The easiest way is look down the exhaust nozzles. The 8s is an inrunner motor, the 6s is an outrunner motorLive Q&A every Tuesday and Friday at 9pm EST on my Twitch Livestream
Thanks for reply. I been using 11ms on my large scale gas planes using digital servos and the servos like it better. I will have to rebind my other Freewing jets with 11ms and see how it goes. I’ll start with my Avanti to see if there isn’t any difference while sitting on the bench when using 22ms and 11ms.Comment
Awesome Job Steve! Love the pile of PVC stands in the background! LOL. I always seem to building a custom one! :-)Current Hanger: FW, F4.F22,F14, Byron T-6, Top Flite P-47, Top Flite P-40, Top RC P-51 H9 P-51, SebArt Avanti, Yellow aircraft Spitfire, T Jeti Extreme Flight EDGE, DS-24 Carbon,Comment
Question for Alpha, in the manual it gives a max value of 32mm for the flap setting. They seem like they can go much lower so just wondering if going lower leads to some bad tendencies? Also, any idea when spare parts might be in stock?Comment
It can be landed with more flap, but we preferred the 32mm so that's what made it into the manual. Too much flap and they tend to blank out the stab's effectiveness depending on the AoA of common approaches. Most modelers are keeping the nose up for slower and shorter approaches, so less flap is more often better than too much. For pilots coming in longer and flatter under power, a higher flap than spec'd could be used --your mileage may vary.
Spares should be very soon --call Tech Support and see if they have an ETA yet.Live Q&A every Tuesday and Friday at 9pm EST on my Twitch Livestream
Been working on the F-22. I am doing my standard list of things for all my larger EDF's... First, the EDF unit and ESC come out for inspection. More times than not, there is a screw a little loose, or the connection(s) between the ESC and the motor.Comment
I put the color coding on the 130 amp ESC to match the motor leads. I also cut the tie wrap off the capacitor pack and replaced it with heat shrink. I cut the factory EC5 connector off to remove it and the included 8amp BEC. Then a new EC5 was attached. A new jumper was assembled to add a Castle Creations 20amp Pro, and the telemetry sensor lead for the Spektum receiver. ( 9 channel 9030T) So that is the plan for far!!! Lastly, I am going to make a stand-off for the ESC. It has really nice cooling vents, but when it is screwed down to the plywood mount, no air can circulate.... So 1/16th ply should do the trick to lift the ESC slightly...
5 PhotosComment
Well, I'm glad you guys all got your planes and having fun mine came in missing the aluminunm elevator control horns don't know, when I'll be getting them this is from motion sort of sucks also check your wires from motor to esc mine had one unplugged.
Hi Dan,
The part you require is currently out of stock so I have added your email address to the "NOTIFY ME WHEN BACK IN STOCK" field on that product's page on our website Our system will automatically email you a notification as soon as the product is restocked and available for replacement. Once you receive that email please reply to this Ticket and we will be happy to send it out.
Best Regards,
LOLComment
I expect it shouldn't take long. Still a bummer though.Well, I'm glad you guys all got your planes and having fun mine came in missing the aluminunm elevator control horns don't know, when I'll be getting them this is from motion sort of sucks also check your wires from motor to esc mine had one unplugged.
Hi Dan,
Best Regards,
LOLComment
I looked them up. They seem to be the same, at least on the F-14 and F-15 (FJ308110918) Different number on the F-22, they are ALL out of stock... :-( Sorry. I tried!!!Comment
Just a word of caution on pivot rods for horizontal stab, mine were tight on bearing and had to polish rod to get a push fit. For some one not familiar with ball bearings, you don't want to put too much pressure on bearing or inner race may break out. Just a little bit of polishing and I could push it on rod. Just didn't want any one breaking the bushing, there most likely no spare parts in yet. I did have a strange one setting up plane. I put nose wheel steering on Aux 2 and mixed it with rudder. When I extend the gear, only the nose gear works and no rudder. When I retract the gear both work. I did this on my L-39 as well and it works as it should. Going to recheck every thing tomorrow. Any body have this happed, separating nose gear steering?
Hi guys. This came today and is my Christmas gift!! My wife will be in possession of it until then. I am worried about the ding on the side of the box. Can someone who has opened theirs tell me if this is in a bad place and I should be worried or nothing to worry about?
Thank you so much. Can't wait to get this in the air!1 PhotoComment
