Hi guys,
I received my F-18 about an hour ago. I just went to the website and read the advisory. The stab plates appear to be secured well, have not checked the servo wires yet. Anyhow I noticed one of the stab bearing assemblies has a considerable amount of slop in the up and down direction. Much more than I am comfortable with, I would say between 1/32-1/16”. Should I try to put a shim in there to secure the bearing tighter?
I received a call yesterday notifying me to return to work next Monday. I received a call today saying it was canceled. Looks like I get to stay home and play with the F-18
Later!!
Anthony
.Later!!
Anthony
. Once cut, those will be attached and tabs added for hook-up to the servos, a combo of ball-link and clevis. Trying to keep it simple and elegant, if that's possible.
out there. I was concerned that I might be tail heavy after installing a twin afterburner, adding several coats of paint and urethane, adding the heavier 3D cockpit (although that's nose weight) and installing 10 pounds of graphics, but it seems that it is just the reverse. I put a Roaring Top 6250 ( which is actually 24g lighter than the Admiral 6000) and even with the battery all the way back hitting the circuit boards, it's still nose heavy! Makes no sense to me but it is. I tried to balanced it at the book 88 mm from the leading edge wing root and with the battery as far back as possible, it's at 83 mm. To get it to 88 mm, I'll need to add 3 ounces of lead to the tail, that's 12 1/4 ounce squares of lead, which is something I definitely do not want to do. I hate to add more weight to any plane as I think it's heavy enough with all the paint/graphics/AB/etc. And adding that much weight to the tail seems sacrilegious.
