  • adb2@suddenlink.net
    Advanced Pilot
    • Nov 2018
    • 104
    • Abilene Texas
    I would be very interested in that myself as I don't have any triple y harnesses. I could probably solder one but changing the time delay would be the max.:Cool:
    Seems like way back in the forum I remember several fellows talking about resetting the time delay. Even remember one saying he reduced his to 2 seconds. However at my age I have these moments where I remember something that is not correct so you may have to taked my question with a grain of salt.
    • thisguy65
      • 509
      What rates are you guys using? Book low rates?
      Book high rates just seems to be....ALOT.
      My high Elevator is 65%. Been playing around with this one the most.
      Planes
      • bill34207
        Jet Junkie
        • 455
        • Bradenton, Florida
        I'm actually using book high rates on mine running through the A3L gyro. They are a bit much with gyro off but comfortable with it activated.
          • 5416
          Book high rates or higher and also add full span ailerons, tailerons, elevator to flap mix and thrust vectoring! I like a lot of maneuverability.
            Nope, nope and nope. I like smooth and scale for these scale jets...But that's just me. Knock yourself silly with the :Silly: flight aerobatics. LOL
              I'm right there with you Aros:Cool:
                • 5416
                We all have our preferences. Having those throws and the thrust vectoring I can also "toss it around" at a very slow speed. The F-22 has a very wide flight envelope. :Cool:
                • thisguy65
                  • 509
                  Thank you for thinking I could do all that buttt I’m not there yet haha. I did sweet your vectoring and Steve/George plane. One day..one day
                  Planes
                  • papaflyer
                    • 7
                    • wyoming
                    I just thought I would share some pictures of my new paint scheme for an idea if anyone is looking for options . It does help me to see it better when its cloudy. Used stencils from Amazon .
                    • downwindleg
                      • 1279
                      • Friday Harbor, Washington
                      Awesome effect papa. Looks kind of pixelated.:Cool:
                      • downwindleg
                        • 1279
                        The nopes have it by an aileron.:)And seconded by an elevator!LOLI've seen the real thing do some incredible maneuvers but never saw a snap roll or rolling circle.:pop
                          With all of my Freewing V1 and V2 Super Hornets I removed the thrust vectoring. Just isn't my bag. I can see how it is a thrill for some but I am all about flying these jets like you would see the 1:1 fly for the most part. But to each their own and part of what makes this hobby so enjoyable!
                          • Scale Master
                            X USAF Pilot, Commercial IFR Jet Rated
                            • Apr 2019
                            • 86
                            Some pics of my F-22 Star-scream converted to turbine with full metal tail section constructed.:bluecool
                              Wow, sweet!! Welcome to Squawk! How did you paint that scheme? Nicely done! :Cool:
                              • Tanguy51
                                • 60
                                It isn't a paint this scheme coming from calie graphics.
                                  • 4869
                                  SM, Welcome to the "Squawk" and I like your paint scheme, Callie Graphics or not. High-Vis for sure. Best, LB
                                    Nice!!! Welcome aboard! :Cool:
                                    • RC30Flyer
                                      • Aug 2013
                                      • 60
                                      Originally posted by T-CAT
                                      Although the vertical stab. flex doesn't have me worried as it's likely secured well and appears to occur within reasonable amounts, but its it's worth checking the mounting tabs on each of them, on the vertical and fuselage. It makes me curious if gluing the vertical stabs into the fuselage (and still use the screws of course) would allow less flex of those tall and massive vertical surfaces. Around the 55 second to 1:05 minute mark in the video shows the flex well. It is likely aerodynamic factors causing the yaw most, but it's not helping that the vertical stabilizer bases are moving as that could have potential to alter the severity of the yaw action.
                                      From an aerodynamic standpoint, no one pointed out that the camera up front may be creating turbulent airflow causing this... just my thoughts tho.
                                      • thisguy65
                                        • 509
                                        Took my F-16 up in Switching winds gusting up to 22mph. I haven't really flow in wind that high, it would stop and then crank up to about 12-15 then kick up to 22 (highest recorded). Only way to learn flying in wind is to do it. F-22 went up next and I was nervous. Flight was great, few times when banking the wind would catch the tip of the wing and try to push it to a higher bank angle. Landing first I had to abort, came in to fast....rolled on power and came up. Bleed speed sooner and made my descent. As I'm coming down, wind kicks up and is changing speeds. She landed on all three gears at the same time. As my luck would have it right wheel hit a small bump and nose cone came off. I never put the wood piece in there. I was proud of it, even if I had to walk out to get my nose cone. Haha. Most guys weren't flying unless it's a big 100" wingspan.
                                        Planes
                                        • Scale Master
                                          • Apr 2019
                                          • 86
                                          lol thanks boys... and yes its from Callie Graphics, took about 3 hours to get it on, then sprayed a dull coat over the bird. Thank God for those guys.... they make us all look good! Do any of you guys know how to get ahold of RC Jet Dude..... I'm trying to order the F-22 open canopy mod pieces and the Freewing
                                          F-4G Advanced Wild Weasel nose mod.
