  • MeyerVW
    crash test pilot
    • 288
    • Dude who likes flying.
    My nose wheel is off. I havent looked but maybe its loose. It will nose into the wind easy well. I also do not have the clear fin in. It tracks just like the pj and al do. My first take off, not on cam era, was smooth. Very little wind. Thats was my experience
    • jasmith41
      EDF-obsessed
      • Sep 2021
      • 317
      • AZ and NE Ohio
      Originally posted by MeyerVW
      It flies fantastic. If you set you as per Jeremy's video. You are in good shape. I had a few trim clicks but I am very close to cent with his set up. +4 ele and +4 ail. The rudder in 0 Its a smooth flying aircraft and I had no signs of any problems with it. Keep up a pinch of speed on landing and see floats right in. Keep flying it the entire time.
      NIce Nikes...
      When is FW going to make a gear door that fully closes properly...?
      And the gear wobbles like I've been flying and landing it (not healthy for the gear) - i would think a brand new plane would be tight...(?)
      • kallend
        • 1877
        Originally posted by jasmith41
        NIce Nikes...
        Hey, one of my Gripen doors closes properly, as do all three of the Eurofighter doors.
        One landing and FW gear wobbles - that's the way it is.
          • 8814
          NIce Nikes...
          If I'm correct about the door close mechanism, it's a mechanical spring loaded bar that the strut pushes on to close the door. I think it's just a matter of adjusting the rod length so that it closes the door more fully when the strut pins the bar down. Even if it was a servo actuated door closer, the same method is used to adjust the close limit on the door. I usually do this on every plane I get. They are never adjusted properly from the assembly line. It's just part of the getting a plane set up for operation (fine tuning) and not necessarily a design flaw. It's no different than setting all control surfaces to neutral after you've powered up the plane for the first time.
          I've also seen that kind of gear wobble on first flights of any plane. In this case, the retention methodology of the strut onto the retract pin needs to evolve to hold it more firm. Perhaps a longer pin that goes into the bore of the strut is the answer.
          • kallend
            • 1877
            They use cheap alloy for the trunnion and the traveller on the threaded rod, which wear very quickly and create slop. But the worst I've seen has been on some EFlite planes. The 80mm F-4 is notorious for its nosegear retract collapsing due to wear on the metal parts after very little use.
            • MeyerVW
              crash test pilot
              • 288
              Wind is a factor. I almost always have a crosswind of some kind. The plane while on the ground, will turn into the wind very easy. This maybe where that clear fin comes in. I did not use it but I noticed the aircraft will go into the wind very easy without it.
                • 8814
                That clear fin may actually make it weathervane even more easily.
                • viper1gj
                  • Feb 2020
                  • 81
                  I finished the B-2 assembly, set up and Jeti programming in about 3 hours. Biggest fuss was setting drag rudders to the recommended spacing. I had to set the rudder rate endpoints to 60% to make them work. Only change from stock was to set steering on separate channel to get steering trim and turn off steering when retracted. I added the gyro control channel and assigned it to a knob control. I did not use the clear vertical fin.
                  I had to postpone test flights today for rain so Thursday is next opportunity.
                  My gyro channel goes from -100 to +100%. On a Jeti this spread is slightly larger than other radios so it may equate to about -120 to +120 on other systems.
                  This is what I observed.
                  From +100 to +25 I had solid red basic gain in normal mode.
                  From +25 to -25 I had slow flashing red in attitude lock mode.
                  From -25 to -100 I had purple (combined red and blue) in trainer mode.
                  There was no way to turn the gyro off.
                  In the basic gain normal mode the gyro corrections were correct and momentary when the jet was moved in pitch roll and yaw directions. Pitch movement was very low, roll was medium, and yaw was very aggressive. I could not see any difference between when I moved the gain control from +25 and +100 so I assumed the gain is at some preset value in basic or normal mode. This seems to fit what others posted.
                  In attitude lock mode the gyro activated flight controls acted like a heading lock mode and seemed to stay deflected toward the previous attitude which I did not want.
                  In trainer mode the gyro flight controls acted sluggish to limit pitch and bank attitudes which I did not want.
                  As a result I set a function curve for the gyro channel for 100% to keep the gyro away from attitude and trainer modes. After further reading forums tonight the simplest way may be just to delete the gyro channel and unplug the gyro lead. This would still give 100% of the preset gains.
                  Will report back after some test flights.
