion would move forward and offer a primered version of the F-4 as they did with the BAE Hawk. The transition to Navy colors would be SO much easier and my bet is that they would sell a ton of them to people who are holding back like me. Just finished a conversion of my primered FW Hawk to T-45 Goshawk with "Redhawks" graphics and it was a fun project. Would sure like to do the same sort of thing with the F-4.
                                  Good point on the slot chute versus not being one Helmsman52!
                                  navy0968 beautiful job on your Hawk!
                                  • spec450
                                    low altitude record holder
                                    • 124
                                    • Hanford, Ca
                                    The B-47 had to deploy its chute prior to landing because the J35 took so long to spool back up in the event of a go around. The chute added drag with higher engine RPM. If your chute comes out Just land at full powerLOLLOL
                                    Current Fleet: Flightline Tigercat, Flightline Bearcat, Eflite Corsair, ESM Skyraider, Pilot RC Yak-54 30%:corsair
                                    • PikeStaff
                                      Happy.
                                      • 74
                                      • St. Augustine, FL and Perkasie, PA
                                      Ask our co-conspirator Bobaroo about unintended/accidental deployments:
                                      Granted, it was on a 70mm Phantom....but it’s likely the 90mm wouldn’t act much different, slots or no.
                                      • MANFRED
                                        Any Warbird, any time
                                        • 299
                                        • San Diego, Ca
                                        Just some eye candy for you F-4 drivers. I am lusting for my 8s to arrive. I grew up 5 miles from Davis Monthan and among other famous ships, the F-4 was a daily part of my life as we were under the landing pattern. Heavy and loud! Witnessed one go down into a shopping center after engine failure, unfortunately, several people on the ground were killed.
                                          A friend of mine did paint matching at Home Depot for the greens. Says they match perfectly!
