    Originally posted by Splat
    Okay I've about had it with these decals lol.
    I feel ya. I've decal'd and weathered 3 of them since they first came out. On the last 2 I got the custom dragon nose art from Callie. All I can say is, soapy water is your friend!
    Click image for larger version  Name:	IMG_1560.JPG Views:	0 Size:	102.0 KB ID:	266994
    • NJP
      • Apr 2019
      • 7
      Wow, it has been a while since I have been on the site - what amazing models. Here in the UK making the most of it ....it is Hot. Giving the Hog and airing. One step closer to being flown.
      • PaulZ
        Crashing less
        • 279
        • DFW Area
        [QUOTE=Splat;n266957]Okay I've about had it with these decals lol. I still have to finish the wings and engines when I get there but here are some looks at my snake...oh wait, can I do that here? It's not that kinda a forum. 🤣 I think it looks okay, my OCD wasn't having it.
        That looks great, much better than mine. I think the trick is to lower the mouth. Mine at least has the eyes symmetrical now...at first it looked like a snake that took a side punch LoL!
          • 8202
          WOW! I LOVE how dirty your Arctic Girl is! Mine is far too pristine, in fact for being a Hog it's down right embarrassing. Yours really motivates me to get mine dirty and weathered. Looks fantastic!
            • 4817
            NJ, Great looking A-10. I really like the 'contrasting' panel lines with the "Artic Camo". Bravo Zulu, Sir. Best, LB
            • ColtPilot
              Hobby Squawk Advanced Pilot
              • Jun 2015
              • 538
              • Saint Clair Shores, Mi
              My FW A-10 taken by a friend.
              • Splat
                Warheads on Foreheads - IYAOYAS
                • Jul 2020
                • 105
                • Seattle, WA
                So programming the ESCs, the motor runs with the transmitter off and the battery still connected. Is this a trim issue?
                • DCORSAIR
                  • 1918
                  • Selma, Ca.
                  Okay guys, I'm sitting here trying to arm/sync these ESCs and I can't get it so I'm not sure what I'm doing wrong. This is what I have done.
                  1. Reversed throttle channel 3 on the Futaba radio, it was different from the rest so I figured I had to do that after someone mentioned it earlier.
                  2. Motor power leads are plugged into the "throttle" pegs on the control board in the cockpit. I'm not sure which way they go so that might be an issue too...is black towards the nose or tail if looking at it plugged in?
                  3. Throttle lead from board to Rx is plugged into channel 3 on Rx.
                  4. UBEC is plugged into battery/channel 6 on Rx.
                  I power on the transmitter and put throttle to full up, plug the 6S battery in to the lead with the UBEC running off it and it sings then starts beep beep beep beep, even if I move the throttle stick down. I don't know if the 6S isn't providing enough juice as it only has the charge from the factory on it but I've tried the other side without the UBEC and tried plugging in a receiver battery and it does the same thing.
                  I thought I had it from the posts I've read and you guys make it sound so easy. What am I messing up on??
                  I'm the one that said you may to have to reverse the throttle channel, if you had trouble getting them to arm with the throttle channel normal, so it sounds like you need to lower the throttle trim down from the center point, then it should arm, take the throttle trim lever and lower it all the way down, if no luck then you may have to go in to the radio menu end points or EPA and take the trim even lower. Do you want my phone number?? If you call me we can go over it together and just by what I hear I can tell you how to sync them real easy as well.
                  • Splat
                    • Jul 2020
                    • 105
                    • Seattle, WA
                    Originally posted by DCORSAIR
                    I'm the one that said you may to have to reverse the throttle channel, if you had trouble getting them to arm with the throttle channel normal, so it sounds like you need to lower the throttle trim down from the center point, then it should arm, if they don't then you may have to go in to the radio menu end points or EPA and take the trim even lower. Do you want my phone number??
                    Hey Corsair, yeah I reversed the throttle back and its working and I'll adjust the trim point. I wouldn't mind your phone number lol, I can PM you some questions. I'm having trouble getting the other motor, the one without the UBEC lead, to go now.
                      • 8748
                      The TX should never be OFF when the flight batteries are plugged in. The only exception is when binding.
                      • Splat
                        • Jul 2020
                        • 105
                        • Seattle, WA
                        Its been 10 years since I dealt with all this lol. Thanks Viper.
                        • DCORSAIR
                          • 1918
                          • Selma, Ca.
                          Sent a private message with my number.
                          • Splat
                            • Jul 2020
                            • 105
                            • Seattle, WA
                            I GOT IT!!! 😁😁😁
                            Both 80mm's humming in sync together and the whistles sound amazing lol. Thank you everyone!!
                            • Splat
                              • Jul 2020
                              • 105
                              • Seattle, WA
                              Some pics of the days progress. My new hated thing, running the wires from the engines to the electronics bay...ugh what a pain in the ass.
ID:	267230Click image for larger version
ID:	267231Click image for larger version
ID:	267232Click image for larger version
ID:	267233Click image for larger version
ID:	267234Click image for larger version
ID:	267235Click image for larger version
                              • DCORSAIR
                                • 1918
                                • Selma, Ca.
                                Now you did it, posting all these pictures makes me want another one, I sold mine after many flights on it and loosing my runway, but I want another one now,,,,,,,
                                  • 2691
                                  https://youtu.be/NiEJI5dycGQ
                                  Outstanding flight. Looks like you were up for more than 8 minutes. What batteries are you using?
                                    • 8748
                                    Hugh, he was up for only about 3 minutes - timed from when he started his take off roll to when wheels touched down. The rest of the video was two other planes. I had to go check when I saw your post. If he's getting 8 minutes, I'm doing something wrong with mine. I get barely 4 min using twin 5000's.
                                      Same here, 4 minutes on RoaringTop 5800s with 25% left at landing.
                                      • ColtPilot
                                        • Jun 2015
                                        • 538
                                        I have my timer set for 5 and get 4.5 minutes with 35% left on RT 6250's.
                                        • ColtPilot
                                          • Jun 2015
                                          • 538
                                          My A-10 comes in at 14lbs. 3 cell for the sound system, 2 double A's for the formation lights, and a 2cell for the wingtip strobes. Running a 2 speaker sound system from Model Sounds Inc. Need one more channel for the Brrrrrrrrrt.
