  • fredmdbud
    • 450
    Originally posted by James
    No, the base gray is not painted over the blue. The base gray is painted on white foam like the blue angels. The plastic bits that one doesn't see after the model is assembled are molded in blue (wing connectors etc). But both versions have 1 layer of paint on white foam either blue or gray.
    OK - thought the first batches were oversprays because where the paint chipped on mine exposed blue, but those must have been the plastic bits (nose, gear doors, tailhook).
    But with the BA you still don't have to wait for decals to arrive separately (extra $$$, plus worry if they were sized correctly).
      • 8207
      Originally posted by Bobaroo
      Affirmative, .Awesome stuff, sands and takes paint very well. Home Depot// Possibly,... I get it from the Sherman Williams paint store here in town !! GL
      For Pete's Sake I have a Sherman Williams 1 mile from my house versus Home Depot which is 5 miles away. Geez Todd! (face palm)
      • e4dragongunner
        Living the dream!
        • 876
        • Arlington Heights Il.
        Glad you guys aren't being OCD about Hornets, and with that here's my first attempt at weathering a foam jet. Tried to keep it subtle. I need to get some better sidewinders, stole these from the F-4. Gotta get out and fly it again soon!
ID:	206637Click image for larger version
        This is EXCELLENT WORK! so subtle. Way to go Marine!
        • Jetman64
          • Jun 2017
          • 113
          The A10 sidewinders work great, almost perfect scale fit.
          • Jetman64
            • Jun 2017
            • 113
            Originally posted by Aros
            I dinged my F/A-18C Hornet yesterday when I was trying to unplug my battery...The connectors were super tight and when they finally pulled apart it tore into the edge of the fuse leaving a nice little pea-sized chunk out of it.
            Grrrrrrr....
            So I am in the hunt for a really good spackle or something similar I can go grab at the hardware store. I have used spackle in the past but the consistency isn't a great match, especially when painting over it. Any suggestions? Help is greatly appreciated!
            Arose,
            even the best foam putties out there, are no match for a hole that big. I’ve found, your better off cutting out a 1” square and filling it in with a slightly larger piece of scrap foam. Then you putty the edges, sand and repaint. I’d use foam from the weapons or tanks or better yet, a piece from a crashed bird. I’ve had large dents in the leading edges and this works great.
              I have to laugh at “ Sherman” Williams. Bobaroo called it that and it stuck!! It is Sherwin Williams. Great paint! https://www.sherwin-williams.com/ Click image for larger version  Name:	SWP.jpg Views:	0 Size:	20.1 KB ID:	206887
                https://www.amazon.com/Hobbico-1000W.../dp/B0015GZAUS This works pretty nicely too.
                • Bobaroo
                  If it Ain't Right on the Ground...
                  • Dec 2017
                  • 327
                  • Newburgh, IN
                  Originally posted by Hardway
                  Indeed !!! Though there is a lot of shrinkage with it, and when this stuff is Painted on, there tends to be a lot of absorption leaving a porous and sunken finish !! When I do use the HobbyKite , I will apply Thin CA over it before painting and that really locks it in nicely. The 'Sherman' is a better filler on EPOJets for most applications !!! Hahahaha
                  Click image for larger version  Name:	IMG_20171217_082716.jpg Views:	0 Size:	72.5 KB ID:	206890
                  • Bobaroo
                    • Dec 2017
                    • 327
                    • Newburgh, IN
                    The LEFlaps and Gear Doors are going to really set this one apart from my other projects.
