Originally posted by tengarang
View Post
Originally posted by Bobaroo View PostThe LEFlaps and Gear Doors are going to really set this one apart from my other projects.
When watching the FSA perform the LowSpeed Maneuvers during displays, pay particular attention to the use of TEFlaps and LEFlaps. Sometimes even in Afterburner, these Flaps are being deployed. There is something to be said for the Aerodynamic advantage they provide in these realms. Why wouldn't you take advantage of these features on your Foamie F/A-18C ?? 'I'mJustSayin'
The reason why this is not terribly tempting on these small models imo is simply weight. It totally killed the flight envelope of the T-45 for example.Freewing A-10 turbine conversion: http://fb.me/FreewingA10TurbineConversion
Originally posted by Aros View PostI just did it again! I told my wife "I need to run to Sherman Williams..." She gave me "the look" and said "it's SHERWIN..."
Well maybe they SHOULD CHANGE IT TO SHERMAN!!!
Yes, I'm Sure, man.
Word of warning guys!!
I haven't seen anyone else besides James from MRC who crashed his F-18 on maiden have something mounted on the belly of the F-18, today I tried a drop tank but only after I put four flights on it, including the maiden, then I mounted the drop tank on the 5th flight. CG was checked and perfect, it took off and instantly I knew I was in trouble, it yawed to the right really bad, ailerons weren't turning it hardly at all, kicked in rudder and got it to turn left, it almost rolled over on it's side and crashed a couple of times just like James did with his, but mine never got inverted, ailerons by them selves could not hold it straight, then I realized that rudder was the only way I was going to fly and land this wild Hornet, gear was down already, and with almost full left aileron and using rudders, I was able to bring it around and land it without a scratch, I couldn't use flaps because I couldn't let go of the sticks to put them down, glad I didn't use flaps, no telling what would have happened, anyway it's in one piece, the next flight I removed the drop tank and it flew straight and level like the first four flights, so be warned if you're going to try a drop tank. Here it is before the wild flight with the drop tank mounted, and here it is now after I weathered it up, drop tank will be for display only, going to try some ordinace next time and see how that goes. I might have over did it on the weathering but this is my first attempt so lets not be to critical...........lol.
So be ready is all I can say if your going to try a drop tank, my tank is from the FW F-15 and my mount from the F-16, it is mounted nice and straight, anyone with an explanation on why my drop tank caused this out of control flight????7 Photos
- Likes 5
Originally posted by DCORSAIR View PostI might have over did it on the weathering but this is my first attempt so lets not be to critical...........lol.I solemnly swear to "over-celebrate" the smallest of victories.~Lucky B*st*rd~
You'll never be good at something unless you're willing to suck at it first.~Anonymous~
WellNow,.. Some of us feel that if your 'Warbird' cannot be flown like this, .... then, what's the point of it all !!! Why not just get a Avanti then, and paint it Gray ?? Hahahahaha. Might consider making them there Stores Drop-able, ya reckon !! ...in case you gotta Lose them in a hurry!
Heavy 'DirtyJets' fly very differently than their Clean, Demonstration Configured counterparts ... it is a Skill that must be learned, and Mastered just like everything else. GL
- Likes 2
Originally posted by Bobaroo View PostWellNow,.. Some of us feel that if your 'Warbird' cannot be flown like this, .... then, what's the point of it all !!! Why not just get a Avanti then, and paint it Gray ?? Hahahahaha. Might consider making them there Stores Drop-able, ya reckon !! ...in case you gotta Lose them in a hurry!
You mount up a drop tank on your F-18 and tell me how you like it and see if you have them there skills your talking about..............
Those Stores of yours are most likely 3DP ..?? I'm guessing
Kinda Heavy. The CG of those things must be calculated for, as well as their incidence along the Longitudinal Axis... Mostly I use Foam for my OrdPackages,... Keeps the weight Negligible. Drag and Incidence are then the real critical factors on my stuff. Cheers !!
You can always Make them Drop-able !! Or just fly a 'Naked' Fleet Hornet around !!
Seriously though, have you got another Jet you can mount these things onto and Evaluate them. Check the flight characteristics and see how the airplane reacts to them ?? That might be a start if you're serious about solving your controllability issue. I've been flying stuff Hangin' Down off my Jets for as long as I can remember.... Soooooooooo, I guess I don't really understand what the problem is.
I've got stuff hanging off a E-Flite UMX F-16C here... and that thing could barely fly itself around to begin with !! So yes, I understand that there are challenges to overcome with this wing stores Business !!! Hahahahaha
Last edited by Bobaroo; Jul 20, 2019, 06:54 PM. Reason: Attempting to be more encouraging, constructive and helpful with my responses
Ubetcha !! That's the plan... I'll even UTube it for ya !!! Hahahahaha
I fly my 90mm F-16, F-15, F-4, A-4, Mig 21, Eurofighter, L-39, A-10, Yak 130, I fly them all with either drop tanks and ordinance or one or the other, but this is the first time I tried a centerline tank, two tanks on the wings seem to be okay, I might give that a try but no more centerline drop tank for me, so I'm used to flying heavy but the F-18 was nuts, and my CG was the same as without the tank, it's actually a little ahead of the CG point I was using, makes me wonder if James may of had this problem along with his CG being off? Will be looking forward to your video because I'm not trying that again...........lol.
Outstanding !!! .... Fair Enough. Hahahahaha. Incidence is probably a more Critical component then on this one !! Notice the Wedge shaped Pylons on all of my stuff. Get the Nose of your CLTank Drooped a bit below the Longitudinal CL. That'll help with the Airflow interface under there.
I run a CLTank on Everything.... MiG -21/A-4/F-15/F-16 and the F-4. Often only the Centerline Tank . I'd start with a CLTank on one of those. I'd recommend the F-4 as it handles many different configurations so well with very little trim changes. if..... you are feeling it !! Cheers and GL.
- Likes 2
One thing I was thinking of that hasn't really been mentioned much if at all is how scale this model takes off. The older "E" version would pop up so unscale like no matter what I would do it drove me mad. This model lifts off so easily and gentle it's almost taken for granted. Every single time. Rotation is a gentle affair, she never POPS up, simply lifts her nose gently and that's it. Yes, sometimes it's the little things in this hobby, lol.My YouTube RC videos:
Originally posted by Carlbrainiac View PostWith the centre line drop tank issue could it be that as well as adding weight and drag it is also covering up the cheater vents so you are also losing thrust? Add all those together and that's your recipe for disaster? Just my thought on it. I could be way off.
How was the tank mounted anyway? With large, longitudinal tanks, it is clearly paramount that they are mounted in a way that prevents opposite weather-waning. If using a regular slot/groove attachment, it could very well be that is indeed imposes a lot of opposite yaw if the tip of the tank is allowed to hang toward the outside of the turn.Freewing A-10 turbine conversion: http://fb.me/FreewingA10TurbineConversion
Originally posted by Aros View PostOne thing I was thinking of that hasn't really been mentioned much if at all is how scale this model takes off. The older "E" version would pop up so unscale like no matter what I would do it drove me mad. This model lifts off so easily and gentle it's almost taken for granted. Every single time. Rotation is a gentle affair, she never POPS up, simply lifts her nose gently and that's it. Yes, sometimes it's the little things in this hobby, lol.
Originally posted by janmb View Post
Sounds quite a bit like what James had too. While his model was definitely tail heavy, there was also clearly more than that going on in his case too.
