Official Freewing 64mm Lippisch P.15 Thread
    You had to cant the verticals out, didn't you??? LOL I would have done the same. I am OCD and straight verticals are not cool on a twin!!!! HA!!!! LOL
    Nice
      Nice
      Yep, couldn't stand it :Silly:
      • tclaridge
        Instructor Pilot
        • 141
        FOIL is finally revealed! Thanks TiredIron.
          Why hasn't anyone else done a twin? It's twice the fun:Cool:
            • 8835
            There was a time I would have jumped at this. In fact, I made a twin FliteTest Viggen. However, in this case, my Lippy is pretty well used and a bit beat up. If I made a twin, I'd have one that was brand new and shiny on one side and really gross looking on the other side. I'm just not willing to buy 2 more new Lippy's.
              Has anyone else done a "Lips" Twin Lippisch...and if not, why...this thing is a blast?
                That thing is so cool!:):Cool::pop
                  Here's a video Steve shot at the Fall Fly-In...
                  • McLogo
                    • Aug 2018
                    • 36
                    • Switzerland
                    Unfortunately the summer is over and it's quickly getting cold and rainy were I live.
                    I'm however very happy to have started the awesome hobby of rc flying in July 18 and also with the choice of planes I did get so far.
                    The P.15 is just awesome and I will start going from there to larger edf's in the next season.
                      Good to hear, this is by far the best hobby I've ever been involved in and I have meet some of the best people who I can now count as great friends!
                      • McLogo
                        • Aug 2018
                        • 36
                        • Switzerland
                        Very true sir!
                        I've joined a local club with great people and have learned a lot online and from club mates. It's inspiring to see your awesome work and group with all the enthusiasts :Cool:
                        • Dmonhellcat
                          • 7
                          just bought one, had to make it more visible, hopefully I don't mangle it on it's first flight! :Confused:
                            Very cool!!!! Turn down the aileron and use a lot of expo and you will be fine.... Welcome to Hobby Squawk!!!
                            • Dmonhellcat
                              • 7
                              Thanks! Maiden flight was today, used 40 rate with 30 expo and a mighty 45 degree chuck, dipped a little then flew out nice and steady, very nice flyer. 2nd flight, same settings but couldn’t get altitude so it just went down into the grass, I think the flat bottom saved it from any damage.
                                Welcome home to Hobby Squawk, Dmonhellcat! You may want a little more elevator for launch, depending on how strong your headwind is (the more headwind, the better).
                                  • 8835
                                  Indeed! Most of my hand launcher have a mix programmed into the gear switch to give a little reflex (UP elevator). I launch this plane as full throttle and the reflex activated. Allow a second or so for the motor to spool up and chuck it. No matter whether I throw it level or with some inclination, the plane just goes straight where it's thrown and very quickly begins to climb. That's when I deactivate the reflex. How much reflex depends on the throwing technique.
                                  The exception to this are my sailplanes as they generally have so much lift even after a weak throw, that they climb anyway. However, I've seen poorly set up sailplanes that have gravitated (yeah, I know - pun) towards a dirt nap.
                                  • McLogo
                                    • Aug 2018
                                    • 36
                                    • Switzerland
                                    Once you figured out how to throw it and with a "launch mode" with up elevator I find it very easy and consistent to launch.
                                    I wonder what the weight/thrust ratio is on the Lippisch as it has more thrust than weight ;) at least on my 3s 1800amps.
                                    • Dmonhellcat
                                      • 7
                                      Hello,
                                      Yes, I wanted to put a mix in for some up elevator on my DX6i but couldn't get it to work (I must have been doing something wrong in the MIX1 setup) so I'll just trim in more elevator and then trim it out once in flight.
                                      Thanks!
                                        • 8835
                                        Originally posted by Dmonhellcat
                                        Hello,
                                        Thanks!
                                        That's what I did before I figured out how to do the mix for reflex. I'd give it 10 to 15 UP clicks on the ELE trim and as soon as it's flying, I'd UN-click the same amount. Doing a reflex mix on the gear switch on an elevon plane is not always intuitive as it is with a "normal" wing.
                                        Here's what it looks like on one of my elevon planes. I have a stabilizer on my Lippy, so the programming for reflex is a little different.
                                        • Dmonhellcat
                                          • 7
                                          [QUOTE=xviper;n160247]
                                          Thanks, I'll try it again
