Official Freewing 90mm Eurofighter Typhoon EDF Jet Thread
    • 8835
    Mine's all done - steering gyro installed, RX gyro set on master gain, throws/expo set, everything seems to work - reverse, airbrake - all good. Balances a few mm behind CG marks when using twin Coddar, 4s, 6000mah, HV. Just need to hang it up and wait for spring. A foot of snow on my deck in some places, more to come, -33C overnite in 2 days. It's only -20C now. :snowman2:
    • TonyTaff
      • Oct 2017
      • 39
      Hi xviper. When you’re done shoveling can I ask what diameter the Spanish rounders are. I’m thinking that when I get mine I will just cover those up with RAF roundels
        • 8835
        35mm
        • Alpha10
          J e t - J u n k i e
          • 377
          • Chicago
          Has anyone mentioned the elephant in the room on how this is the second delta release with a tragically poor designed battery bay that doesn't allow proper cg flexibility on a 5000-6000mAh lipo?
          First the Gripen (Which is nose heavy even on 4000 max aft) and now the beloved Eurofighter that we've been waiting for almost a decade to be release.
          Now even on a 4000 (Which is unacceptable for a 90mm combo) this plane is severely nose heavy...
          How can these planes be released with such a poorly designed battery bay? The builkhead should've been removed or designed around like the original Euro and the EDF could've easily been mounted further aft to avoid this huge issue.
          Can we get some insight as to how this was missed from Freewing?
          Having to add tailweight to a plane that could've easily been designed properly is just unacceptable considering how much time went into everything else on the plane (Which is beautifully done IMO)
          • kallend
            • 1877
            The so-called "test pilots" should have figured out the likely CG range customers would want and provided feedback before the design was cast in concrete (or foam).
            But they make slick marketing videos, which I suppose is more important.
              • 8835
              Something is not quite right. I'm going fly this with twin 6000mah, 4s batteries weighing a total of about >900g and with both batteries pushed as far back as possible, I can achieve a CG of about 10mm AFT of the marks on the wing. If you use a 6s battery weighing less thatn 900g, it should not be nose heavy. When I use my twin SMC HV, I'll relocate the control box and slide one battery on it's edge up into that spot OR I'll just use that supplied cylindrical weight they provided.
              • Alpha10
                J e t - J u n k i e
                • 377
                • Chicago
                Absolutely... Maybe good test pilots/tuners are becoming harder to find?
                Send me planes... I'll let you know REALLY quick lol
                I just can't believe this made it to final mold with such a critical issue like battery placement/cg flexibility... Insane.
                • Alpha10
                  J e t - J u n k i e
                  • 377
                  • Chicago
                  Yes, that's very strange because I've seen this plane be flown with a small 690g 6s pack all the way back to the bulkhead WITH 20g of tailweight and it's extremely nose heavy (Considering the true cg will likely be about 15-25mm aft of the manual)
                    • 8835
                    Do you have the 6s? I have the 8s. Perhaps the 8s fan is heavier? I haven't checked the weight of the 2 fans so can't say what the difference is. In this recent video from Arthur RC, you can see where his battery is (later in the video) - right at the rearmost part of the tray, up against that rear lip and the plane seems to fly quite well (aside from him chopping the centerburner light wires). He's using 70C CNHL LiPo, which tend to be on the heavy end of the scale for batteries in any size range.
                      • 5426
                      He said it was balanced 20mm aft of the marks and very nose heavy.
                        • 5426
                        The 8S has a much larger motor and a metal fan.
                          • 8835
                          That may explain why I don't seem to have a problem with balancing this plane.
                          • Alpha10
                            J e t - J u n k i e
                            • 377
                            • Chicago
                            Yes, that's the video I was watching... It might need 30mm tbh? I really want to test one myself, but I don't want to buy it if that's the case haha!
                            The 8s fan is a BRICK and likely why it's not a severely nose heavy compared to the lighter 6s version.
                            • kallend
                              • 1877
                              Looks like some "Kallend's Heavy Nozzles" are called for.
                              • Radar-Guy
                                AirBorn Jetworkx
                                • 364
                                Just in case someone can't wait. 55mm exhaust diameter. Three different versions:
                                1. Simple Replacement
                                2. Lengthened thrust tube. The hollow can be filled with additional ballast. "Foam bearer" on fuselage needs to be removed.
                                3. Solid version."Foam bearer" on fuselage needs to be removed.
                                https://cults3d.com/en/3d-model/vari...hter-v3-nozzle
                                • Radar-Guy
                                  AirBorn Jetworkx
                                  • 364
                                  Some cosmetic parts for the wingtip pods (DASS on the FSA) that Freewing omitted. I'll upload these as well when there's sufficient interest.
                                  • kallend
                                    • 1877
                                    Thanks - saves me a bunch of effort.
                                    • Radar-Guy
                                      AirBorn Jetworkx
                                      • 364
                                      You're welcome. Check these out, I'm glad to make changes when needed!
                                      Here's another thought regarding tail weight. It's possible to add ballast into that tail body between the nozzles. I've already designed a slightly nicer looking replacement for the "drag chute hatch". I will make the entire rear-looking face as a 3DP part, so it would be easy to remove foam inside, add ballast and close it again with that part.
                                      Click image for larger version  Name:	IMG_6425.jpg Views:	0 Size:	87.1 KB ID:	371715
                                        • 5426
                                        Okay Motion, your site still says mid March. I consider early to be days 1-10, mid 10-20… that’s 11 days away so you should have an idea of when the ship comes in and when you’ll get it. Time for an update!
                                        • Learj
                                          Addicted to the sky
                                          • Jun 2019
                                          • 17
                                          • Texas
                                          Hi all, is the 8s worth it? I would think the added weight would negate any gain. just curious. I plan on painting mine as I did my V2 that's still on the line and flying it is 8s as well. but I didn't gain much converting to 8s on the V2.
