I looove the low viz...but i also really dig the 70s schemes
I haven't flown this, so take whatever I'm saying with appropriate skepticism. I've been considering this model with AS3X for some time now.
Whenever I've seen this bird fly, it looks and is described like being two separate planes. Wings out it is docile, wings in and it loves to roll.
I've always thought that AS3X would be ideal. Separate flight modes with separate and appropriate stabilizing for each wing state seems like an ideal setup. More roll gains when swept than when extended.
What I haven't determined is wing type. When swept back the wing type may need to change. This is not within the capability of the AS3X programmer. Therefore finding settings and mixes that are meaningful for each state would need to be programmed into the receiver. This is quite possible, but I have no idea how it would interact with the box.
It is possible to test the interaction by hooking everything up, and setting your initial gains and include heading hold. Heading hold will hold the control surfaces in place while you manually move the model around. Just be very careful to turn it off before you fly.
Gilatrout all the reasons you stated are why I’m wondering if it is actually going to work at all with AS3X. See I am running ar9350 AS3X in my f18 and f22 and spent a loooong time trying to figure out tailerons for both planes. The issue is that, as you know you must program all your mixes through the receiver so it knows what flight surfaces to interact with and what surface does what. You are supposed to be able to mix channels this way but no matter how I tried I just couldn’t get it to work. If I mix it through the tx it works great but mixing through the rx seems impossible. Even horizon tec support was no help lol. I’m thinking that the control board might be able to trick the AS3X into thinking it’s still on a normal single tail / single aileron setup so the gyro will still work and the board will distribute the mixes for tailerons accordingly. That’s my hope anyway.
Yeah, their tech support isn't up to speed on the nuances involved. There are a couple of the guys involved on the development side of things that are active on rcgroups. Generally I don't like rcgroups as the signal to noise ratio is too high, but if you can hook up with Andy Kuntz ( I think I spelled it correctly) , he could probably answer and if not point you to the developer that can.Originally posted by RaptorMan2275 View PostGilatrout all the reasons you stated are why I’m wondering if it is actually going to work at all with AS3X. See I am running ar9350 AS3X in my f18 and f22 and spent a loooong time trying to figure out tailerons for both planes. The issue is that, as you know you must program all your mixes through the receiver so it knows what flight surfaces to interact with and what surface does what. You are supposed to be able to mix channels this way but no matter how I tried I just couldn’t get it to work. If I mix it through the tx it works great but mixing through the rx seems impossible. Even horizon tec support was no help lol. I’m thinking that the control board might be able to trick the AS3X into thinking it’s still on a normal single tail / single aileron setup so the gyro will still work and the board will distribute the mixes for tailerons accordingly. That’s my hope anyway.
I bypassed the control board and ran my tailerons and rudder thru gyro while the ailerons are run thru gyro but not stabilized. My gyro is a frsky s8r in delta wing config. I added an extra 4 channels so I run 12 channels. I can change amount of roll via flight modes so when wings fold back my gain changes along with amount of throws. I don’t know if you can do all this with that reciever since I not a spektrum guy.
AC, Welcome to Hobby Squawk and thanks for the vid. Very Well Done. Best, LBOriginally posted by AeroCali View PostA video of the Tomcat mixed with in-game DCS footage."I am having an extraordinary ordinary life."~Lucky B*st*rd~
Over 300 flights with my Tomcat, 3 different fuselages, several crashes, but after all this time and ordered parts this bird delivers. I finally have her fully dialed in on 10 channels. Flight modes, mixes, gyro. I would like to give an extensive review on what to do with this jet as soon as it comes out the box. This was today, along side the A4 skyhawk on a beautiful day in South Florida.2 Photos
- Likes 5
Got a about 15 flights on my stock tomcat now and loving it. Only mod is D85MG servos and a paint job. Have had a couple flights where I’ve heard the motors “hiccup” simultaneously and wondered what it was. Had a
brown out on my 90mm F-22 today where I totally lost the motor and flight controls, but was able to get just the flight controls back after a few seconds and dead sticked it back for a landing. Anyone else had this issue? Should I upgrade the BEC? If so, did those that have done it cut the red wire from the stock esc to the throttle Y cable just on one motor as shown below?
I finally was able to wrap up the thrust testing of the F-14 after switching to inrunners. The results speak for their self, I can't wait to get this plane in the air. Hope you enjoy it.
Also, be on the look out for the F-14 mods kits as Rich Baker, RCinformer, will be releasing a video here shortly.
Planes
Why ruin a perfectly good ESC by cutting wireOriginally posted by thisguy65 View PostYes cut the red wire
Just lift the plastic locking tab on the connectors red lead pin and pull it out of the connector and wrap it with some electrical tape to isolate it from inadvertently shorting out the ESC.
This will allow you to reuse the ESC down the road in another application
Sorry, brain fart. You cut the stock BEC off the battery wire leads and use those cut leads to put in your new BEC. My apologizesOriginally posted by Gvasiloff View Post
It's not ruined, just add another terminal if ever needed. I mention cut because that is what he asked. Doesn't take much lifting to disengage
Hmmmm....are you sure? Because after further reading it looks like you only do that if the ESC has its own BEC....which the Tomcat doesn’t.
Cut where my line is and solder your new BEC there. Installed a castle 20amp
Link to mine: http://www.castlecreations.com/en/cc...ro-010-0004-01Planes
