  • Dan McKeag
    • Sep 2020
    • 22
    Now that's triple Orsum!!!
    Thanks!
    How did they react? :D
    They were quite impressed. I was able to talk to them for about 15 minutes. They had no idea that models could handle like that.
    • Mikeochs
      • May 2022
      Can someone please tell me..do I really need to jump to the 150esc or is the 130esc fi e for 8s
        • 8831
        I'm using a 120A, HV (for 8s) FMS Predator ESC.
        • SanExup
          • 912
          • Western Wy.
          Having been military and into models for so long I have been part of exhibits and demonstrations during which both the Blue Angels and Thunderbirds and did their routines. At each one where we flew our models at the same demonstration I have to say the models had as much attention as the full scale.
          The whole reason I got into RC was that in high school I went to see the Blue Angels at the Monterey/Salinas airshow in 89 or 90 and someone was flying an RC model of the Blue Angel's A4 with a turbine. There were other models on display as well. But I can wholeheartedly say that was the beginning of my rc flying obsession!
          • Airguardian
            Post Stall Svengali
            • Aug 2020
            • 1686
            • Catalonia
            Now I have another cool story to tell, thanks for that!
            • Mud Duck
              • Feb 2022
              • 46
              Ok F-22 guys, looking for some inspiration on how to best install the receiver / gyro / battery into the cockpit area of the F-22; please share or PM me some photos of your radio installations. Thanks!
                • 5416
                Upper right hand of your screen, filters, show photos only. Also look at attachments on RCG.
                • Abwagner121
                  • Apr 2021
                  • 17
                  Finally getting mine finished. I know that this question has probably been asked/answered a million times but is everyone using book CG. Mine is the 6S hi-po version using the 6S 6000mah batteries.
                    • 5416
                    Up towards the top of the page is a little magnifying glass symbol in a box. Type a term or word in there and it does a search. I just tried "cg" and got four pages of return. It's a cool feature. Not trying to be a smart arse...
                    • Abwagner121
                      • Apr 2021
                      • 17
                      Then why give a “smart arse” answer? Wouldn’t it be more productive to just give an answer to the question?
                        • 8831
                        Give a guy a fish and he feeds himself for a day. Teach a guy how to fish and he feeds himself forever.
                          • 5416
                          OK, book CG works fine. Since that's probably not a good enough answer here is the book value. "150mm (5.9") from the leading edge of the wing at the root"
                          But if you do a search you will get some additional information and opinions. That is the more productive answer.
                          You're welcome!
                          • Airguardian
                            Post Stall Svengali
                            • Aug 2020
                            • 1686
                            • Catalonia
                            I like 165mm.
                              Teach a guy to fish and he goes broke buying a boat and fishing gear.
                              • Drifty
                                Old A/C mechanic
                                • 55
                                • Temperance MI
                                I have some F-22 parts for sale in the classified section. Right wing Horz and Vert stabs, Cockpit and LDG. all in good condition.
                                • Gary9648
                                  • 16
                                  Has anyone had issues with setting travel with either rudder or flaps using the blue ox in the F-22? I have set travel limits for flaps at 100%, up, 80% , takeoff, and 20% for landing and when I switch trough my three position switch I only get up 50% down and 100% down. Also I have set full 100% travel for rudder but only get about 50% travel. Does the blue ox limit travel foe these controls?
                                    • 8831
                                    No issues here and I've got the blue box as is. Flew it again this morning and all works as it should. Did you declare "1 AIL, 1 Flap" in the aircraft type so that you could open up the flap menu and do the final set up there? (This is for Spektrum but it may be the same for other radios.) I also get all the travel I need on the rudder as well. The blue box is just a "collector" (or a series of "Y's"). It shouldn't be limiting anythng. If you need more travel for the rudder, perhaps use different holes in the servo arm and/or control horn.
                                    • Iamrcpilot
                                      • Jun 2021
                                      • 13
                                      I am rebuilding my F22 and I do not remember how the nose gear doors are setup. Can someone post pics of the door linkage/servo setup? Any help would be great.
                                      • Iamrcpilot
                                        • Jun 2021
                                        • 13
                                          Here you go.
ID:	346748Click image for larger version
ID:	346749Click image for larger version
