  • Spad Driver
    Okay I'm airborne. Now how do I land?..
    • Apr 2020
    • 57
    • mountains of Utah U.S.A.
    Will Do!.👍
    • Coolandquiet2013
      • Jan 2019
      • 4
      • Riverside California
      finishing up my new 90mm f-18 hoping to see it on the live shows one day
        • 4822
        CQ, great looking repaint and livery, Sir.
        If you want a shot at the live show, post your pictures to that thread: "Share Your Pictures for the LIVE SHOW" or something like that.
        Also, weather permitting if your bird is completed, take some snapshots outside in a setting that enhances the airframe.
        That helps get a favorable response from the powers that be.
        Best and good luck, LB
        • Coolandquiet2013
          • Jan 2019
          • 4
          Thanks for the info might be able to get some outside shot soon
          • dsmithwc04
            • Aug 2020
            • 40
            I’m going through thread trying to find where folks are putting CG. Stock is 88mm I know but how far back are folks going? Going to maiden my f18 on 8s soon
              • 5387
              I have mine at 95mm but some go back as far as 110mm, not sure how they measure it though or wheels up or down. I measure wheels down. I have mine on 8S too. Fun plane and flies very smooth.
                • 8756
                Mine is also 8S but it got finished just as winter hit, so I've not flown it yet. I always start with the recommended CG in the book and change it after the first flight if it doesn't feel right for me.
                • Dougcarr73
                  • 69
                  • Augusta, GA
                  90mm CG and I fly on 9s (6s + 3s 5000 packs). I'm using Freewing's V2 8s motor (1350kv) with the Spektrum 120a 6-12s ESC. I think I'll get a couple LiHv (4.36v) packs from SMC and fly it on a true 8s setup. The standard 8s setup at 4.20v is better than a 6s, but it's just ok for me. The extra cell from the 9s gives me a similar flight time, with much better performance out of the 1350kv motor. Give it a shot if you're feeling crazy and wanting to push your 18 over 135mph.
                  • Dougcarr73
                    • 69
                    • Augusta, GA
                    Here’s a quick vid of my 18
                      • 8756
                      Looks like it flies really nice. Did you add thrust reverse?
                      • Dougcarr73
                        • 69
                        • Augusta, GA
                        Sure did. I added the Spektrum 120a, 6-12s ESC. When combined with the AR8360T and my IX12, it enabled me to forward program reverse onto Ch 9 (Aux 4). Significantly reduced landing rollout. I had to shave out some foam to fit the larger ESC, but if I had discovered SMC batteries earlier, I likely would’ve never made this update. Pics attached.
                        I also flew it with two SMC 4s 6200mah LiHv batteries… AMAZING!! SMC batteries are the new GOAT in the battery industry. The 4.36v charge instead of the standard 4.20v is game changing. It’s like turning a 6s or 8s power system into a 7s or 9s setup without updating the ESC.​
                          • 8756
                          Yes, indeed. HV is the way to go now. When I need batteries, those will be the only ones I buy.
                          • Hajo77
                            • Jan 2023
                            • 3
                            Originally posted by Radar-Guy
                            Ooops, what a major oversight! :Scared:
                            Here is the revised design. Btw, the rectangular plates between some of the outer bolts appear to be not standard. I've looked at some pics and there are none of these.
                            HUD parts are prepared as well.
                            @ Steve (RCjetdude): I assume you will be getting your hands on your F-18 sooner than me (ETA late June over here). Would you volunteer as tester for the hub caps?
                            Click image for larger version Name:	F-18 Hub Cap Design.jpg Views:	0 Size:	63.5 KB ID:	193896
                            Click image for larger version Name:	F-18 HUD Design.jpg Views:	0 Size:	53.2 KB ID:	193897
                            Hi There,
                            Does anyone know where to get (also buy if necessary) the main wheel covers for the F/A-18?
                            thank you
                            Hajo
                              • 4822
                              Originally posted by Hajo77
                              Hi There,
                              thank you
                              Hajo
                              HJ, Welcome to Hobby Squawk, Sir. Do you have access to a 3DP printer? I have my STL Wheel Cover file for that part. I do not print and sell parts.. Best, LB
                              • Hajo77
                                • Jan 2023
                                • 3
                                Hi Elbee,
                                Yes, i do have a printer :) Was just looking for the file. Been browsing this thread for a long time as I am just about to finish my F-18 :)
                                Best Regards
                                Hajo
                                • Radar-Guy
                                  AirBorn Jetworkx
                                  • 364
                                  Hi Elbee,
                                  Best Regards
                                  Hajo
                                  Here you go!
                                  Happy landings
                                  Frank
                                  • Hajo77
                                    • Jan 2023
                                    • 3
                                    Thank you so much Guys for the quick help!
                                    Happy flights!!!
                                    Hajo
                                    • Dougcarr73
                                      • 69
                                      • Augusta, GA
                                      Great performance from those SMC LiHv batts. Topped out at 128 mph on 8S 5300 packs, but hit 140.4 on 9s 5000mah SMART Lipos
                                        • 8207
                                        Nice flight and video!
                                          • 8207
                                          Everything comes to an end eventually. Sad...My favorite F jet!