                    ​​​​​​When watching the FSA perform the LowSpeed Maneuvers during displays, pay particular attention to the use of TEFlaps and LEFlaps. Sometimes even in Afterburner, these Flaps are being deployed. There is something to be said for the Aerodynamic advantage they provide in these realms. Why wouldn't you take advantage of these features on your Foamie F/A-18C ?? 'I'mJustSayin'
                    • MANFRED
                      Any Warbird, any time
                      • 299
                      • San Diego, Ca
                      So, with the big Tech Warning I am a little paranoid about running with the stock elevator servos. Some guys are using the Hitec 5085 but they are discontinued. Anyone try the Promodeler DS 100? I almost ordered a pair until I hit the order button until they showed a $12.95 delivery charge for 2 micro servos! The cheap old man in me made me rethink the order. Nothin worse than spending close to $500 on a ship then have to replace critical servos for piece of mind.
                      • Bobaroo
                        • Dec 2017
                        • 327
                        • Newburgh, IN
                        An ageless conundrum to some, a NoBrainer to others !!
                        • thisguy65
                          • 509
                          D85MG there replacement
                          Planes
                          • Bobaroo
                            • Dec 2017
                            • 327
                            • Newburgh, IN
                            Interesting Stuff here !! Cheers
                            https://youtu.be/LZzmfoS3TH4 ​​​​​​
                            • Hoomi
                              Cactus Dodger
                              • Apr 2018
                              • 863
                              • Baja Arizona
                              Having read the tech notice (despite not having an FA-18), the issue wasn't the quality of the servos, but the process of installing them causing cuts in the wiring. If I read it correctly, so long as your wire insulation is intact and the mounting plate properly attached, the servos should be fine.
                              Of course, it's not unreasonable at all to consider a relatively cheap servo upgrade worthwhile to make sure a $500 bird remains a bird instead of a $500 pile of scrap foam.
                                • 8207
                                Man I am one giant face palm lately! LOL!!
                                  • 8207
                                  Originally posted by Jetman64
                                  ...even the best foam putties out there, are no match for a hole that big. I’ve found, your better off cutting out a 1” square and filling it in with a slightly larger piece of scrap foam. Then you putty the edges, sand and repaint. I’d use foam from the weapons or tanks or better yet, a piece from a crashed bird. I’ve had large dents in the leading edges and this works great.
                                  Yeah with the bigger boo boo's I definitely use scrap foam to fill, then putty/sand....However, I think this particular damage can be rectified with just spackle, sanding and paint. It's not that large of an area, just enough to piss me off.
                                    I was not going to comment on this subject at all, but then last night I kept having dreams about it... Totally stupid stuff, but, I had to do it!!! LOL Then I started second guessing myself... I was like "IS IT REALLY SHERMAN???" dang....
                                    • Bobaroo
                                      • Dec 2017
                                      • 327
                                      • Newburgh, IN
                                        • 8207
                                        I just did it again! I told my wife "I need to run to Sherman Williams..." She gave me "the look" and said "it's SHERWIN..."
                                        Well maybe they SHOULD CHANGE IT TO SHERMAN!!!
                                        • tengarang
                                          Banned
                                          • 382
                                          • Yay Area, California, USA
                                          Addressing 'Geometric Perfection'.
                                          ​​​​​​ I have similar wants, and correct my Jets to achieve this wherever possible.
                                          I have not seen Symmetry of Design in the FW Jets that I have purchased since maybe the MiG-21 and F-15C. F-4/A-4/F-22 and again here on the F/A-18C,... All of these Jets have Asymmetry in the Flap Arrangement/Layout on these models. Replacement Servos corrects this for me. I can achieve Symmetry (Geometrically Perfect) under there by simply repositioning a Flap Servo. I am not sure why this is not done for us since the BB or a Reversed Servo installation from the factory can correct this. The Geometrically Imperfect Flap Arrangement can be seen very clearly below. 'I'mJustSayin'
                                          As far as surface Deflection is concerned, I'm afraid that is far more difficult due to Twisting and Shifting of these EPO Foam control surfaces from Exposure to the Sun. Most flights require trim adjustments anyway because I fly with multiple/various Ordnance packages and these too create their own specific trimming requirements on any given flight.
Name:	044 Eating grass.jpg
                                          understand
                                          but uggh this is why i dont like belly landing it messes up the airplane underside way too much
