  • Corsair nut
    Jets...warbirds...mmm hmmm
    • 218
    • Tehachapi ca
    Some really cool shots of y f14 at aef! Im terrible with names and ive forgotten the photographers name...but he took some stellar shots! Ive really been enjoying the f14...with the added power of the a4 power systens the performance and flight times are excellent and i just cant get enough of this model. It looks so real in the air! Im just totally in love with it :)
      • 4812
      Originally posted by Corsair nut
      Some really cool shots...It looks so real in the air! Im just totally in love with it :)
      CN, Yeppers, that'll do for sure. Again, great looking livery. Bravo Zulu, Sir. Best, LB
        Brent, those are from Jeremy Solt's collection. It was either him or Justin taking the pics.
        • Corsair nut
          • 218
          • Tehachapi ca
          Pat..no it was a younger fellow thatbwas with them. Ugh..im horrrible with names
          • thisguy65
            • 509
            Finished up my EDF comparison of stock vs inrunners
            Planes
              • 4812
              TG, Logic seems sound and there's no denying the increase in static. Will be waiting for the your flight analysis. Best, LB
              • Corsair nut
                • 218
                • Tehachapi ca
                Awesome video! Your gunna love it! Mine flies awesome on the 1850 outrunners so i can only imagine how good yours will do!!
                • Brinka
                  Because I was inverted!
                  • 121
                  Florida Jets on March 11th - 14th in Lakeland, is mostly turbines, but I will proudly be at the event featuring the F14 Tomcat and F18 Hornet, any one else thinking of attending?
                  • scootergenie
                    Jet lover
                    • 261
                    • Stuart FL.
                    I was planning to attend on Saturday, but as a spectator only.
                    • Brinka
                      • 121
                      Sweet, I should be there Friday and Saturday, I have a lot of buddy’s flying some major size turbines, but the show always welcomes all type Jet pilots, this will be my 1st time flying at the event, super excited! See you there!
                      • Aces
                        Pilot Wannabe
                        • Jul 2018
                        • 179
                        • Georgetown Texas
                        Hello. I have been searching and searching for someone who has done this thrust testing on the stock f14. I have been having an issue with mine and i felt like i had lost power. But after watching this video i know i have not. I get 7lbs thrust on my stock setup. I think i must have missed which inrunners you went with? can you provide a link or full description? Thanks.
                        • thisguy65
                          • 509
                          Here you go. You will need 100amp ESC too
                          Planes
                          • Aces
                            Pilot Wannabe
                            • Jul 2018
                            • 179
                            • Georgetown Texas
                            Thank you. WOW! about $400 (assuming you need two esc's). Did you really feel the difference and think its worth it?
                            • thisguy65
                              • 509
                              I bought or had some parts
                              haven’t flown it yet. 3 lbs of more thrust is a lot
                              Planes
                              • Aces
                                Pilot Wannabe
                                • Jul 2018
                                • 179
                                • Georgetown Texas
                                Ok. I will wait to hear what you think. Thanks.
                                • RaptorMan2275
                                  • May 2019
                                  • 10
                                  thisguy65 did you think about trying the fms v2 pro 2100kv fans? A friend of mine put one in his Avanti and it has damn near unlimited vertical. I’ve never tested one but fms claims 3500 grams of thrust on 6s. Two of those should get you pretty close to a 1:1 thrust ratio.
                                  • thisguy65
                                    • 509
                                    I wanted a bolt on and go. A good friend of mine in PA as we were talking mention he is going the FMS route and from a technical aspect/ scientific point of view I went with the Freewing edf
                                    Planes
                                    • scootergenie
                                      Jet lover
                                      • 261
                                      • Stuart FL.
                                      The fms 80mm fans are a little different diameter than the freewing fans, and will require some carving to get them to fit in the Freewing airframe properly.
                                      • RaptorMan2275
                                        • May 2019
                                        • 10
                                        scooter genie Thanks for the explanation. I’m considering going that route myself.
                                        On another note has anyone tried wiring the the escs in parallel and running one battery like eflite’s new su-30 does? A config similar to the su-30 could be beneficial for weight savings and would make achieving cg that much easier. Is there any reason in particular that freewing went with a dual battery configuration?
                                        • Brinka
                                          • 121
                                          Cheap F14 cockpit work around; so here in Florida that sun bubbles the foam fast and especially for this particular canopy, (I personally hated the way it would look) so I bought a large sheet of thin black construction paper, measured and cut the paper over all the exposed foam area (entire cockpit) glued, then carefully used a thin paint brush to dot in dials and controls as scale as possible. Painted seats green. Painted and cut 4 small pieces of servo wire for iconic ejection seat handles, glued them onto seat with paper over it, and this turns out to look a thousand times better than what I had. Sure you can try to get the 3D print stuff but if you don't have access to printer this is a great work around. Whole process takes a good 2 hrs to complete.