                  Gary
                  • avanti127
                    • Apr 2018
                    • 96
                    Got the LED landing lights all hooked up and wired in...
                      • 8814
                      Someone over at RC Guppy already mentioned this. The "mode" control is different from "master gain" control. Take a look at the stock gyro device. There are 2 separate pins for these functions. One is for "mode" where you have 3 types of gyro function. This should be a switch. The other is for "master gain". This is the one that you put on a rotary or slider so you can dial it from 0% to 100% of the set gyro gains. 0% will turn the gains to ZERO (no gains, no gyro response). If you are using Jeti and not incorporating the stock gyro, you must emulate what the stock gyro unit does in terms of these 2 separate and distinct functions. (I don't use Jeti so I have no idea how you do it.)
                      • MeyerVW
                        crash test pilot
                        • 288
                        Seemed to me to be a relitivly normal flying plane. It seems the internet is being very picky for this aircraft. Its seems to be in tge AL and PJ category for flight skill and expectations.
                        Warning. You can easily loose the aircraft if you look away. for any reason. Dont take your eye, or eyes, off the aircraft.
                          • 8814
                          Yeah, that's what the internet does to a lot of people. Brings out stuff in their character that they would never get away with at the flying field. What can you do?
                          I'm a little surprised that you can visually lose this plane so easily. Perhaps with the right kind of sky? My old X8 was never a problem to find it again if I "lost" it. Worst case, do a shallow banking circle and there it is. With this plane, if I were to lose it, I'd put it in "trainer" (auto level) mode before doing the big circle. I would love to put a RTH module in it but with its stock gyro, that would be extremely difficult. I tried once with my 2.0 Opterra and that was a nightmare - could never make it work.
                          • kallend
                            • 1877
                            Gary
                            I'm unclear why you have the MODE channel assigned to an analog input (the knob). It should be on a 3 position switch.
                            If you want to adjust the master GAIN, that is a separate input to the gyro and its channel should be assigned to a knob or slider.
                            • JohnnyJet62
                              • 11
                              I have Spektrum radio. Can someone tell me what Aircraft Type settings should be used? For some reason, none of the control surfaces are functioning. I have it set to a single aileron/elevator servo for the wing type. And, I have the gyro plugged into Aux2, and that channel is assigned to switch B, but the switch does not change the modes on the gyro. Any help is appreciated.
                                • 8814
                                I also use Spektrum (DX9) but when I look at the aircraft type, I only see "wing: normal, tail: normal". I don't see what you see on yours. Maybe it's the same?
                                As for the "mode" switch, is the wire you're using plugged in the right way? It's not upside down at one end, is it? Is it actually plugged into the "MOD" port and not the "gain" port? Can confirm when you look at the "monitor" that when you flip the switch, it's actually working AUX2? Other than these points, it should be working.
                                • kallend
                                  • 1877
                                  Can you be more specific? Are the flying surface controls completely dead, or just not working correctly? How about the retracts, are they working? What is the color of the LED on the gyro?
                                  When you state "I have the gyro plugged into Aux2", how exactly have you done that? Which slot on the gyro, which cable did you use, and how is the cable arranged (which color lead is on top)?
                                  If you plug a servo directly in to the AIL or ELE port on the receiver, bypassing the gyro and control box, does it respond to stick movement? If you plug a servo into the Rx AUX2 slot, does it respond when you move Switch B?
                                  If you look at the monitor screen on your transmitter, what values do you see on AUX2 for the three switch positions of switch B?
                                  • mshagg
                                    • 541
                                    • South Australia
                                    Seperate BEC has tripped people up in the past, make sure it's plumbed in somewhere
                                    • Tabdy
                                      • Jun 2020
                                      • 14
                                      • Little Faringdon, Lechlade
                                      Wondering if anyone has investigated how to setup RTH. I wonder if one could somehow use Kopilot Lite bearing in mind gyro conflicts.
                                      • viper1gj
                                        • Feb 2020
                                        • 81
                                        This is exactly what I wanted to accomplish but without understanding the mode and gain connections I just plugged in the lead labeled gyro in the gain function controlled by a knob on the radio. I found the step I missed explained with photos in post # 638 by Icarus on the other thread. I'll get it done today and test it.
                                        Thanks for the help.
                                        Gary
                                        • kallend
                                          • 1877
                                          Gary
                                          Glad that you sorted it out.
