  • Skosh25
    • Mar 2019
    • 177
    • Denver
    Hopefully we get some sort of acknowledgment from MRC that the issue is real and not just typical statistically acceptable accident rate for a new release. Usually with a new model I gain more confidence with every flight. With this one however I get more nervous. 14 flights on it with no issues but still have anxiety every flight until it's back on the Earth in one piece.
    • kallend
      • 1877
      There's another loss of elevator authority crash being reported on RCGroups this morning. Looks like identical symptoms to the others.
      "Once is happenstance, twice is coincidence, three times is enemy action"; Auric Goldfinger, in Goldfinger by Ian Fleming.
      • Firebird
        • Oct 2020
        • 44
        So much remains unknown at this point. We’ll have REAL data when Firebird installs the HACKER servos and looks at the telemetry data they provide. Pretty much conjecture until then.
        -GG
        I’m on it. The telemetry servos will arrive tomorrow afternoon.
        Exchanged the nose tires meanwhile with JP Hobby 45mm:
          • 5401
          Remember that while Motion, specifically Alpha has some input, this is a Free Wing produced aircraft.
          • kallend
            • 1877
            Originally posted by Firebird
            We will find out soon what is actually really going on with the signal strength and voltage at the elevator servos. I just ordered Hacker telemetrie servos which are sending telemetrie data about signal strength, voltage at the servo, torque load, temperatur, blockade and overload live to the TX where the data gets recorded.
            Do you have a systematic flight test program in mind? Just randomly collecting data may not tell very much.
            • Skosh25
              • Mar 2019
              • 177
              • Denver
              Correct, but Motion is their largest distributor and our primary conduit into FW for voice of customer feedback and comms overall. Has anyone ever heard from FW directly? I was one of the many people Alpha personally called about the servos, which was a very impressive customer experience. Kind of surprised there hasn't been some sort of statement, even such as "we're aware of the similarities in these crashes and are monitoring the feedback and working on a root cause analysis".
              • Airguardian
                Post Stall Svengali
                • Aug 2020
                • 1676
                • Catalonia
                Alpha is the senior designer/engineer for Freewing as far as I understand it.
                • janmb
                  Slow and low
                  • 729
                  Yeah unfortunately it means my maiden is postponed until this is figured out. Far too many more or less identical crashes in a situation that is completely undramatic in every way. No stall, no high g, no great range, nothing. Way too much to be coincidence.
                  Wish Alpha would chime in soon. There is clearly a conseptual problem here
                  • Firebird
                    • Oct 2020
                    • 44
                    I will compere the signal quality and voltage at the elevator servo. One time connected to the stock setup and one time connected to my upgraded and rerouted elevator servo cable.
                    Both with and without running the impellers same time.
                    No flying required for this servo impulse signal and voltage check.
                    • GliderGuy
                      • 1412
                      Please also consider adding a simulated load on the elevators, too.
                      -GG
                      • Firebird
                        • Oct 2020
                        • 44
                        -GG
                        Copied, will do
                        • bandetx
                          • Nov 2017
                          • 88
                          Check them for voltage drop too. Maybe the load is causing a brownout on the elevator servos due to the long wires? Maybe adding small cap pack at the back like those used on gyros would stop it, or inline voltage booster etc.
                          • Skosh25
                            • Mar 2019
                            • 177
                            • Denver
                            Would this work? I have hitec D85mg’s in mine.
                            • Bushong572
                              • Dec 2017
                              • 29
                              • Midland, Texas
                              That looks much better. Where did you order them?
                              What do you have on the mains?
                              • Teslamandex
                                • Aug 2020
                                • 21
                                • Wasilla, Alaska
                                Are they the same wheels I’m seeing on fanjetsusa.com?
                                • Teslamandex
                                  • Aug 2020
                                  • 21
                                  • Wasilla, Alaska
                                  Guess not. After looking back at your photo Firebird,I noticed that the bolt pattern is different.
                                    • 5401
                                    Another three flights today, 28... Never going to match GG.
                                      • 5401
                                      I started a poll for those that have crashed a BIG MiG.
                                      • GliderGuy
                                        • 1412
                                        As long as they were good / fun flights, nobody is counting!
                                        Glad you had good flights!
                                        -GG
                                        • Gringotuerto
                                          • 409
                                          • San Diego
                                          https://www.rcgroups.com/forums/show...d-a-FW-Big-Mig
                                          It says poll closed. Anyway, I'm sure why mine crashed - I was stupid! Case closed. New higher-torque brain still on backorder.
