    • 8207
    Here's the video I never thought I would be able to release!
      • 4822
      Aros
      How many hours of 'blinking' did you edit out of your video?
      Best, LB
      • f4u ausie
        • 1232
        • Melbourne
        That's funny
          • 8207
          Originally posted by Elbee
          Aros
          Best, LB
          I think about 2 days worth!
            • 8207
            Anyone happen to have any spares of those coveted wingtip pylons?
            Asking for a friend.
            • stojakovic
              • Mar 2024
              • 19
              Hey Hornet Aficionados, Back to work here at LB's Hornet Worx. Vents, antennae, Filler at elevator bay, gun port, 2 coats primer on the bottom/top tomorrow, then sand, sand and more sanding. Best, LB
              Elbee
              Yeah man, seriously nice work
              Where can I find the stl files,such as nose gear door and the antennas.
              I searched through thingiverse but couldn't find it
              could you please tell where can i find it.
                • 4822
                Originally posted by stojakovic
                Elbee
                Prusa Printables:
                https://www.printables.com/@Stevie_14806/models
                Choose: Open files in Prusa Slicer.
                There might be an STL Download as well, but it's easier just to drop to Prusa Slicer from the Printables.
                Best, Steve
                  • 8207
                  Hey gents, what's the easiest way to access the ESC? The cheater intake section doesn't appear to have any screws to easily access the ESC. Pop off carefully with a tool? My RX still is working fine, all the lights, control surfaces, gear...No issue. But the ESC does not make those series of tones when I plug in the battery and there is no throttle at all. I need to access the ESC and most likely replace it.
                    • 4822
                    Blue Angels maneuver of the week.
                    Best, LB
                      • 2693
                      If I'm not mistaken, I think you have to access it by removing the edf cover and take the fan out to get better access to the ESC.
                      So glad you found it, now the investigation begins. If you dare, I'll help you mess it up again as it seems I'm pretty good at that.
                      3 possible issues IMO:
                      1) RX got loose (unlikely)
                      2) Check RX orientation and confirm it was correct
                      3) Signal loss, in watching the video that may have happened. Assuming you placed the two antennas going forward. Keep in mind the signal reception area around the active end is like a donut, so if both are lined up along the fuse, you'll loose signal when it is flying directly at you or away. You should place one that way, and the 2nd up/down or left/right. With EDF's, I always add a sattelite RX as well with 2 more antenna. In the F18 I placed it behind the battery. With those 4 antennae, every possible directional plane is covered. Lipos, edf ESC's and any carbon fiber raise hell with signal, and with only 2 antennas in front, the battery and carbon tubes in the fuse block signal aft (where you were standing). You should also check for Frame Losses and Holds after flight in your TX telemetry. In the video, to me it looked like a couple points where you got a Hold.
                      Just some random thoughts to pass on to the NTSB
                        • 5387
                        Long thin screwdriver through the bottom cheater. If you have a AS3X receiver it has to be upright and still to initialize.
                          • 8207
                          Good stuff! When I opened up the battery tray the RX is still facing forward, flat, all servo leads still firmly plugged in place. One of the antenna wires is facing aft and one facing forward (see photo). I may even have a spare satellite antenna I can use to add to the configuration. I should have done that to begin with.
                          Hopefully it's just an ESC replacement and she's back up and ready to go for a second attempt. I will be pushing the battery forward to get closer to manufacturer's recommended. It really did act tail heavy from the start. I couldn't seem to get that nose down to control her and bring her back to me which is why she kept flying away from me until the crash.
                          I'm determined! Especially with this exceptional good fortune thanks to my search crew!
                          • Fruchtzwerg76
                            • Sep 2024
                            • 3
                            Prusa Printables:
                            Best, Steve
                            Hey Steve, really great work! The parts are superb.
                            I was wondering which pilot figure did you use in your F18 cockpit?
                            Telling from the pictures, the pilot is not included?
                            Best greetings.
                            Alex
                              • 4822
                              Best greetings.
                              Alex
                              Hey Alex,
                              The pilot body is from Max Grueter Designs and I found it on CGTrader, also Greuter has some things on Cults3D, I think.
                              There are a couple pilot figures that are similar and less expensive around that you could use.
                              I modified the OEM pilot head by removing a "V" shaped section out of the back, pinching and gluing it together, and printing a modified cylinder shape for a new neck.
                              Sounds strange, I know, but it worked as I liked the general design of the OEM pilot head.
                              Happy 4th of July.
                              Best, Steve
ID:	428486 Click image for larger version
                                • 4822
Name:	Blues Full Formation 2025.jpg
                                  • Nov 2013
                                  • 2673
                                  • Cody, WY
                                  Beautiful legacy F-18s of the Blue Angels!! Happy Birthday, America!!🪄🪄🪄
                                    • 4822
                                    https://www.printables.com/model/134...le-rails-lh_rh
                                    Hornet Honchos,
                                    There's been some renewed interest in the 3DP missile rails for this model.
                                    Okay, just one guy, but we all know him.
                                    I have posted my version I used on my Hornet on Prusa Printables. See Link.
                                    Better late than never, I said I would about 2 years ago, "Doh!"
                                    My set comes as 4 printed parts each side and screws in place in the OEM location.
                                    I drilled and tapped the OEM Mount points to 2-56 (or 4-40 ) and used countersunk nylon screws from the hardware store,
                                    It should be noted there is no mounting provision for Aim-9s, though you could add those with your own mod.
                                    Best, LB
                                    Click image for larger version  Name:	Freewing F-18C Missile Rails.jpg Views:	0 Size:	104.2 KB ID:	428509
                                    Click image for larger version  Name:	IMG_501.jpg Views:	0 Size:	71.6 KB ID:	428510 Click image for larger version  Name:	IMG_0526 - Close up.jpg Views:	0 Size:	79.2 KB ID:	428511 Click image for larger version  Name:	IMG_1202b.jpg Views:	0 Size:	77.6 KB ID:	428512
                                    • Earl Poe
                                      • Mar 2025
                                      Blue Angels F/A-18C
                                      Can someone send a picture of the nose steering servo mount? I got a new fuselage and think I'm missing a bracket or something. Thanks for your help.
                                        • 8756
                                        Have you looked through the "photos"? After flipping through them for about a minute, I found some on page 70 of the photos that shows you what you need to know.
                                          • 8207
                                          Elbee you are a rock star's rock star!
