  • Thomas W
    • 54
    • Indianapolis, In.
    Noah gets his transplant the 28th. However he has vision problems that hopefully go away, if not he will be blind. He is getting stronger though and that is good. 5 months old now.
    Kind of new to this thread and forum, but you certainly have my best wishes and prayers for your son.
    • dahawk
      Augermeister
      • Jun 2013
      • 1006
      • Keller,Texas
      Pogo,
      congrats! A lot of similar experiences. I've logged 20 sorties now and she has not bit me yet. What a joy to fly. I love not having to fight the plane.
      • downwindleg
        • 1279
        • Friday Harbor, Washington
        Originally posted by Pogo
        Hi Brad- yes the spring needs to come off the hook, but can be left on the pin. Here's what I did (it's actually pretty easy once you get the hang of it.)
        1) Put the strut pin in a vice (use hardwood or something on the jaws so the pin doesn't get marred) to secure the strut. It stays in the vise for all the following.
        2) Use a pair of substantial needle nose pliers (with serrations on the jaw tips) and grab the spring coil above the hook and the hook itself with the very tips of the pliers. Squeeze, and with the help of a slot screwdriver pry the coil up and off the hook.
        3) Getting the spring back on back on is easier. Place the tip of a slot screwdriver through the coil and just onto the tip of the hook and pry back. Voila!
        (Wear eye protection and don't stab yourself!) Hope this helps.
        Tom
        First, congratulations on a successful maiden and followup flight. Second, thanks for the info on the spring removal and replacement. I assume you removed the strut from the plane since you put it in a vise. I'm not sure what you mean by grabbing the spring coil above the hook and the hook itself. Also, if you removed the strut, you must have carefully removed the painted plastic "cowl" to get at the grub screw to remove the strut from the retract pin. .thanks, Brad
        • Pogo
          • 452
          • Waterford, Ontario, Canada
          Yes, I skipped that step- the retract certainly needs to come out of the wing. The cowls come off easily. I can't take a picture right now but if you had it in front of you I think you'd see what I mean as regards removing the spring..
          Tom
            I may have come up with a bounce fix, I switched the struts from one side to the other...they still have straight up and down suspension but don't catapult. There's a little milling (filing) to be done on the "new" front side of the retract to match the other side,, just continue the dropped edge around to the other side and "V" out the retract plate a little on the open end. I hope this makes sense.
            I just put four flights on the A-10 and the last two I dropped it a little hard and only the nose wheel bounced a little.
            • TSHobbies
              Hobby Squawk Warbird Pilot
              • Nov 2015
              • 671
              • Cartersville GA
              unfortunately, I tried to get one of the mains off last week, and those dreaded hex screws stripped out on me...I hate those things!
              www.TSHobbies.com
              • gravityworks
                • 21
                • Nashua nh
                So u just switched the left and right mains ?? Tired iron ... a pic if possible
                • ColtPilot
                  Hobby Squawk Advanced Pilot
                  • Jun 2015
                  • 538
                  • Saint Clair Shores, Mi
                  If anyone would like this drop tank let me know. Includes the pylon and will include the plastic slip on pieces to glue in. It's 21.5" long for the center of the A-10. PM me, first come first served. No cost unless overseas.
                    I just switched them around, springs are toward the rear now.
                    • ColtPilot
                      • Jun 2015
                      • 538
                      Extended fuel tank has been spoken for. Thanks TI.
                        TI beat me by 4 min :P
                          Thanks so much!
                          • ColtPilot
                            • Jun 2015
                            • 538
                            My simple cradle for the FW A-10. Wings will fit underneath in a bag. Plus the HUD complete with the read out.
                              Originally posted by T-CAT
                              A few pages back, I posted an image of what a 22mm acrylic dome looks like on the AGM-65 without cutting the dome. The dome is just too round to work well, especially in that size, at least to look more realistic. The AGM-65 has a very shallow window unlike the shape of a dome. An ellipse is more of the shape that is necessary to look more realistic. However, the ellipses sold by the same company are solid all the way through and not hollow like the inside of the domes they sell. That's not a huge deal, but you would have to drill into it to place anything in the ellipse or put something on the foam part of the AGM-65, and glue the ellipse on top. It's not as good of an image as the dome, more of an illusion, but the ellipse seems to lay on top better and look more realistic. I will post some pictures of what the 22mm ellipse looks like installed with a quick paint job of the foam underneath. The shape is better.
                              Hopefully RCdude will get his installed as well to see what the cut down 25mm dome looks like, as they may work well.
                              OK, here are how my Mavericks and Pave Penny turned out with the 7/8" and 1" domes.
                                Very nice...as expected ;)
                                • ColtPilot
                                  • Jun 2015
                                  • 538
                                  Thanks and it's my grandson. He is in good hands at Boston's Children's hospital.
                                  • Sky Wolf
                                    Flying Ant
                                    • Sep 2013
                                    • 731
                                    • Irving, Texas
                                    Originally posted by OV10
                                    Now get that bird decaled or I'll have to start calling ya the Naked Flyin Ant LOL
                                    I know, right OV!
                                    However, the scheme I want to do requires painting, which I've never done before. Will have to YouTube study airbrush painting and get a kit.
                                    • Sky Wolf
                                      Flying Ant
                                      • Sep 2013
                                      • 731
                                      • Irving, Texas
                                      Anthony, beautiful job, and I really enjoyed your video! You're not, however, the last of the first group to maiden, as mine hasn't flown as yet (it's a long story....) Soon though.
                                      Anyway, congrats!! :Cool::Cool:
                                      Tom
                                      Dang it! I was going for the record of being the last one to maiden from the first run! :)
                                      • Sky Wolf
                                        Flying Ant
                                        • Sep 2013
                                        • 731
                                        • Irving, Texas
                                        Originally posted by dahawk
                                        Congrats Anthony! One fantastic maiden and a successful maiden smile to go with it. Headed out to our field late in the day( hot) for flights 18 & 19. Scott will maiden Avanti.
                                        Getting a pair of RT 6250 35C's from Andy(rcjetwerx.com) to push the 5 min mark. Unlike some other edf's in my squadron, once airborne, I want to stay airborne for as long as I can with the A-10.
                                        Cheers,
                                        Hawk( fellow Texan)
                                        Thanks Dave!
                                        let me know if those 6250's fit with the canopy completely closing. I tried to fit 2 new Wild Scorpion 5500's and the canopy wouldn't completely close.
                                        • Sky Wolf
                                          Flying Ant
                                          • Sep 2013
                                          • 731
                                          • Irving, Texas
                                          Great job Anthony, thought you might go for the grass to avoid the dreaded bounce but you pulled it off nicely on pavement. Brad P.S. Awesome airfield!!! BTW Frank Sinatra was a nice touch!!
                                          Thanks Brad! Glad you enjoyed old "Blue Eyes"!
                                          I was was wanting to avoid the grass if possible. You never know what hole may be lurking. :Scared:
