  • Dewey H Lee
    WARBIRD JUNKIE
    • Apr 2015
    • 919
    • Fayetteville NC. US
    Maybe 50 or 60 5000 mah 6s.
    Dewey l
    • ckankel
      • Mar 2013
      • 39
      Any plans for optional ordnance packages? Would love to see CBUs, GBUs, and JDAMS as options.
      • TSHobbies
        Hobby Squawk Warbird Pilot
        • Nov 2015
        • 671
        • Cartersville GA
        sounds like the ordnance department would be a great aftermarket item for someone who does 3D printing/sculpting and can cast in a lightweight plastic
        www.TSHobbies.com
        • jamiew
          I fond this on RCGroups: "The aircraft can house a pair of 6s 4000 batteries, just like those recommended for the Freewing F-14D, and up to a pair 6s 6600s! So all of you stuffing 6s 5800s into your Tomcats won't have to worry with this big A-10."
            HI ckankel, welcome to Hobbysquawk! We don't have plans for additional ordnance packages at this time, other than the one we've created here. The reality is the cost to mold a wider variety of weapons has never come close to paying for itself in the past. However, for pilots wanting other ordnance other than what we're making, I recommend the 1/10 scale ordnance set from Jethangar.com that matches the Freewing's ~1/10 A-10. Jetmang is a member here, and he and his father run that website. They sell a wide variety of products, including highly detailed pilot figures that fit many of our planes, ordnance sets, 3D printed parts, and not to mention their high quality glass/wood ARFs/KITs.
            Hobby Squawk RC airplane, boat, car, helicopter, tank, truck blog forum community
            There is also our friend Keith at Parkflyerplastics.com. He produces a wide range of hop ups in plastic that go together quickly and in my experience are vacuum formed very nicely.
            Jamiew, welcome to Hobbysquawk as well!
              Here is more information about the Freewing 80mm A-10's ordnance set and its primary features.
              1) Correct pylon shape. Due to the shape of the wing, and the fact that on the real A-10 the pylons are not identical, we have actually molded four separate designs of pylon, each suited to fit at the correct station (#1, 2, 3, 4, and 8, 9, 10, 11). The outer pylons near the wing tips (#1 and #11) are the shorter pylons. The pictures show this better than I can describe.The three fuselage stations (#5, 6, and 7) are not molded, but installing the MWS hardware linked below is a quick affair for a modeler wanting to add those stations.
              2) Correct ordnance proportions. The factory painted sets will use accurate colors, too.
              3) Correct downward mounting angle. The ordnance on the real A-10 faces slightly downward, not straight ahead.
              4) Completely removable and exchangeable pylons and ordnance. Each wing includes four factory installed slide clips, using the same design as our Freewing 90mm F-15 and F-16, and the twin 80mm F-14, for example. The pylons slide onto the clips, giving the user the option to fly with zero or a mixture of empty pylons, or with a mixture of ordnance on different pylons, even if their desired mix doesn't match the "real" configuration. All of the weapons themselves can be moved to any pylon. Two AIM-9 Sidewinder missiles, two Mk.83 bombs, two AGM-65 Maverick missiles, one LAU-131 rocket pod, one ALQ-131 ECM pod, and one Sniper Advanced Targeting Pod. However, the intended "real" configuration is as shown in the picture with the Avanti. These are BIG weapons,with most being 9.5"-12.5" long. Notice the 12" ruler.
              5) Aftermarket. As I mentioned above, Jethangar has a 1/10 ordnance sets including triple racks and other goodies, which should scale well with the Freewing 80mm A-10. You'd need to install Freewing's MWS sliding clips to work with the Freewing pylons, but those sliding clips are available at four pairs for only $2: https://www.motionrc.com/products/fr...hment-hardware. I'm unsure what of the Parkflyerplastics.com weapons will fit, but I highly recommend his work as well. To give a rough idea compared to his weapon scales, our AIM-9 is 10.75" long and the Mk.83 bomb is 12.5" long.
              I'll paint these up tomorrow. Stay tuned!
              • Beeg
                • 1335
                • Texas
                Those look really good Alpha. Can't wait for this one. Already have the paint scheme picked out.
                  • 8217
                  Definitely awesome... Would jethangar or parkflyerplastics have the inboard tri-clusters seen on this bird (sorry not an ordinance guy, I don't know what you call them)? Man that just looks so sweet and will finish off my Arctic Aggressor scheme... :)
                    • 8217
                    Sweet! So this is it then?
                    6x Mark 82 500 lb bomb with triple ejector rack kit
                    (builds 6 complete mk82 bombs with LD or HD fins and 2 triple ejector racks, 1/10 scale)
                      Originally posted by Beeg
                      Yes. JetHangar has the triple ejector rack. Just go to their website, Accessories, scroll down to bottom of Aircraft Ordnance. For 2 triple ejector racks you'd be looking at $200 and that's for the kits. Another few hours assembling and painting.
                      Looks like 6 bombs (2 triple ejector racks) are $100. Am I looking at that correctly? I just picked up their 1/10th scale jet pilot. Looks pretty good.
                      • MikeT
                        Here......Hold my beer.
                        • 1060
                        Awesome
                        Mike.
                        • ckankel
                          • Mar 2013
                          • 39
                          Understand completely and thanks for the info!
                          • TSHobbies
                            • Nov 2015
                            • 671
                            • Cartersville GA
                            wow, that price is ridiculous for a vac form kit.
                            www.TSHobbies.com
                            • Beeg
                              • 1335
                              • Texas
                              yes, my mistake.. Looks like you get a dual set ( 2-racks) for $100, not $200.
                              And yes, I love their pilot figures. I have half a dozen or so. I just wish they'd do a 1/10 scale "Sabre" pilot.
                                They are actually $100 for 2 triple racks and 6 bombs but still...
                                  Jetmang's weapon set can be finished into Scale Masters quality TER, it has all manner of extra details in plastic and resin. Admittedly it might be overkill for this A-10, but hey, it is the only 1/10 TER kit I know of. And it looks great!
                                  It's raining kittens and horses over here, so I didn't accomplish much painting. But the base colors have been correctly scale effected and laid down. More to come as this week dries out.
                                  • TSHobbies
                                    • Nov 2015
                                    • 671
                                    • Cartersville GA
                                    when did they start mounting cell phones on the A10?
                                    www.TSHobbies.com
                                      LOL! Good one.
                                        That is a rip TS, damn near snorted my refreshment ;) all over the keyboard.
